Privacy Policy |
Please read our Terms
of Service | Signup and
coutleef
Reged: 02/21/08
Loc: Montreal and St-Donat, Québec,...
Just to add, i do not consider TV plossls as cheap EPs. They are great plossls and perhaps a smaller number of elements does not hurt in some situation.
On planets, my plossls are sharper than the naglers or pan (i compared the pan 15 and plossl 15 this spring and there was a difference).
Plossls still have a place in our EP case
-------------------- François
Nexstar 8 SE
50mm StellarVue finderscope, Astronomik UHC-E and Orion OIII filters
WO Swan 40mm; TV Pan 22mm; TV Nagler 9T6, 12T4, 17T4; TV Plossl 11mm and 15mm.
WO 2" dielectric diagonal retrofitted with Denk Power Switch (and now reach the zenith with the shorty adapter).
tcat
Reged: 06/02/08
Loc: Va. USA
Thank you for your observations, Francois. I have noted in my Nexstar 6 SE that you can quickly run out of light when you start stacking glass elements, in my case using barlows. I am sure the Pans and Naglers excel in larger aperture scopes and fully justify their higher costs. It would be interesting to see a comparison of Baader Hyperions and Televue Plossls in a 6" or 8" cat when viewing planets and faint fuzzies. Same price range but differing fov's and number of elements. Both get rave reviews here.
Clear skies, Tom
-------------------- NexStar 6 SE
Orion 80mm ShortTube
Garrett Gemini 15X70 LW
Rick Woods
Reged: 01/27/05
Loc: Inner Solar System
I'd like to throw in my 2 cents (seen many times elsewhere): Good eyepieces are good eyepieces! My eyepiece box is filled with Naglers + 2 Meade S4000 UWAs, collected over a period of years. I had it made: the best of the best! That is, until I got a set of Brandon eyepieces. These are so dramatically better in contrast and sharpness, that since I got them last January, I've hardly used the Naglers at all. A whole box of beautiful, expensive glass, sitting unused.
So, money spent on top-quality eyepieces is NEVER wasted, no matter what your scope. Better in a fast scope = better in a slow scope. If you're really serious, don't spend any money on "these are probably good enough" eyepieces. They're not! Get the best you can afford, and scheme for better down the road. It really does matter.
-------------------- - Rick
14" LX200GPS
8" Meade 826C
12 registered and 13 anonymous users are browsing this forum.
Moderator: Jason B
