bob midiri
Reged: 06/17/04
Loc: pa 19320
Nexstar 5 Alignment problems new
      #2559403 - 08/04/08 12:17 PM
Hi group. I have the original Nexstar 5 (Silver OTA) which I gave to my daughter. Last night while aligning the scope using auto align, the scope slewed to Vega. During the process of centering Vega using the up arrow on the HC, I noticed Vega continue to drift in the same direction after I took my finger off that (up/down) arrow direction button and went to the left/right arrow button to center in that direction. Any idea in what might be occuring? It makes it very difficult to atttempt an accurate alignment with this occuring. Do you think it might be the batteries? Or is there something more sinister occuring. Thanks Bob Midiri
Homemade 16"F6.5 dob
Celestron Ultima 9.25
Celestron/Vixen Flourite 102F8.8 w Moonlight focuser
Celestron C6RGT w DS moonlight focuser
Cave 10"F6 Super Chrome deluxe
C80ED F7.5
Skywatcher PRO ED 120 w W.O dual speed rotatable focuser
sang33ta
Reged: 07/08/08
Loc: UK
Re: Nexstar 5 Alignment problems new [Re: bob midiri]
      #2559424 - 08/04/08 12:24 PM
Probably gear slack / backlash it's normal, there is sometimes a compensation setting you adjust in the handset. Normaly you take your drives through a traning procedure which I assume calculates the adjustment required.
Hioptic 152mm f12.5 Maksutov
Celestron Advanced CG5-GT Mount (Mr Noisy!)
Meade 4000 Super Plossl Set
Casio QV-2900UX
Got fed up of waiting for Meade ETX-150 so put this together for £500/$1000
Edited by sang33ta (08/04/08 12:27 PM)
Bob Griffiths
Reged: 10/10/05
Loc: Frederick Maryland
Re: Nexstar 5 Alignment problems [Re: sang33ta]
      #2559569 - 08/04/08 01:49 PM
If it is drifting UP when you release the direction button it would be most likely caused by the your basklash settings...
and to be honest I have no clue if the NS5 has both positive and negative settings for each axis...
If it is drifting Down when you release the button I'd guess is that your altitude adjust nut need to be adjusted...This is assuming the scope is still fixed to the mount and is still very slightly rear end heavy...
Adjusting the nut is a simple process..but I would NOT tighten it ore then 1/8 of a INCH ..not 1/8 of a TURN...then recheck how it works.. this can be easily done in daylight using a shingled roof or a brick wall as your background,...
Bob G.
CPC1100
Nexstar 8i + GPS & Rays Brackets
Denk S1 power switch
Orion 100 mm Refractor
Meade LXD 55 ...AR-5 127 mm Refractor
Exploradome Observatory S.I.E. (Smiling Irish Eyes)
39*21'03" N
77*28'12" W
7 registered and 14 anonymous users are browsing this forum.
Moderator:  Jason B
Home
