abutu
Reged: 03/09/07
Loc: Gijón (Asturias) - SPAIN
CPC800 & TV76 new
      #2558184 - 08/03/08 07:44 PM
Hello:
Well, I am planning to buy a 8" SCT. Finally I have decided not to go for the 9.25 because of the size and weight, I prefer something more portable. On the other hand, I am a pure visual amateur astronomer, and I do not have intention of doing astrophotography in the future. I am a tired of using GEM mounts, they takes time to allign and also sometimes the tube takes positions that are difficult for me to observe.
For these reasons I have put my eyes in the CPC800, I suppose that will be easy and quick to allign it, and of course the position to observe will be more friendly. What I don´t know is how precise is with the tracking??.
I would like to know your opinions of this telescope, I think will be very confortable to use (in comparison with a GEM).
My idea is to put on the 8" SCT a TV76 in piggy-back. Is it possible? Anyone has done it?. Where could I get the accesories to attach the TV76 to the C8? would it be neccessary a system of weights to balance the scope with this combo?
How do you see this combination? The TV76 for wide fields and the C8 for more detailed and planetary views?
Thanks a lot,
Alex
Rusty
Reged: 08/06/03
Loc: Brooker, FL
Re: CPC800 & TV76 new [Re: abutu]
      #2558507 - 08/03/08 10:43 PM
The TV 76 is certainly workable atop a CPC800. A top dovetail, rings and, shoes would be needed, and as you suspected, counterweights for the C8 would be necessary.
Astronomics and other vendors have the items you'll need.
I sometimes piggyback my WO 80mm on top of my N11 for the same reason - views different from the main OTA..
N11GPS Fastar
TOA-130S
MK66 Std
Vintage C5
Megrez II 80mm ED Triplet APO
SolarMax 40
NJP Temma II
Sirius EQ-G
ST8XE/CFW-8(LRGBHa)/AO-7/DF-2/STV Dlx/ST237a/350D (Unmodded)/Mallincam Color Hyper Plus/DSI III Color/DSI II Pro
Two not-spoiled Golden Retrievers - Maggie and Casey
Sometimes I think we're alone in the universe, and sometimes I think we're not. In either case the idea is quite staggering. - Arthur C. Clarke
Bob Griffiths
Reged: 10/10/05
Loc: Frederick Maryland
Re: CPC800 & TV76 new [Re: Rusty]
      #2559122 - 08/04/08 09:54 AM
As far as tracking goes...all I can say is that my new CPC1100 which I have only had out under the stars a few times but it sure did not give me any indication that it may not be tracking well... I also use a single arm 8i which has been pier mounted the last 2 years in my observatory (CPC will replace it shortly)..BUT I have tested tracking with the 8i and it kept Jupiter in the FOV for almost 4 solid hours a couple of weeks ago BEFORE it was my bedtime and I had to put the scope to bed...
I would not be concerned at all about tracking...once you get the"hang" of the scope it will track..especially with worm gers doign the driving instead of my 8i's spur gear setup...
Bob G
CPC1100
Nexstar 8i + GPS & Rays Brackets
Denk S1 power switch
Orion 100 mm Refractor
Meade LXD 55 ...AR-5 127 mm Refractor
Exploradome Observatory S.I.E. (Smiling Irish Eyes)
39*21'03" N
77*28'12" W
Rick Woods
Reged: 01/27/05
Loc: Inner Solar System
Re: CPC800 & TV76 [Re: Bob Griffiths]
      #2559208 - 08/04/08 10:46 AM
What Bob said.
Celestron and Meade both have the alt-az tracking algorithms pretty much down. Both will track for hours at high power, no problem at all.
You'll need weights on the bottom of the OTA to balance the TV76.
- Rick
14" LX200GPS
8" Meade 826C
3 registered and 10 anonymous users are browsing this forum.
Moderator:  Jason B
Home
