Announcements and News >> Beginners Forum
WNCAGC
Reged: 06/25/08
Loc: NC Mountains (God's country)
Fingerprint smudge on corrector plate new
      #2581398 - 08/14/08 03:56 PM
How do you guys clean isolated smudges on a corrector plate?
I have researched on the net to find the best way with either cleaners and other forms that are safe or so called safe for coated optics.
What is best? Could one use ROR for isolated smudges from oils in the skin?
CPC 1100 XLT "The Big Monster"
Power Tank 17
NexImager
2" Smart Astronomy 10:1 dual speed Crayford focuser
2" Smart Astronomy Dielectric diagonal
2" Smart Astronomy 2x Barlow
2" Baader SCOPOS 35 mm prototype EP
Baader Hyperion zoom EP 8-24mm
Celestron dew shield
Bob's Knobs
panhard
Reged: 01/20/08
Loc: Markham Ont.
Re: Fingerprint smudge on corrector plate new [Re: WNCAGC]
      #2581422 - 08/14/08 04:07 PM
Yes ror stands for residule oil remover. I got that info when chatting with the distributor for Canada. I use it.
Orion xt10i
8 & 17mm Hyperion eye pieces
koning 32mm 25mm skywatcher eyepieces
lumicon 0111 & antares variable polarizing filters
12x50 binos
A love for this hobby
"What goes around comes around."
"She who must be obeyed."
Herb c
cloudy nights my # 1 site
43.53°n 79.17°w
Brooklyn
Reged: 07/24/08
Loc: Central New Jersey
Re: Fingerprint smudge on corrector plate new [Re: panhard]
      #2581565 - 08/14/08 05:06 PM
I don't think its necessary to remove that unless its completely ruining your images, which is impossible.
The corrector plate is the most insignificant part of the optical chain. It can be the dirtiest compared to other parts before it needs cleaning.
The rule of thumb Ive heard is that the closer it is to your eyepiece lens, the higher chance it might degrade your image.
I was viewing with my baader hyperion 5mm last week and a tiny drip of sweat, or maybe some saliva out of my mouth, fell onto the baader hyperion eyepiece lens! I didnt even bother touching it. The less i clean my optics, the better.
People tend to do more damage to their optics by cleaning them, rather than leaving the dirt and grime on it.
Look at my thread that on the Cats forum...notice how grimy my corrector plate is, yet my images are always perfect. Even faint DSOs appear fine.
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/2579430/page/0/view/collapsed/sb/5/o/all/fpart/1
Meade 8.25"(209.55mm) LX-90 EMC (SCT)
Albert Einstein =>
“Intellectual growth should commence at birth and cease only at death.”
“If you can't explain it simply, you don't understand it well enough.”
Edited by Brooklyn (08/14/08 05:07 PM)
Starman1
Vendor - Scope City
Reged: 06/24/03
Loc: Los Angeles
Re: Fingerprint smudge on corrector plate new [Re: Brooklyn]
      #2583382 - 08/15/08 03:08 PM
The fingerprint can be easily cleaned off using a couple Q-Tips and a lens cleaner (I like ROR, too, but others work fine).
Carful! After you've cleaned this small section, the rest of the corrector will start to look dirty, and you'll end up cleaning the whole thing!
Don Pensack
12.5" Truss Dob, 5" Maksutov
Sustaining Lifetime IDA member, TeleVue junkie
WNCAGC
Reged: 06/25/08
Re: Fingerprint smudge on corrector plate new [Re: Starman1]
      #2583399 - 08/15/08 03:19 PM
That is what I am afraid of!
Power Tank 17
NexImager
Bob's Knobs
BluewaterObserva
Reged: 05/18/04
Loc: Zuni Mtns, NM
      #2583421 - 08/15/08 03:36 PM
My advice? Never ever look at your corrector plate.
Midnight Dan
Reged: 01/23/08
Loc: Brockport, NY
Re: Fingerprint smudge on corrector plate new [Re: BluewaterObserva]
      #2583905 - 08/15/08 08:38 PM
I would not leave the fingerprint on there. There are acids in the finger oils that will attack the fragile coatings over time.
Here's a good article on how to make your own very inexpensive but effective fluids, and how to clean the corrector without damaging it.
http://www.arksky.org/asoclean.htm
I've used this system and can vouch for it. It's easy and it works! You don't want to clean your corrector often, but this might be a good excuse to clean the whole thing and get that fingerprint off.
