Observing >> Deep Sky Observing
NGC6144
Reged: 07/24/08
Loc: Virginia Beach, VA
NGC 7662
      #2578087 - 08/13/08 12:12 AM
With my 10inch I can see mottled edges, deep blue coloration and a second smaller oval portion in the center. No central star though. this is with 150x using a 8mm hyperion. What is everyone elses notes on the Blue snowball?
Orion Skyquest XT10i w/telrad
21mm Hyperion
8mm hyperion
Messier objects observed this year:65
caldwell objects observed this year:10
Herschel 400 objects this year: 9
Never
Reged: 11/22/05
Loc: Finland
Re: NGC 7662 new [Re: NGC6144]
      #2578194 - 08/13/08 01:58 AM
For the central star I'd use a lot more magnification than 150x. Four years ago, I failed to see it with a 8" Skyquest @ 386x and have not been able to spot it. I have the star listed as 13.2 magnitude but it is surely fainter / variable / too well inside the nebulosity.
The general shape is roundish, somewhat elliptical with a ring structure and a brighter arc in the center.
18 different sketches can be found from http://www.deepsky-archive.com/
/Jake
Jaakko Saloranta - Some basic sketches.../
8" Orion DSE
4" Sky-Watcher
3" Konus RFT
scopethis
Reged: 05/30/08
Loc: Kingman, Ks
Re: NGC 7662 new [Re: Never]
      #2578312 - 08/13/08 06:51 AM
Sorry, my notes indicate that at 200x w/10" SCT no central star was seen.
David Knisely
Reged: 04/19/04
Loc: Beatrice, Nebraska
      #2579590 - 08/13/08 06:36 PM
In my 10 inch, the faint central star takes a *lot* of power (over 350x) and very good steady seeing to come out. Otherwise, it tends to blend into the bright glow of the interior of the inner shell. I have not seen it very often. The nebula itself appears as a nice bluish-green disk at low power, while at high power, it shows two nested oval ring-like features with the inner one slightly off-center and the outer one as more of an enhancement of the outer edge of the nebula. Clear skies to you.
David W. Knisely
Hyde Memorial Observatory
http://www.hydeobservatory.info
Achernar
Reged: 02/25/06
Loc: Alabama, USA
Re: NGC 7662 new [Re: David Knisely]
      #2579727 - 08/13/08 07:54 PM
That has been my experience as well. Unless the seeing's very steady, I do not see the central star of NGC-7662. On two occasions I have in fact seen the central star with my 10-inch during periods of excellent seeing, at 375X through my 3.5mm Orion Stratus eyepiece. It flitted in and out of view, it was faint and hard to make out amid the bright nebula all around it. The oval outer edge and the dark inner zone were also very noticeable.
Taras
10-inch F/4.5 Discovery Dob
6-inch F/8 Homebuilt Dob
4 1/4-inch F/4 Homebuilt reflector
Silicon Owl
Reged: 11/25/05
Loc: Waimea, Hawaii
Re: NGC 7662 new [Re: Achernar]
      #2579964 - 08/13/08 10:39 PM
I have had the same sort of issues with the central star, it is elusive...
27 Aug 2006
TIMPA, Avra Valley, AZ
28cm f/10 SCT Gypsy @ 350x
Beautiful! A distinct light blue color is the first impression, bright! holds magnification well revealing a two shell structure, a bright round inner shell and a quite faint outer shell, no central void, no central star observed even at 350x
27 Sep 2003
Las Cienegas NCA, Pima Co., AZ
46cm f/4.5 Deep Violet @ 175x
Fairly bright, slightly bluish disk, no other detail obvious, averted vision appears to show a star involved with the nebulosity but not centered, the edges of the disk are well defined
Andrew Cooper
Personal Website and CN Gallery
Handmade 18" Dob / NS11GPS / 6" RFT / 90mm APO / TV-76 ...and a twin 10m
"I have loved the stars too fondly to be fearful of the night." --Sarah Williams
5 registered and 3 anonymous users are browsing this forum.
Moderator:  matt, Olivier Biot
Home
