CarlosEH
Reged: 01/19/05
Loc: Pembroke Pines, Broward County...
Jupiter Observation (August 3, 2008) new
      #2558813 - 08/04/08 03:01 AM Attachment (22 downloads)
I made an observation of Jupiter on August 3, 2008 using my 9-inch F/13.5 Maksutov-Cassegrain. Much detail was noted over the planet, especially the South Equatorial Belt (SEB) and Great Red Spot (GRS). The seeing conditions were above average (6/10) for a short time before the clouds came in and ended my observing session. I welcome any comments that you may have on my observation.
Date (U.T.): August 3, 2008
Time (U.T.): 05:00
L1 016.2, L2 179.5, L3 177.6
Diameter (Equatorial): 46.4"
Instrument: 9-inch (23-cm) F/13.5 Maksutov-Cassegrain
Magnification: 273x
Seeing (1-10): 6, Antoniadi (I-V): III
Transparency (1-6): 5
Notes:
South Polar Region (SPR): Appears dark to dusky (3-4) and mottled.
South Temperate Zone (STZ): Appears thin and shaded to bright (6-7/10).
South Temperate Belt (STB): Appears dark (3/10) and thin. No ovals visible within it.
South Tropical Zone STrZ): Appears bright (7/10) with a dark (3/10), oval-shaped albedo feature following the central meridian (CM) and preceding the Great Red Spot (GRS).
Great Red Spot (GRS): Appeared dusky (3/10) and salmon-pink with a white central core.
South Equatorial Belt (SEB): Appeared dark to dusky (3-4) and containing dark (3/10) dark condensations along it's northern border and bright (7/10) undulating sections (strips) within it.
Equatorial Zone (EZ): Appeared shaded to bright (6-7/10) with a thin, dusky (4/10) band across the center of it.
North Equatorial Belt (NEB): Appeared dark (3/10) and thin with a dark rod (barge) on the CM along it's northern border.
North Tropical Zone (NTrZ): Appeared bright (7/10), but no other detail visible within it.
North Polar Region (NPR): Appeared dark to dusky (3-4/10) and mottled.
The best of luck in your own observations of Jupiter.
A digital observation made using Photoshop CS3.
Carlos
CarlosEH
Reged: 01/19/05
Re: Jupiter Observation (August 3, 2008) new [Re: CarlosEH]
      #2558815 - 08/04/08 03:05 AM Attachment (11 downloads)
A wider field observation of Jupiter made on August 3, 2008 (05:00 U.T.) showing Io and Europa, respectively, preceding the planet.
Carlos
RLTYS
Reged: 12/18/04
Loc: New York (Long Island)
      #2558906 - 08/04/08 06:51 AM
Carlos
Excellent sketches, keep up the good work and thanks for the view. Did you see Red Spot Jr?
Thanks and clear skies.
Rich (RLTYS)
10" F4.8 Refl.
4" F5 Refr.
80mm F5 Refr.
12x63 and 10x50 Binoculars.
Tommy5
Reged: 03/28/04
Loc: Chicagoland
Re: Jupiter Observation (August 3, 2008) new [Re: RLTYS]
      #2559062 - 08/04/08 09:10 AM
Wow great sketch of jup, i see you spotted the condensation trailing the grs and a you have included a thin eq band,very sharp sketch, very realistic looking and clever use of the digital media.
Reged: 06/13/06
Loc: Illinois
Re: Jupiter Observation (August 3, 2008) new [Re: Tommy5]
      #2559076 - 08/04/08 09:22 AM
Carlos,
Most impressive renderings of Jupiter and company. The details in your notes and drawings are just superb. Wonderful work!
Frank
cildarith
Reged: 08/26/04
Loc: San Diego, CA
Re: Jupiter Observation (August 3, 2008) new [Re: frank5817]
      #2559263 - 08/04/08 11:10 AM
Excellent observation, Carlos! I especially like the wide angle view showing two of Galileo's satellites.
Eric
6" f/6 Parks Newtonian
10x50 Bushnell Binocs
CN Sketch Gallery
CarlosEH
Reged: 01/19/05
Re: Jupiter Observation (August 3, 2008) new [Re: cildarith]
      #2559702 - 08/04/08 03:04 PM
Thank you all for your very kind compliments on my Jupiter observation. I was happy to be observing Jupiter once again. The king of the planets always presents a challenge. I look forward to your future observations.
