Privacy Policy |
Please read our Terms
of Service | Signup and
AstroRealtor
Reged: 03/26/08
Loc: Terra Firma
I had the little double star in the field of view just to the north and west and maybe it was the sky being washed out by the bright moon, but, I could not for the life of me glimpse that blinking planetary. Perhaps I blinked when it winked?
-------------------- Clear Skies, Jim
Discovering: Messier objects, Deep sky treasures, NGCs, Double stars, & Nebulae of all kinds.
Televue 85 "Polaris" Mount
Custom Crafted Newtonian Dob 8" f7 w/Feathertouch
Celestron Cometron Reflector 114mm f8
Zeiss Diafun 8 X 30 Binos
Zeiss 10 X 56 Binos
Aldrich Astronomical Society
AstroRealtor
Reged: 03/26/08
Loc: Terra Firma
Upon further review, it was probably there all along and I failed to see it for all the reasons I fail to see anything.
1.) I wasn't absolutely sure I was in the right spot. 2.) I saw what I thought was the faintness of a planetary but it was just on the edge of visibility. 3.) I had doubts about whether it would appear at all in a telescope as small as I was using (8") 4.) I was expecting to see something similar to M-57 and when I didn't I momentarily gave up. 5.) I was just practicing for the day I WILL see it. 6.) I was never "supposed" to see it at all, I was just supposed to memorize that area of sky. 7.) The "seeing" wasn't right and I would never have seen it no matter how long I looked.
Zeiss 10 X 56 Binos
calibos
Reged: 11/18/07
Loc: Ireland
Well I had the benefit of Orions Intelliscope system on my Dob, so I knew I was in the right place.
Pfffttt, nothing there, just a star in the middle of the FOV. Must be nearby outside the FOV somewhere.
So I start scanning. All of a sudden as that first star moved to the edge of the FOV and it entered my peripheral vision.....
Hey, that star just got fuzzy!!
I pan back to it...
Nah...its just a star!!
Look to the side of the FOV, that star back in my peripheral vision again....
So thats what they mean!!!
-------------------- Keith D.
Orion SkyQuest XT12i
Moonlite CR Focusser with Rigel motofocus
Brian Reed 'RoundTable' Equatorial Platform
Howie Glatter Holograhic Collimator and Blug
Baader Hyperion 21/32mm,17mm,13mm,8mm,5mm,3.5mm EP
TS 15x70 Binoculars
[img]http://7timer.y234.cn/exe/apanel.php?country=EI&adm=EI31&site=92&en[/img]
stevek
Reged: 04/16/06
Loc: west michigan
Jim, NGC 6826/Blinking is pretty small and may be overlooked as a star in a low power FOV. It IS stellar with a high surf brightness and it doesnt really need filters. Your 8" should nail this one easily and seeing wont affect it. I can pick it up @ 92X/13mm EP readily. For me, its there just as that obvious small little double star moves out of the FOV. This one takes mag well and is less 'blinky' at 150-200X. Good luck & clear skies... Steve
-------------------- DSO 8" f6 DOB w/ 8x50 RACI & 2"Crayford
1958 Sears Discoverer 76mm Refractor
GSO SV 30mm 2",21mm Hyp,13mm Strat,BO/TMB ver2-6mm & 4mm
1.25"Filters: DGM-NPB, 25%ND
1.25" plossls: 25mm,20mm,15mm,9mm
Orion 2X Shorty Barlow
Garrett Gemini LW 11x56mm binocs
BTG-10 4.0mW green laser pointer
"What is that burning in the sky? Tell me y'all..." Jeff Beck/Jan Hammer
AstroRealtor
Reged: 03/26/08
Loc: Terra Firma
Thanks for "weighing in" on this one Steve. You just knew I wasn't going to give up yet. Sometimes its the hardest things to find that are the most worth finding anyway, so I'll keep at it until I get it.
Zeiss 10 X 56 Binos
xfile101
Reged: 12/08/07
Loc: Ocean Gate, NJ
Everything Steve said. This is an easy object for an 8" scope (like mine ) The easiest way to view it is, get in the FOV (the central star is bright so this sound be easy), then once you believe it is in the FOV look DIRECTLY at it, all of a sudden you will see the nebula, then use adverted vision and it goes away, back to directly looking at it and it appears! Quite neat! This planetary kind of goes against all that you have trained you eyes to do and that is ADVERTED vision helps picking up detail, in this case it doesn't, it's the opposite. And once you "train" your eyes to view with adverted vision you have a tendency to do it automatically (without any thought at all) and this is why, IMHO, people tend to miss this one. I love this planetary and I affectionately call it "The Anti-Planetary", for reasons stated above!
-------------------- Orion XT8I
Celestron 114EQ Firstscope
Meade 70mm
Astroscan
Kolenka
Reged: 06/01/08
Loc: Seattle Area, WA, USA
I recently saw the Blinking Planetary for the first time myself and was having issues understanding why it was called the blinking planetary. I was expecting a variable star of some kind in the center.
All I got was a **** nebula that kept disappearing out of my view when my eye twitched.
I didn't strike me that is why it might be called the Blinking Planetary until I read this thread.
-------------------- Meade 10" LX200R
Orion 80ED
Nagler 7T6, 9T6, 13T6, 17T4, 26T5
Canon XSi, TIS DMK 31AF03
Northwest Astro Photoblog
AstroRealtor
Reged: 03/26/08
Loc: Terra Firma
Its a blinker for sure, don't blink for too long, if you do you better learn how to blink in resonance with it!
Zeiss 10 X 56 Binos
Achernar
Reged: 02/25/06
Loc: Alabama, USA
NGC-6826 is small but very bright. Look for a bluish, out of focus star that won't become a pinpoint of light no matter what you do with the focus. That's the Blinking Planetary Nebula. Once found you'll want to use at least 150 or 200X to see it's disk and central star well.
Taras
-------------------- 10-inch F/4.5 Discovery Dob
6-inch F/8 Homebuilt Dob
4 1/4-inch F/4 Homebuilt reflector
proud uncle
Reged: 01/22/07
Loc: Central Texas
I was out looking for this one Sunday night. I used the double star 16 Cygni as a "skymark" to find it. At 62x, I noticed a "star", nearly colinear with the components of 16 Cygni, slightly fainter than either of those components, and roughly equal distance. All other objects in my fov were significantly fainter points of light. I increased the power to 208x. The third "star" near 16 Cygni still appeared as a point of light, not fuzzy, but it did appear to blink off and on several times while the other stars in the FOV remained steady. Does it sound like the third "star" could have been the blinking planetary? I could not see anything else in the fov at either power that appeared to be a likely candidate. Thanks.
-------------------- Kenneth
Zhumell 10" Dobsonian (f/4.9)
2" 32mm WA eyepiece
9mm, 12.5mm, and 20mm Plossls
6mm TMB/BO Planetary
2" 2x ED Barlow
Nikon 10x50 binocular (6.5 deg FOV)
xfile101
Reged: 12/08/07
Loc: Ocean Gate, NJ
Sounds like you may have found it. NGC6826 lies a bit NE of 16 Cygnus but I quite honestly don't know if it is in the same FOV as 16 Cygnus as I don't have the distances from each other and of course what your AFOV is. However, you are for sure in the right area. NGC6826 will appear to "blink" in and out and the central star is easy to see, it's the nebula that "blinks". The central star will appear to have a bluish-grey ring around it then it won't then it will, then it won't. It's very neat
Meade 70mm
Astroscan
