Privacy Policy |
Please read our Terms
of Service | Signup and
rodelaet
Reged: 04/28/06
Loc: 50°56' N - 4°58' E (Belgium)
M22, in the constellation Sagittarius, can easily be found at two and a half degree NE of Lambda Sgr. This fine globular cluster shines with a magnitude of 5.1, making it one of the five brightest and largest globulars at all. The reason is that M22 is only 10,400 l-y away. M22 would be more famous if it did not have such a low declination.
M22 appears fairly large in my 15x70. The granular core is non stellar and shows a somewhat triangular or fan shape. Its N and E edge are more distinctly visible against the fainter halo. A few pinpricks show up near the edge of the fading halo. But these might be foreground stars.
Site : Andratx, Mallorca, Spain ( 39° N ) Date : July 28, 2008 Time : around 00.15UT Binoculars : TS 15x70 Marine FOV: 4.4° Filter : none Mount : Trico Machine Sky Window Seeing : 3/5 Transp. : 4/5 Sky brightness : 21.08 magnitudes per square arc second near zenith (SQM reading). Nelm : 6.5 Sketch Orientation : N up, W right. Digital sketch made with Corel Paint Shop Pro X2, based on a raw pencil sketch.
(Note: if the sketch does look too dark on your monitor, try to darken the room.)
-------------------- Rony
My Astronomical Sketches
My Binocular Sketches
Callibrate your Monitor with this little strip.
Reged: 06/13/06
Loc: Illinois
Rony,
A stunning rendition of this great globular cluster in Sagittarius. As you have written this would be an even more magnificent sight if it were more overhead. Nevertheless a most impressive wide field binocular drawing. This was the first object in Sagittarius I saw through a "large"( 4.25") reflecting telescope many, many years ago. I saw it about the way you have drawn it here but not with the wonderful wide field of view. Great work Rony, I can only hope you have many more to go.
Frank
-------------------- my gallery
xfile101
Reged: 12/08/07
Loc: Ocean Gate, NJ
Man, I'm loving these binocular sketches! What can I say that hasn't been said a hundred times over..........EXCELLENT!!!
-------------------- Orion XT8I
Celestron 114EQ Firstscope
Meade 70mm
Astroscan
rodelaet
Reged: 04/28/06
Frank and ... Frank,
Your kind words are much appreciated.
Moderator: Charlie Hein, cildarith
