Mike Phillips
Reged: 02/21/06
Loc: Swift Creek, NC - 35.682 N, 78...
Mike Phillips' 1st Double Transit
      #2560865 - 08/05/08 12:31 AM Attachment (45 downloads)
More to come once I get inside and get some sleep. Here's the teaser... anim and stats forthcoming!
New home:
http://maphilli14.multiply.com/
Older Astro Photos:
http://picasaweb.google.com/maphilli14
HowTo: Planetary Processing Routine v7
http://maphilli14.multiply.com/journal/item/37/Michael_A._Phillips_Planetary_Processing_Routine_version_7.0
Mike Phillips
Reged: 02/21/06
Re: Mike Phillips' 1st Double Transit new [Re: Mike Phillips]
      #2560866 - 08/05/08 12:32 AM
Just noticed, rising oval BA too!
this is my regular setup @ 150% resize
New home:
Older Astro Photos:
solshaker
Reged: 06/06/06
      #2560880 - 08/05/08 12:39 AM
great shot, Mike. looking forward to the rest.
My Gallery
siriusc
Reged: 04/03/07
Loc: Racine, WI
      #2560894 - 08/05/08 12:46 AM
Great update, Mike! Nothing but clouds here in Wisconsin. Thanks for the virtual view. cheers, Dan
Mike Phillips
Reged: 02/21/06
Re: Mike Phillips' 1st Double Transit new [Re: siriusc]
      #2561501 - 08/05/08 10:32 AM Attachment (13 downloads)
Last one for now, as I've got a day job to tend to.
New home:
Older Astro Photos:
john D
All you have to do is ask!!
Reged: 08/05/07
Loc: Midlothian, VA
      #2561918 - 08/05/08 02:05 PM
great shots mike!
Meade ETX-125
Meade LXD55 mount
Philips SPC900NC webcam
Seymour Solar filter
Backyard Observatory
-Midlothian VA
--Land Of The Free Because Of The Brave--
Mike Phillips
Reged: 02/21/06
Re: Mike Phillips' 1st Double Transit new [Re: john D]
      #2565375 - 08/07/08 12:55 AM
Quickly processed animation of 18 frames from about 6 minutes apart and 60s per RGB @
http://picasaweb.google.com/maphilli14/MichaelAPhillipsAstronomyJupiter08Gallery/photo#5231634843530907730
New home:
Older Astro Photos:
Mike Phillips
Reged: 02/21/06
      #2570526 - 08/09/08 03:10 PM Attachment (7 downloads)
Full(er) report
Ad hoc plan was to get as much as the local trees would allow! I started to focus and take test shots on nearby stars but they all seemed
too dim to catch with the Hartmann Mask. So as I piddled around I found Jupiter was clearing the trees. I knew that Ganymede started transit
before the planet was in shooting position so I quickly adjusted the alignment and did a bad focus through the leaf-less tree just in front of the
the planet.
By the time Callisto was transiting, I refocused and had much better success. I took 3 x 60s captures per channel nearly every
6minutes from 021302UTC to 040334UTC, then it disappeared behind the leaves over the right side of my driveway. Visualize my driveway
facing the road nearly spot on facing south. Should I move the scope for a better angle on the wondrous trees?
I did and manged to get 1 more good shot as the GRS hit the CM!
I may reprocess and post again as I did not use any Lucy-Richardson Decon for any of these shots. I'll follow up with one that does.
New home:
Older Astro Photos:
Mike Phillips
Reged: 02/21/06
      #2570527 - 08/09/08 03:10 PM Attachment (5 downloads)
100% sized and mono of Left capture:
New home:
Older Astro Photos:
Mike Phillips
Reged: 02/21/06
      #2570528 - 08/09/08 03:12 PM Attachment (7 downloads)
And one final for today with LRdcon...
ooops realized that was one from up top... oh, well, ya'll tell me which processing is better. With or without LRdecon?
New home:
Older Astro Photos:
Edited by Mike Phillips (08/09/08 03:13 PM)
john D
Reged: 08/05/07
Loc: Midlothian, VA
      #2571117 - 08/09/08 09:36 PM
wonderful images Mike!
Meade ETX-125
Meade LXD55 mount
-Midlothian VA
Lunatiki
Reged: 08/07/05
Loc: Amarillo, TX
      #2571127 - 08/09/08 09:45 PM
Mike, I like the last one you posted showing the R,G and B. And Ganymede looks great in that shot too. Kind of 3d.
Mars Watch
All images taken with:
Celestron NexStar 8i SCT
DBK 21AF04.AS
K3ccd/Registax4/PSP8
ALPO Member #4287
6 registered and 22 anonymous users are browsing this forum.
Home
