Tom TrusockAdministrator
Reged: 02/26/02
Loc: Alternate Reality (TM)
Re: Nagler 13mm T6 真questions?? new [Re: ausastronomer]
      #2565839 - 08/07/08 09:47 AM
If you get a 13 marked "made in japan" be certain it's the t6, not the t1. Offhand, I don't recall where the t6's were made.
T
Hi Tom,
I spoke at length about this topic (and many others) with Al Nagler at 2007 TSP. Al explained to me that he tried to split production of Televue eyepieces between the manufacturing plants in Taiwan and Japan. He indicated that generally the smaller eyepiece series were produced in the Japanese factory and the larger eyepieces (T4's, T5's, Panoptics and now ETHOS were produced at the Taiwanese factory. Al indicated the Taiwanese factory were "slightly" better set up tooling wise to produce the physically larger eyepieces, but each factory could quickly tool up to produce any eyepiece in the TV range. Al said this gave him comfort if ever issues arose with one manufacturer, because he could quickly switch all manufacturing to either Japan or Taiwan.
Ah yes, I remember that now. Thanks for assisting in my momentary lapse of memory John.
There are two theories to arguing with my wife. Neither one works.
Edwin Quiroga
Reged: 01/31/08
Loc: Miranda, Venezuela
Re: Nagler 13mm T6 真questions?? new [Re: Starman1]
      #2565918 - 08/07/08 10:36 AM
Very interesting info!
jcjr
Reged: 01/06/08
Loc: TN, USA
      #2566088 - 08/07/08 12:04 PM
Actually, in this eyepiece, if you are far enough in to contact the eyecup, you are too close to the eyepiece. The field stop becomes visible several mm before your face touches the eyecup. Many people report blackouts with the Type 6 Naglers, and that is why--they think they have to touch the eyecup to see the whole field of view. If you move in slowly until your peripheral vision *just* sees the fieldstop, you will never touch the lens with eyelashes.
The eyecup is designed, I believe to reduce peripheral light hitting the eye, because the eye lens is fairly flat, which can reflect light back at the eye that is reflected off the cornea.
The coatings on this eyepiece are so good there essentially is no internal reflection, and the ghosts and light scatter people report is often due to the reflection off the cornea being reflected back by the eye lens, which is only an issue with planets and very bright stars.
Thanks Don
Will experiment further. I could not see the field stop edge until touching the eyecup, but that was while looking directly AT the fieldstop. If the idea is to stare straight ahead and only pick out the field stop edge in peripheral vision, maybe won't have to get so close.
It is an interesting device to peer thru, because if one does get real close, then it is possible to 'peek around the edges' and see quite a bit of extra field 'hidden' inside the lens (grin).
The coatings seem really effective. When first inspecting the eyepiece, it took a moment to recognize that the field lens is so near to the barrel opening, because the reflection coming off the field lens is so dim. Glad I didn't poke my finger in the barrel (grin).
CPC 1100, C102SLT, SV F80, Meade 70 & 60 AZT
Q70 38mm, Pan24, Meade 5K 18mm UW, Axiom LX 15mm, Nagler 13T6, Axiom LX 10mm, Expanse 20mm, 9mm, 6mm, BO/TMB 5mm, 2.5mm
Astro1956
Reged: 12/23/05
Loc: NE, USA
Re: Nagler 13mm T6 真questions?? [Re: Starman1]
      #2567578 - 08/08/08 12:12 AM
All my T6s are made in Japan. I don't know if the glass is superior to TV lenses made in Taiwan. I'm happy with all my Tele Vue lenses. After comparing to other manufacturers I use only TV lenses except for a Rigel 12.5 reticle Plossl. That ones says made in Japan also.
TV 102
Tele-Vue 60 Imaging System
TV 31mm T5
TV 26mm T5
TV 20mm T5
TV 16mm T5
TV 13mm T6
TV 11mm T6
TV 9mm T6
TV 7mm T6
TV 5mm T6
TV 3.5mm T6
TV 2.5mm T6
TV 2-4 Zoom Nagler
TV 13mm Ethos
TV 8mm Plossl
TV 11mm Plossl
TV 20mm Plossl
TV 55mm Plossl
TV 41mm Panoptic
Losmandy G11 Gemini Level 4
26 registered and 12 anonymous users are browsing this forum.
Moderator:  Greg K., Jason B, csa/montana
Home
