Privacy Policy |
Please read our Terms
of Service | Signup and
Bart
Reged: 05/28/06
Loc: Inside the (DC) Beltway
Loose Panoptic barrel
I just bought a 19mm TV Panoptic today and when I got home the barrel was extremely loose. Is that normal and will I somehow damage it by tightening it? Does the fact that it was loose mean that the lenses are also loose or are the lenses separately held in place whether or not the barrel is loose? After the money that I just spent this really has me concerned.
Bart
-------------------- Mead 12" LightBridge
Orion 127mm Mak
Orion 80ED
Orion Short Tube 80
Baader Hyperion 3.5,5,8,13,17,24mm
Baader Hyperion Aspheric 31mm
Orion Sirius 25mm
Celestron Plossl 4,6,9,15,32mm
Orion UltraView 10x50
Canon XTi
My two eyeballs
ErnieM
Reged: 06/13/04
Loc: Phoenix,AZ
Hand tighten it,shake it.If there is no rattle noise it should be fine.
-------------------- Ernie
DSH8/ Crayford focuser
ST80 with 2" focuser on Astroview mount
7XL,10LX,13t6,17LX,22LVW,27 Pan,TV 32,SWA 26 & 38mm,TMBs,UOs,Sratus,and Viven 8x24 Zoom.
9x63 binos
AZStarGuy
Reged: 05/05/08
Loc: Scottsdale AZ
Yep - do that. If it happens to rattle afterwards, that means the retaining ring is slightly loose too. Turn the EP upside down on a table, unscrew the barrell and hand tighten the ring inside. It doesn't take much. My 24 Pan was loose from shipping. 1/8 turn and all better. This is common with a lot of ep's. Do a quick search on Panoptic Rattle. Lots of more specific instructions.
I throw this out there simply because if the barrel is that loose, chances are the retaining ring will be too. Better to tighten both up.
-------------------- Ron
8" f6 Eq Newt
24PAN, 13T6,7T1,6RAD,5RAD,4 & 3.2 Planetaries
13 registered and 14 anonymous users are browsing this forum.
Moderator: Greg K., Jason B, csa/montana
