Astrophotography and Sketching >> Beginning Imaging
FoxK
Reged: 11/07/07
Loc: Cape Cod, MA
Registax..handpicked vs auto stacked results here!
      #2580810 - 08/14/08 11:47 AM
Hi all....
Thought I might post a pictorial of the difference hand picking subs can do. People may wonder if its worth the time and effort, i'll let your eyes determine that. This first image is quality set to 90%, gradient method used for alignment. Of 600 subs, registax picked 422. The subject is the Sun taken with a BF600 Lunt CaK blocking filter on an 80mm ED APO scope with a DMK monochrone cam
Next is the same subs, though handpicked through the 600 subs. I took around 250-350
10 best registax subs stacked:
In my opinion, Registax does a pretty good job of selecting frames for stacking but by no means is perfect. It can save time when you have 2000 subs lol. But hand picking subs in a practical number of under 500 subs can be done relatively quickly and provides a substantial improvement in sharpness.
Hope this helps someone
Orion 80mm ED Apo Refractor
8" Classic Dob (used as Newtonian on CG5 mount)
Meade 70-AZ-A 70mm Guider using PHD
LS60TCaK/B600/C
CG-5 Advanced GT Mount
Nikon D40x with T-Adaptors
Philips SPC900NC
Imaging Source DMK 21AU04.AS
Dome=the box my mount came in so I can see my solar images in bright sun lol
- click for cloud prediction for Plymouth, MA. area
kmsu
Vendor / Maxvision
Reged: 02/25/08
Loc: Maxvision Kunming Yunnan China
Re: Registax..handpicked vs auto stacked results here! new [Re: FoxK]
      #2580822 - 08/14/08 11:56 AM
I am generally between 1600-800
The target is different and the amount is also different
And strictly choose a single piece quality, is a key
maxvision Club
kmsu@163.com
MEADE ED127 F7.5
maxvision ED102 F7
MEADE ED80 F6
maxvision Maksutov-Newtonian 152 F4.8
LXD75 mount
JE160 mount
JE120 mount
K3 mount
Canon 5D
Canon 350D
Nikon D70s
SBIG-STV
FoxK
Reged: 11/07/07
Loc: Cape Cod, MA
Re: Registax..handpicked vs auto stacked results here! new [Re: kmsu]
      #2580847 - 08/14/08 12:12 PM
I think it would help if I learned how to make the best frame the reference frame...I see an option for that but how to do it is not very user friendly
Any tips?
LS60TCaK/B600/C
Philips SPC900NC
kmsu
Vendor / Maxvision
Reged: 02/25/08
      #2580865 - 08/14/08 12:20 PM
H'm, this I agree with!
Registax software at I/O interface up, really have an inconvenient place
The raw recruit isn't easy to control
Hey Hey, this is also let everyone have a target so research of opportunity
^__^
maxvision Club
kmsu@163.com
MEADE ED127 F7.5
maxvision ED102 F7
MEADE ED80 F6
LXD75 mount
JE160 mount
JE120 mount
K3 mount
Canon 5D
Canon 350D
Nikon D70s
SBIG-STV
kmsu
Vendor / Maxvision
Reged: 02/25/08
      #2580883 - 08/14/08 12:27 PM
Suggest raw recruit
The default constitution of software can attain a simple target
Cautiously choose a good single piece a picture
Can raise quality
However.......Take a lot of time....
^_^
maxvision Club
kmsu@163.com
MEADE ED127 F7.5
maxvision ED102 F7
MEADE ED80 F6
LXD75 mount
JE160 mount
JE120 mount
K3 mount
Canon 5D
Canon 350D
Nikon D70s
SBIG-STV
FoxK
Reged: 11/07/07
Loc: Cape Cod, MA
      #2580903 - 08/14/08 12:36 PM
Thanks Kmsu
LS60TCaK/B600/C
Philips SPC900NC
kmsu
Vendor / Maxvision
Reged: 02/25/08
      #2580934 - 08/14/08 12:50 PM
Good evening!(Xi Xi, I am here already dead hour)
Go to bed................
maxvision Club
kmsu@163.com
MEADE ED127 F7.5
maxvision ED102 F7
MEADE ED80 F6
LXD75 mount
JE160 mount
JE120 mount
K3 mount
Canon 5D
Canon 350D
Nikon D70s
SBIG-STV
snowdragonusa
Reged: 09/04/07
Loc: Denver, CO
      #2580966 - 08/14/08 01:01 PM
Try this...
1. After doing and initial alignment be sure to move the slider all the way to the right. This will include ALL frames. They will be sorted but we want to include everything. The initial sort can be thought of as sorting everything to make a good reference frame... which is just what we will do now.
