Privacy Policy |
Please read our Terms
of Service | Signup and
EricJD
Reged: 07/24/07
Loc: Chesapeake VA
Anyone have any idea as to what may be causing these black smudges?
I adjusted the image to make them more visible.
-------------------- Orion 120mm @ f5
Nils_Lars
Reged: 01/04/08
Dust motes?
Maybe use some flats to get rid of them.
-------------------- Erik
Orion ED 80
Orion Atlas GOTO mount
Williams Optics reducer
Various eyepieces and other gear
Baytronix 80mm guidescope
Orion Starshoot Autoguider
PHD guide
Canon 400D (unmodded)
Stilleto Focuser
NexImage webcam
http://home.comcast.net/~eriknlarsen/site/?/photos/
jgraham
Reged: 12/02/04
Loc: Dayton, Ohio
Yep, dust on the CCD or filter near the CCD. A careful cleaning should get rid of most of them. Applying flats will also help. Also, if you have a bit of tracking drift using median combine may reduce them.
-------------------- -John
Homebuilt scopes from 4.25-16.5"
Meade LXD75-N6/SN6/SC8, DSX-90, ETX-60BB, ETX-125PE, DS-2130
Orion StarBlast, BinoViewers, Coronado PST
Rebel XT/XTi, DSI Pro (I & II), DSI, LPI, Electronic Eyepiece, Phillips SPC900NC
Tasco 60mm Refractors
EricJD
Reged: 07/24/07
Loc: Chesapeake VA
Thanks guys, will clean the CCD and see what happens. I believe for a DSI pro a Q-tip with rubbing alcohol is the way to clean it?
jgraham
Reged: 12/02/04
Loc: Dayton, Ohio
I use a dry cotton swab and a puffer bulb to clean mine. I thought the documentation did recomend an alcohol as a cleaning solvent, but I'd check just to be sure.
RandallK
Reged: 11/10/06
Loc: Nanaimo, B. C. Canada
Give it a blow before using any liquid (isopropyl). It should work free.
-------------------- Scopes: Meade SC-8AT w UHTC
SkyWatcher 5" F/5 Reflector
SkyWatcher 127mm MAK
Mount: HEQ5 Pro
Cameras: Orion Starshoot DS Colour Imager V.1
Imaging Source Webcam DMK21AU04.AS
Palm TX PDA w Astromist and Bluetooth wireles control.
4 registered and 5 anonymous users are browsing this forum.
Moderator: Charlie Hein, knuklhdastnmr
