Rob Willett
Reged: 02/07/05
Loc: London, UK.
Can you drive a Giro II or WO Alt-Az mount? new
      #2575871 - 08/12/08 04:07 AM
I had an idea about driving the various Alt-Az mounts such as the Giro II/III and WO Ez-Touch.
I'm sure somebody has thought about this and why it's a bad idea, so fire away
I have a Giro II mount and really like it, easy to setup, no polar alignment, no levelling, takes massive amounts of weight and zero problems.
I was thinking about astrophotography and how the Chief Financial Officer has decided, for some obscure reason (lack of money?) that I'm not allowed to buy anything else. I then wondered if the Giro II could be adapted to do photography.
So my logic was:
  • Make a wedge for the Giro II. Clearly it needs to be where I am, 56 and a bit North
  • You need to be able to lock the Alt axis on the Giro
  • You need to be able to drive the body of the Giro at an appropriate speed.
  • Use a webcam to take lots of frames and throw away the rubbish ones (all of them?)
Making a wedge is easy enough, locking the Alt axis is easy as well, driving the body of the Giro is a little more tricky, but belts and stepper motors come to mind. Though also a little friction wheel (skateboard?) might also do for testing the idea out.
I'm not trivialising the effort, and I need to polar align, etc etc, but a) will this work? and b) Has anybody done this before?
What am I missing? or is this one of those ideas that should be tried out?
Rob
gatorengineer
Reged: 02/28/05
Loc: Hellertown, PA
Re: Can you drive a Giro II or WO Alt-Az mount? new [Re: Rob Willett]
      #2575930 - 08/12/08 06:53 AM
See Dob Driver from Tech2000......
16" & 20" Dobs
4" Triplet Refractor
10" LX200R OTA
8"F20 Dall Kirkham
12.5" F3.5 Newt
CGE
Lots of binos---
Nikon 8x30, 10x35, Prostars,10W/18 x 70 astrolux; 10x50 Fujis. Collectors items 12x60 BLC, 10x80 Flaks, Gas Masks, US Mark 28, 30, 41, 43's
Telescopes Past - 8" Stf Mak, C8, Meade LX10-10", SN8, TAL150K, Orion 150MC, Jason 60mm refractor, ATM 6" F8, WO 110FLT, 92mm Off Axis Newt, Nikon 20x120 bino's, 15x110 Boarderguards, Kuhne Flaks
Luigi
Reged: 07/03/07
Loc: Massachusetts
Re: Can you drive a Giro II or WO Alt-Az mount? new [Re: gatorengineer]
      #2575954 - 08/12/08 07:23 AM
The Ioptron Tower is a new, driven Alt-Az with ratings similar to the GiroII or WO mounts. Check out the threads in the mounts forum.
17.5" f/5 Discovery Truss
IM715 7" f/15 MCT, Eon-120ED
Lunt 60mm single etalon HA
CG5A coffee grinder, Orion Skyview Alt-AZ
35,19,15 Pans.9 Nag. Meade 24.5 4kSWA, 4.7 5kUWA.
BO-TMB 7mm planetary.
Zeiss Diascope 85
Zeiss, Leica, Canon IS, Fujinon, Nikon binos
Rob Willett
Reged: 02/07/05
Loc: London, UK.
      #2575974 - 08/12/08 07:46 AM
Sadly this requires money which is not forthcoming from the CFO.
Rob
Rob Willett
Reged: 02/07/05
Loc: London, UK.
Re: Can you drive a Giro II or WO Alt-Az mount? new [Re: Luigi]
      #2575975 - 08/12/08 07:48 AM
Luigi,
Thanks for this, but the point is I already have a Giro II and want to utilise that rather than buying any more kit (which I can't).
Rob
Michael Miles
Reged: 02/11/05
      #2576452 - 08/12/08 12:40 PM
Do you have a holocaust cloak and a wheelbarrow?
What other resources do you have? Free stepper motors, belts and gears? Metal machining tools? Friends with metal machining tools?
Webcam mated to what type of optics?
I think it might be possible, but it depends on how much performance and precision you expect from the mod.
Michael
LXD-75 w/
Stellarvue 102ED
Hardin 10" Newt
Antares 8" Newt
Meade AR-5
Meade N-6
Celestron 102mm refractor
Canon 300D, Meade DSI guiding
scout72
Reged: 05/12/08
Loc: SF Bay Area
Re: Can you drive a Giro II or WO Alt-Az mount? new [Re: Michael Miles]
      #2576484 - 08/12/08 12:55 PM Attachment (17 downloads)
You mean something like this:
You can buy this setup from Teton Telescopes- or use this as inspiration to build your drive - a couple of motors and gear plates and some big ole hoseclamps and you are good to go!
Scout72 is my 1972 International Scout 4x4
Some Scopes, Some Binocs, and Some Mounts,
and a much shorter signature
Rob Willett
Reged: 02/07/05
Loc: London, UK.
      #2577318 - 08/12/08 06:36 PM
Michael,
Got four high quality stepper motors plus a number of cheaper motors. I can write the software and build stepper motor circuits using PIC controllers.
Lathes I don't have, mores the pity.
Webcams are plentiful, and I can mate them from a Borg 76mm through to a Brandon 94mm or TMB 100mm. I also have a home made 80mm short field refractor which is 'almost' finished.
My thinking was a friction belt around the Giro, I can control the stepper motor down to microsteps. I'm at work at the moment and can't remember the angular resolution of the motors.
My thinking is that I 'plan' for slop and use the webcam and Registax to average it out.
Rob
Rob Willett
Reged: 02/07/05
Loc: London, UK.
Re: Can you drive a Giro II or WO Alt-Az mount? [Re: scout72]
      #2577363 - 08/12/08 06:56 PM
I already have this on my Giro II
It's the Wildcard Innovations mounting kit for their digital setting circles, this is a push-to system, not a motorised system which I was after.
Rob
9 registered and 4 anonymous users are browsing this forum.
Moderator:  Don W, Joe Cipriano
Home