2. Press the LIMIT button. Create a reference frame stack of about 50 frames. Registax will take the first 50 frames which it previously sorted and assumes are the "best" for now.
3. Once the reference frame has been stacked, apply a very slight wavelet to bring out just a little detail. Don't over do it at all. Click "Apply All" and then "Continue".
4. Now you will click "Optimize" so all the frames in your list will be sorted against the newly created reference frame.
5. Once the optimization is complete GO BACK to the Align tab. Move the slider so that you include about 3/4 of the total frames. Click "Limit".
6. Create a new reference frame (same number of frames) "apply all" the SAME wavelets (don't change the values) and "continue". Click "Optimize".
7. Once it is complete... repeat by clicking the align tab again, move the slider to include about 1/2 of the total frames (the frame list you see here is the total frames NOT the limited frames you were just working with). Click LIMIT and go through creating a new reference frame again.
Once you have at least 400 to 600 frames in your limited list then it is time to think about stacking. Before you do the stack though, run one more optimization run but this time also run either your resample or drizzle. Once this is complete you can stack.
Basically what you are doing in all these previous steps is to continually take the first 50 frames which Registax says are the best and use them to sort (optimize) the next set. Every time you create a new reference frame the program fine tunes the order of 'best' frames. This routine should help give you a sharper image. Keep in mind that the total number of frames stacked can have a substantial impact on sharpness and resolution as well.
Here in Colorado we either have the Jet stream right over head or we have turbulence coming off the mountains so seeing is ALWAYS horrible. I have never seen a clear diffraction ring when trying to collimate.
Hope this helps! See if it works for you.
Adam
12" LX200R
AT80mm piggyback
DSI Pro, DSI-C, LPI
Denver Astronomical Society
Brighton Astronomical Group
FoxK
Reged: 11/07/07
Loc: Cape Cod, MA
Re: Registax..handpicked vs auto stacked results here! new [Re: snowdragonusa]
      #2580987 - 08/14/08 01:08 PM
I'll give it a try Adam...thanks for the tip
LS60TCaK/B600/C
Philips SPC900NC
jay52
Reged: 09/26/04
      #2581397 - 08/14/08 03:56 PM
Now, to continue the experiment, pick the best ten images...or just enough to give you good S/N. Process it, post it. Let's see the difference.
jay
www.allaboutastro.com
NyxAither
Reged: 09/11/07
Loc: Arlington VA
Re: Registax..handpicked vs auto stacked results h new [Re: jay52]
      #2581554 - 08/14/08 05:01 PM
I did a quick reprocess using Snowdragon's method, here it is:
Processing Comparison Thread
Thomas
✸Orion XT8i✸Orion 80-T✸CG5 GT Mount ✸Meade DSI II Color✸Meade DSI (THANKS TODD N!!!)✸Orion 4.5" Reflector OTA✸Trusty Mac Powerbook G4✸1960's Gilbert 3" telescope✸10x50 binoculars✸SPC900NC✸
..::*~*Clear Skies*~*::..
snowdragonusa
Reged: 09/04/07
Loc: Denver, CO
Re: Registax..handpicked vs auto stacked results h new [Re: NyxAither]
      #2581608 - 08/14/08 05:29 PM
Thaat is awesome Nyx! Now run the final stack (unprocessed or stretched) through PixInsight or PS. You should also se post processing improvements as well.
Cheers!
Adam
12" LX200R
AT80mm piggyback
DSI Pro, DSI-C, LPI
FoxK
Reged: 11/07/07
Loc: Cape Cod, MA
Re: Registax..handpicked vs auto stacked results h new [Re: snowdragonusa]
      #2582294 - 08/14/08 11:29 PM
Added the image using registax's best 10 subs to the original post..had to use slightly less wavelets however. Seems to have a greater effect when you use only a few subs.
Good suggestion trying 10....i thought that'd be too few but I think it looks the best of all 3
LS60TCaK/B600/C
Philips SPC900NC
jay52
Reged: 09/26/04
Re: Registax..handpicked vs auto stacked results h new [Re: FoxK]
      #2582466 - 08/15/08 01:48 AM
Nice! I knew the DMK was a pretty clean camera, and it's not as if the sun is all that dark. Taking the best frames to the point where you are satisfied with the S/N will always be the best way. Why stack 1000 frames when the best handful will do the job?
jay
snowdragonusa
Reged: 09/04/07
Loc: Denver, CO
      #2582640 - 08/15/08 07:16 AM
Nice work Fox!
Adam
12" LX200R
AT80mm piggyback
DSI Pro, DSI-C, LPI
5 registered and 5 anonymous users are browsing this forum.
Home
