Privacy Policy |
Please read our Terms
of Service | Signup and
Mr. Bill
Reged: 02/09/05
Loc: Just passing through.....
Thinking about the "new" Vixen 125mm binos that use 1 1/4 inch eyepieces. Apparently this is a rerelease in the US of the same binoculars that were offered several years ago and pulled from the US market.
Called Vixen and couldn't get a straight answer if they are user collimatable. The standard "might void the warrenty" response.
Is there a way to get at the prism adjusting screws without disassembling the prism housing?
-------------------- 10x50 Fujinon FMT-SX binos
15x70 AP binos + Paragon p-mount
Oberwerk 100BT 45 degree + Hercules fork mount
120mm f/5 Orion achromat + Moonlite focuser
140mm f/5.7 Vixen NeoAchro Petzvel refractor
150mm f/6.5 Antares achromat
150mm f/8 homemade achromat....EE Barnard MW Sweeper
8 inch newt with f/5 Swayze mirror
10 inch f/4.7 Orion newt + Paracorr
15 inch f/5 Discovery split tube
35mm Pan, 26mm Nagler, 17mm Nagler, 13mm Ethos, 8mm Ethos
Member IDA
EdZ
Professor EdZ
Reged: 02/15/02
Not that I am aware of, but I might have missed something.
edz
-------------------- Teach a kid something today. The feeling you'll get is one of life's greatest rewards.
member#21
zx12
Reged: 12/29/05
Loc: Rhode Island
Hi Bill,
I have not needed to adjust my pair of BT 125's as they have been spot on for collimation/alignment up to 150x even after enduring many trips to dark sky sites in my truck. I have a nice Scopeguard case so they are cushioned well.
When I talked to a Vixen rep during an sales event at my scope shop, he said the adjustment is similar to the BT 80.
Lift the black cover on top of the prism housing, remove the screws holding the cover and access the prism adjustments inside.
I don't know if barrel adjustment is possible, but I would imagine that it would be needed only if you dropped them.
I can say that my particular pair has performed superbly and they are the only piece of astro gear that I feel is irreplaceable to me.
Bill Rose seems to have adjusted his pair, maybe he might chime in on how it was done.
-------------------- AP 160 Starfire/AP 1200GTO
Stellarvue SV809D
Vixen BT 125 HFT-MA
Oberwerk BT 100/45
Tak 22x60 Astronomer
Nikon 10x70 FMT-SX
Leica 8-12x42 Duovid
WO 66mm SD
4 registered and 25 anonymous users are browsing this forum.
Moderator: EdZ
