Davidgojr
Reged: 08/09/08
Loc: San Antonio, TX
Planetarium Software to Display Double Stars?
      #2572626 - 08/10/08 05:15 PM
Does anyone know of any good programs to display the locations of good double stars to observe? I currently use Stellarium and Starry Night but neither of these seem to have good lists of double stars.
San Antonio, TX
Orion XT6
Make-it Better
Reged: 06/30/07
Re: Planetarium Software to Display Double Stars? new [Re: Davidgojr]
      #2572682 - 08/10/08 05:41 PM
CdC has the Washington Double Star Catalogue available for it.
Roy P.
CGE C11
ED 80
400D
Davidgojr
Reged: 08/09/08
Re: Planetarium Software to Display Double Stars? new [Re: Make-it Better]
      #2572990 - 08/10/08 08:03 PM
Sorry if this is obvious but what is "CdC"?
San Antonio, TX
Orion XT6
Cotts
Reged: 10/10/05
Loc: 130km eastof Toronto
      #2573796 - 08/11/08 07:48 AM
I suspect that CdC is 'Carte du Ciel' . Bonjour. d.c.
David Cotterell
Cnoc nan Rionnag Observatory
Castleton, Ontario
152mm APM f/8 Triplet LW APO
80mm WO Zenithstar FD
66mm WO ED
Losmandy Titan Mount with Gemini
10-inch Lightbridge
Losmandy G-11 mount
Pete W
journeyman
Reged: 02/24/08
Loc: Round Rock, TX
      #2575344 - 08/11/08 08:46 PM
SkyTools has a star charting function that shows a great selection of doubles, and if you click on one it will give you the vital stats including the multiple components and calculated up-to-date separations for binaries.
SkyTools also generates lists of doubles based on magnitude, separation and magnitude differences, but the actual star designations that are compiled by the search is limited to Struve and ADS numbers. You can always go to the star chart function and click on a specific star to get the more common double designation (Burnham, Otto Struve, Herschel, etc.
I believe that Skymap pro will allow you to download files of doubles (Struve's, Astro League doubles, etc) and you can print out charts with doubles labeled.
These are the two charts I use for doubles. Good Luck!
Pete Wehner
Round Rock, TX
SabiaJD
Reged: 02/20/05
Loc: Clarks Summit, PA
Re: Planetarium Software to Display Double Stars? new [Re: Pete W]
      #2580507 - 08/14/08 09:14 AM
And you can use Taki's Double Star Atlas. http://www.asahi-net.or.jp/~zs3t-tk/index.htm
or Atro Planner http://www.ilangainc.com/astroplanner/index.html
John D. Sabia
Richard Hendrix
Reged: 08/02/06
Loc: Jacksonville, Florida
      #2581227 - 08/14/08 02:51 PM
Hi Davidgojr,
I have Starry Night Pro and it contains the Saguaro Astro Catalog of 11000 doubles. You can find it under the tab Options> Other> click Double Stars. Make sure you turn off the Stars under the tab Options> Stars menu. This extra catalog may not be installed by default by SNP.
hope this helps,
Richard Hendrix
Antares 105mm f/9.5 Elite Series Refractor
AstroTelescopes 102mm f/7 Refractor
Orion SkyView Pro 8" Intelliscope
Orion Scenix 10x50 Binoculars
Zhumell SuperGiant 20x80 binoculars
NightSky Journal
"Every star may be a sun to someone."
Carl Sagan, Cosmos
Davidgojr
Reged: 08/09/08
Re: Planetarium Software to Display Double Stars? new [Re: Richard Hendrix]
      #2586057 - 08/17/08 03:37 AM
Thanks for the great information. I'll try some of the suggestions soon!
San Antonio, TX
Orion XT6
Davidgojr
Reged: 08/09/08
      #2586835 - 08/17/08 03:09 PM
Richard,
I just tried doing what you suggested in Starry Night. Unfortunately, I don't see the the Saguaro Astro Catalog of 11000 Doubles. You mentioned that it may not have been installed by default. If not then how do I install it?
San Antonio, TX
Orion XT6
Richard Hendrix
Reged: 08/02/06
      #2586975 - 08/17/08 04:58 PM
Richard,
Davidgojr,
You can find the SAC Doubles here on the Starry Night Support page. Installation readme is in the zip file.
hope this helps,
Richard Hendrix
NightSky Journal
Carl Sagan, Cosmos
Davidgojr
Reged: 08/09/08
      #2590977 - 08/19/08 04:10 PM
I just did what you said at it now works perfectly! Thank you. Now if only the skies will clear so I can begin my doubles observing...
San Antonio, TX
Orion XT6
Richard Hendrix
Reged: 08/02/06
      #2592608 - 08/20/08 09:55 AM
Davidgojr,
Glad that worked for you. I understand about the weather, I have TS Fay knocking at my door and looks to be cloudy another week here in North Florida.
Good luck with your doubles observing!
Richard Hendrix
NightSky Journal
Carl Sagan, Cosmos
1 registered and 0 anonymous users are browsing this forum.
Moderator:  EdZ, RLTYS
Home