-Dan
Scopes: Celestron NexStar 8, Orion EON 72mm ED/APO on Astroview mount (EQ3)
Eyepieces: Celestron 40mm, 25mm, Baader Hyperion 13mm, 8mm, 5mm
Other: Telrad, 2x Barlow, 0.63x Focal Reducer, Dew-not strips, DewBuster controller
Brooklyn
Reged: 07/24/08
Re: Fingerprint smudge on corrector plate new [Re: Midnight Dan]
      #2583926 - 08/15/08 08:47 PM
I would not leave the fingerprint on there. There are acids in the finger oils that will attack the fragile coatings over time.-Dan
Dan i think that is an old wives tale, or urban legend that no longer applies to modern coatings.
I have heard the exact same thing, that acids from eyelashes or fingerprints can eat through the multicoated layers on the glass.
Luckily, this is nowhere near true anymore. I called meade tech support several times, and spoke to 3 completely different people. They all told me that this doesn't happen ever since the late 1990s, when they started using very strong multicoatings. (these coatings are actually thin layers of metal after all).
Even Al nagler, the founder of televue said that all telescope optics can be carefully cleaned with regular plain old windex and distilled water.
If you can let windex touch all of your optics, greasy fingerprints or eyelash oils wont do squat.
I have about 4 different finger prints and a layer of dust on my corrector plate that are over a year old, and it still does absolutely nothing to my images or light gathering capability.
You are doing far more damage to your optics by actually cleaning them, than by letting the dirt stay there forever. Now, a few finger prints and some dust wont do anything to your images. However if there are fingerprints, dust, pollen, and a THICK layer of dirt on your corrector plate...only THEN might you start noticing some light fade.
But this above scenario requires 100s of observations in dirty environments for long periods of time, with no dusting or cleaning.
The most i ever do to my optics is dust them with a blower bulb, or kick off some specs using a synthetic brush. Other people also use camels hair brush, it works just as good.
And using these two methods, i have never scratched any of the optics so far.
I will only liquid clean my optics when they become unbearably dirty, as i want to have as much longevity from my optics as possible...and the consensus between all the telescope professionals Ive spoken to, is to clean your optics almost never (liquid wise).
Albert Einstein =>
JAT Observatory
Space Freak
Reged: 02/20/05
Loc: Eastern PA
      #2583996 - 08/15/08 09:20 PM
I don't believe in leaving my corrector plate or optics dirty. I have always cleaned my glass on a regular basis and all my coatings are fine.
-Marcus
The problem with free speech is even the stupid have a voice.
http://jatobservatory.org
12" LX200R on a Paramount ME
Midnight Dan
Reged: 01/23/08
Loc: Brockport, NY
      #2584779 - 08/16/08 10:29 AM
Hmmm ... interesting information!
On the one hand:
>> ... strong multicoatings. (these coatings are actually thin layers of metal after all).
Yes the newer coating are stronger than they used to be. But metals are very susceptible to damage by acids and organic compounds such as are in fingerprints. And they are only a few atomic layers thick. Strong is a relative term and as you pointed out, you should not clean very often because of potential damage.
Windex is a mild solvent that is specifically designed to clean glass and has a very different chemical composition than fingerprints so I don't think the comparison is really meaningful. Also, the Windex is removed during cleaning and any small remaining amount will evaporate. Fingerprints, on the other hand, will linger for a very long time allowing any potential damage to occur over time.
>> and the consensus between all the telescope professionals Ive spoken to, is to clean your optics almost never...
I absolutely agree. This sentiment is echoed in the article I referenced by Dr. Clay of the Arkansas Sky Observatory. But as he and others point out, there are times when you do need to clean. Fingerprints are one example, pollen is another - again because of the claimed damage to the coatings. I recently cleaned mine because of a significant layer of pollen. This was not having an effect on my viewing, but I wanted to protect the coatings. Using the extremely careful techniques outlined by Dr. Clay, it worked very well.
On the other hand:
>> I called meade tech support several time ...
One would think that the people at Meade and other scope vendors should know what they're talking about so this certainly lends credence to your statements.
It is true that rumors and old wives tales can be around for so long that everyone just considers them to be "common knowledge" without any facts to back them up. I spent some considerable time on the internet investigating this after reading your note. I found several reputable sources, optics manufacturers, observatories, etc. that warn about fingerprints containing acids or organic compounds that can damage coatings. But, that still doesn't mean that they have actually done the research to back that up. It's entirely possible, in fact likely, that they are just repeating what is "common knowledge".
I was completely unable to find any research done on the direct effects of fingerprints on modern (or even older) optical coatings.
The information I found is more general in nature. First, what exactly is in a fingerprint when people refer to acids or organic compounds? It seems that it's basically a mixture of sweat and sebum, the fatty substance that is produced by the sebaceous glands. Since sweat is mostly water, when it evaporates it leaves behind small amounts of organic substances such as chlorides, ammonia, uric acid and urea. In fingerprints, the fats provide for a relatively stable substance that will not evaporate and will resist cleaning except with solvents. It also serves to hold the other organic compounds mixed with it in place where they can do damage over time. And it provides a substrate for bacterial growth (that's why sweat smells) which can also damage surfaces.