Rich- I was unable to view Red Spot Jr. as it was on the following limb and therefore more jovian atmosphere to look through. I hope to see it and the Great Red Spot in detail soon. The best of luck in your own observations.
Carlos
WadeVC
Reged: 12/02/05
Loc: Lodi, California,
      #2559785 - 08/04/08 03:45 PM
Carlos,
Once again you have offered to us a very pleasant and exceptional rendering of your observation(s). Excellent!
Orion XTi10 f/4.7
Meade NGC 70mm f/10
Orion UltraView 10x50 Wide-Angle Binoculars
My Sketch Gallery
My Astronomy Blog
A wise man can see more from the bottom of a well than a fool can from a mountain top.
CarlosEH
Reged: 01/19/05
Re: Jupiter Observation (August 3, 2008) new [Re: WadeVC]
      #2559826 - 08/04/08 03:59 PM
Wade,
Thank you for the compliment on my latest observation of Jupiter (and satellites). It was fun observing Jupiter once again. Your observation of Jupiter was fantastic. I look forward to your future observations.
Carlos
markseibold
Reged: 01/19/08
Loc: Portland Oregon
      #2560873 - 08/05/08 12:34 AM
Carlos
Very nice digital rendering. It is very similar to what I saw at about 9UT (2 AM PDT this morning) as the GRS just rotated into view from the planets western edge before I called it a night.
I had made some Photoshop renderings of Jupiter as observed though my 10.1" Dob last summer. Although I do not think I am getting the detailed image that you are through a 9" Maksutov.
I look forward to your furture sketches.
best regards,
Mark
CarlosEH
Reged: 01/19/05
Re: Jupiter Observation (August 3, 2008) new [Re: markseibold]
      #2560991 - 08/05/08 01:51 AM
Mark,
Thank you for the compliment on my Jupiter observations. I am looking forward to a good view of the Great Red Spot (GRS) on or near the CM. The best of luck in your own observations.
Carlos
Special Ed
Reged: 05/18/03
Loc: Greenbrier Co., WV 38N, 80W
Re: Jupiter Observation (August 3, 2008) [Re: CarlosEH]
      #2568057 - 08/08/08 09:47 AM
Carlos,
It's wonderful to see one of your excellent observations and detailed reports. The colors in these digital renderings are really nice. Hope you can post another one soon--I haven't seen nearly enough of Jupiter this year--either through my own telescope or through the eyes of others.
Btw, looking at the drawing, I think that preceding and following are reversed.
Michael Rosolina
8" f/10 Orange Tube SCT
4.25" f/4.2 Astroscan Reflector
SVP 3.6" f/13.6 CA Reflector
40mm PST f/10
APM Germany HD 15x70 binoculars
Canon 12x36 IS II binoculars
Mark I Eyeball
My CN Gallery
Happy Birthday rodelaet
Reged: 04/28/06
Loc: 50°56' N - 4°58' E (Belgium)
      #2568807 - 08/08/08 04:08 PM
Carlos,
Wow, what a sketch! I'm really impressed.
That is maximum quality time. Look at all those details you recorded. And an excellent choice of colors as well.
Rony
My Astronomy Sketches
My Binocular Sketches
markseibold
Reged: 01/19/08
      #2568833 - 08/08/08 04:24 PM
Carlos
Beautiful rendering with computer software. With the extreme contrast in the NEB and SEB, are you using filters at the eyepiece?
Thanks again for sharing this,
Mark
CarlosEH
Reged: 01/19/05
      #2571512 - 08/10/08 03:53 AM
Mark,
Thank you for the compliment on my Jupiter observation. The observation was made without the use of a filter. I have employed filters on Jupiter in the past. The reddish-brown belts are enhanced using a light blue (Wratten 80 or 82A) or blue (W38A) filter. The Great Red Spot (GRS) may be enhanced using the blue filters above as well as a magenta (W35) filter. I tend to observe without the use of filters but they can prove useful to amy observers.
I look forward to your excellent observations.
Carlos
2 registered and 1 anonymous users are browsing this forum.
Moderator:  LivingNDixie, Charlie Hein
Home
