Privacy Policy |
Please read our Terms
of Service | Signup and
refractory
Reged: 02/05/05
Lets suppose I've got an optical flat made from optically clear glass, made elliptical for use at 45 degrees, mirror-coated but with an elliptical uncoated spot in the center. If both faces of the flat are parallel, and the flat is relatively thin, then I shouldn't lose too much light to transmission, but what about reflection? Will antireflection coating on the unmirrored spot help, or is the angle too steep?
Jess Tauber
DAVIDG
Reged: 12/02/04
Loc: Hockessin, De
It depends on the refraction index of the glass to get an exact number but a good estimate will be that the glass will reflect about 5% of the light and transmit about 95%. AR coating will increase it around 98%.
- Dave
-------------------- Homemade 'scopes 8"f/7,6" f/5", 6"f/4, 4.25" Schief. 60mm Coronagraph,60mm H-alpha system, 4.25" White-light Solar Newtonian,solar spectroscope, 4.5" f/16 Schupmann Medial refractor, 14 Stellafane awards 7 in optics
Engineering = Taking what you have and making what you need.
John Carruthers
Skiprat
Reged: 02/02/07
Loc: Kent, UK
Try putting a clear piece of glass in front of your secondary, you'll get a double image, the same may happen with any parallel unsilvered glass. A small angled between the faces will take care of the reflected double image, like a Herschel wedge.
-------------------- Jc
ATM 10" F6.1, 1/25th wave spec (max wavefront error +/- 1/12.6 in zone 4 of 6, sodium light )
6" F7 spec
127mm F9.4 Refractor
10 x 50 bin
ETX80 (finder)
Canon 20D
and a curious mind
Ed Jones
Reged: 04/06/04
Loc: Sin-sin-atti
I'm not sure what you are doing here. If you have an unsilvered spot on your diagonal it won't see any light on axis anyway, only off axis light. Are you meaning to transmit through this spot? It will be astigmatic.
-------------------- Ed Jones
7 registered and 3 anonymous users are browsing this forum.
Moderator: Don W, Joe Cipriano