Another source of information is my wife. She is a metallurgist that spends her days looking at damaged and corroded surfaces using optical and electron microscopes, and analyzing contaminants with and x-ray analyzer and Fourrier Transform IR Spectrometer.. One of the primary sources of surface corrosion that she sees is compounds containing chlorides such as can be found in fingerprints. She is always complaining about people providing her samples that are covered with fingerprints since that contaminates and damages the samples. These samples are primarily metals such as are found in the optical coatings we're discussing.
So does this mean fingerprints are a problem? Not necessarily. If the coatings are specifically designed to resist the particular compounds in fingerprints, then they should be alright. But I would guess that it's difficult enough to engineer coatings that have the desired optical characteristics without having to include resistance to organic compounds as an additional requirement.
This is a really interesting topic to me (although I'm probably boring everyone else :-) and I'd love to see some real research on the topic if someone can dig some up.
For me, I'm still planning on keeping fingerprints off my optics as much as possible, and cleaning them (very carefully and very infrequently) if they accidentally get on there.
-Dan
Starman1
Vendor - Scope City
Reged: 06/24/03
Loc: Los Angeles
Re: Fingerprint smudge on corrector plate new [Re: JAT Observatory]
      #2584823 - 08/16/08 10:56 AM
I'm with you. There's no need to be paranoid about cleaning. I have 20 year old eyepieces that have optical surfaces that look just like new despite being cleaned scores of times. And I inspect the surfaces for contaminants using a 20X Hastings loupe.
If the surface is broadband anti-reflection coated, it can be easily cleaned without fear of damage.
Additionally, nearly every corrector plate on an SCT over 3 years old has a haze on the inside, and needs to be cleaned there as well as outside. It's sort of like washing your car and not cleaning the inside of the windows. I've cleaned an occasional SCT where the inside was literally fogged over after a few years.
Causes can be outgassing of grease and paint inside the tube, or simply environmental contaminants like cooking vapors.
Don Pensack
fastrudy
Reged: 04/09/06
      #2585107 - 08/16/08 01:21 PM
I would not think that a fingerprint smudge (and the possibility of reactions from a fingerprint smudge) would seriously degrade image quality. Before shipping my scope off to repair (for an unrelated problem) my collector plate was filthy with pollen and dust that had adhered to the dew on it. I don't think the image suffered at all. It came back from Meade perfectly cleaned, although I could not detect a better image. IIRC, a disgruntled employee at Mt. Palomar shot the primary mirror (with a 30-06?) and the embedded bullets did not affect image quality.
ToeMoss
Reged: 09/18/05
Loc: Jacksonville, Florida
      #2585818 - 08/16/08 10:32 PM
Wow, remind me never to look through your glass.
Edited by ToeMoss (08/16/08 10:33 PM)
dirkdentry
Reged: 12/10/07
Loc: Jackson, TN
Re: Fingerprint smudge on corrector plate new [Re: fastrudy]
      #2585843 - 08/16/08 10:52 PM
please tell me where i can read about this, i think thats grounds for a killin !
8" Meade Starfinder (still on dob mount - for now)
Meade ETX 80
Canon Rebel 300D DSLR
FINE! West Tennessee Weather .... humidity sucks!
Jim Rosenstock
Reged: 07/14/05
Loc: MD, south of the DC Nebula
Re: Fingerprint smudge on corrector plate new [Re: dirkdentry]
      #2585856 - 08/16/08 11:07 PM
Here ya go:
http://www.astr.ua.edu/keel/telescopes/mcdonald.html
QUESTION AUTHORITY!
"errr....sez who??"
Raven911
Reged: 03/12/05
Loc: New Mexico
Re: Fingerprint smudge on corrector plate [Re: Jim Rosenstock]
      #2585889 - 08/16/08 11:41 PM
I have to clean my optics. The desert dust storms out here in NM will leave them coated with crud in no time. I mean really coated. No matter where you store them.
I ran into your problem once. Only it was due to a misdirected sneeze. Got all over my brand new corrector plate. To this day I am still paranoid about it when I see it. It did not seem to affect the image though.
http://smg.photobucket.com/albums/v287/Raven911/Astrophotos/
http://www.eye-of-the-raven.blogspot.com/
Celestron SC6
IM M66 Mak-Newt
100mm F6/76mm F4.5/80mm F5/SV NHII 80mm F6 Achros
SBIG ST7/Canon 300D/DSI Pro Mono/Starshoot DSCI
8 inch F7 Newt on Edmund EQ
8 inch F4.5 Project Astrograph
4 registered and 6 anonymous users are browsing this forum.
Moderator:  miniventures, desertstars, werewolf6977, dgs©, ClownFish
Home
