tigerroach
Reged: 08/13/08
Loc: Houston, TX
So if I were to upgrade my Canon 10x30 IS...
      #2581470 - 08/14/08 04:24 PM
...to the 10x42 or the 15x50, should I expect a more sophisticated stabilization gizmo? Or would it mainly be a question of more aperture?
BTW, by "upgrade" I really mean "get new binocs in addition to the old ones." Because I love the 10x30s and won't be getting rid of them.
Brian
TeleVue TV-102, Gibralter alt-az mount
Webster 14.5" f/4.3 truss dob *under construction*
Canon 10x30 IS binocs
Joe Ogiba
Reged: 02/14/02
Loc: NJ USA
Re: So if I were to upgrade my Canon 10x30 IS... new [Re: tigerroach]
      #2581505 - 08/14/08 04:40 PM
I have the 8x25 IS,10x42L IS, 12x36 IS II , 15x50 IS and the 10x42L & 15x50 have a 5 minute timer on the IS button when you press it once. If you plan on keeping the 10x30 IS then it's a no brainer to get the 15x50 IS.
Pentax PF-80ED
Meade 102ED APO
Orion EON 72
120ST
Apex 127
C6 XLT
CR150
C9.25
XT10
Zeiss 7x42 FL
Canon 10x42L IS WP
15x50 IS
12x36 IS II
Garrett Optical 28x110 HD-WP Signature Series
Oberwerk BT-80 45
Apogee RA-88-SA
Denk II Power x Switch binoviewer w/13mm Ethos, 20mm Pentax XW's, 20mm Widescan III's.
Les
Reged: 04/22/06
Loc: Maryland
Re: So if I were to upgrade my Canon 10x30 IS... new [Re: Joe Ogiba]
      #2581806 - 08/14/08 07:12 PM
Same IS technology. The 10x42 is also waterproof if that is of use to you.
Les
Canon 10x42L IS
Oberwerks BT80/45, Helix Hercules mount on Oberwerks Standard Tripod
Swift 8x44ED Ultralite
Questar 50th Anniversary Model, 501 head on Manfrotto 475 tripod
Stellarvue SV90T 90mm Fluorite refractor Bogen 3236/Televue Tele-Pod Head
Questar 7 Astro
Vixen GP-DX on Baader Surveyor Tripod
tigerroach
Reged: 08/13/08
Loc: Houston, TX
Re: So if I were to upgrade my Canon 10x30 IS... new [Re: Les]
      #2581838 - 08/14/08 07:26 PM
Thanks for the replies gents. If the IS is basically the same I can hold off for a while. At least until I buy my new scope, heh heh.
The 5-minute timer sounds like a nice feature, but not enough to make me pull the trigger.
Brian
Tony Flanders
Reged: 05/18/06
Loc: Cambridge, MA, USA
      #2581900 - 08/14/08 07:57 PM
Same IS technology.
Are you sure about that? The stabilization on the 15x binoculars seem much more aggressive than on the 10x30s. More of a "lock on hard" feel. Also seems to chew through batteries faster. But I've never studied this carefully, so I can't vouch for either fact.
Tony Flanders
eyeglasses
6x15 and 8x32 monoculars
8x25, 7x35, 10x30 IS, 10x50, and 15x70 binoculars
70mm and 100mm achromatic refractors
4.5", 7", and 12.5" Dobs
Les
Reged: 04/22/06
Loc: Maryland
Re: So if I were to upgrade my Canon 10x30 IS... new [Re: Tony Flanders]
      #2582855 - 08/15/08 10:27 AM
Tony,
By same technology, I meant no more than the use of vari-angle prisms. I wouldn't doubt that the gains in feedback circuitry may be different for different magnifications and capture angles. But I suspect that only the Canon engineers would know those details.
Les
Canon 10x42L IS
Questar 7 Astro
doctordub
Reged: 01/11/06
Loc: New Rochelle, New York
      #2584728 - 08/16/08 10:01 AM
I use the rechargeable sanyo Eneloop batteries. They are 2000mAh AA batteries I first used in the camera flash. They hold their charge longer and have more capacity.
Jonathan
TeleVue TV102 on Vixen SXW mount
Meade LXD 55 SN10/UHTC Modified
Jason 60mm F11
Canon 15x50 IS
Olympus E-510, 14-42, 40-150 Zuiko
Meade DSI, LPI
TeleVue:
Binovue & 2X Cor.
3x barlow, 2x 5mm, 2x7mm,
12mm, 17mm & 2-4mm Zoom Naglers,
2x24mm, & 27mm panoptics,
55mm Plossl & 3mm Radian
2" OIII & Nebustar filters
Siebert Power Mag wheel
Lumicon Filter selecter &
2" focal reducer
Celestron: 7 1.25" color filters
7.5mm, 26mm eps & 2X ultima barlow
7 registered and 13 anonymous users are browsing this forum.
Moderator:  EdZ
Home
