Announcements and News >> Beginners Forum
mstrplmber
Reged: 05/18/08
Loc: NC
SETTING THE LOCATION ON STELLARIUM
      #2595419 - 08/21/08 02:17 PM
I told a friend of mine about stellarium but he is having trouble setting his location. He tells me he is unable to click on the map to choose his location. I really can't remember how I did it. Can anyone tell us how to set your location. Also are there any directions on how to get the best use from Stellarium? Thanks
wolfganggold
Reged: 02/06/07
Loc: Louisville, KY
Re: SETTING THE LOCATION ON STELLARIUM new [Re: mstrplmber]
      #2595443 - 08/21/08 02:32 PM
point to the general area you are in and move the mouse wheel up one or two clicks. then re-position your mouse arrow to be a bit more accurate. As you move the arrow around you'll see the locations of each of the little dots on the map. I just chose one fairly close to me and clicked it. Then hit save location, and type a name into the blank and click OK.
There's a manual for it on the stellarium.org website...some good stuff in there.
Orion XT8 Classic
Orion Sirius Plossl 25mm
Orion Sirius Plossl 10mm
Orion Q70 32mm 70° Widefield
Takahashi 5mm ED LE
Rigel Quickfinder
9X50 RACI Optical Finder
Orion Shorty 2X Barlow
Orion 25% Moon Filter
Nikon Action 10X50 Binoculars
Moonlite Focuser
Baader Hyperion 13mm EP
My Band
smasraum
Reged: 01/13/08
Re: SETTING THE LOCATION ON STELLARIUM new [Re: wolfganggold]
      #2595495 - 08/21/08 02:58 PM
It's a pain to use the map.
Go to C:\documents and settings\<username>\application data\stellarium.
On my laptop the location is "C:\Documents and Settings\masraums\Application Data\Stellarium"
You should see a file titled "config.ini". If you open that file (it should open in notepad) then you can edit this section with your lattitude and longitude.
From mine
[init_location]
name = home
latitude = +29d 32'17"
longitude = -95d 13'0"
altitude = 0
landscape_name = guereins
time_zone = system_default
time_display_format = system_default
date_display_format = system_default
home_planet = Earth
If you don't know your lattitude and longitude, this page will give it to you (in the US)
http://world.maporama.com/
Steve
Houston (Friendswood), TX
Space Center Houston
8" Zhumell Dob - Woo Hoo!!
Celestron C102 f/5 - Thanks Tim!
21mm, 13mm Hyperion
2.5x TV Powermate
Canon Rebel XT
Nikon 7x35
Bushnell 10x50
richard7
Reged: 11/02/07
Loc: Sacramento
Re: SETTING THE LOCATION ON STELLARIUM new [Re: smasraum]
      #2595526 - 08/21/08 03:13 PM
If you're trying to set your geographic location, your observatory, click on the tool button, (the wrench), then the location tab and have at it.
It would help if you knew your coordinates ahead of time. Google earth can help you there.
Richard Trost
Richard Trost
Orion 130st, Ioptron e/r80
Meade 10x50, Konusvue 20x80, Zhumell Tachiyon 25x100
Coffee thermos and cup
Treehopper
Reged: 07/29/08
Loc: Upstate NY
Re: SETTING THE LOCATION ON STELLARIUM new [Re: richard7]
      #2596071 - 08/21/08 08:59 PM
Be aware that in the new development version of Stellarium (v. 0.10.0) is still in beta, and last I checked the location map doesn't work under Windows Vista 32-bit (this was as of last week.)
The current operating version is 0.9.1, and functions properly.
Tim
Third oak on the right, and straight on 'til morning.
Meade ETX-125PE (NGC7000 Edition)
When I consider thy heavens, the work of thy fingers, the moon and the stars, which thou hast ordained;
What is man, that thou art mindful of him? and the son of man, that thou visitest him?
WildBill
Reged: 07/07/08
Loc: Batesville Ar USA
Re: SETTING THE LOCATION ON STELLARIUM new [Re: Treehopper]
      #2596121 - 08/22/08 02:52 AM
Another way to find your coordinates (longitude/latitude)is if you have access to a clearsky chart free on the net for your location click on the topo map just below the graph and it will direct you to a different page on that page look to the left side and it will give the long/lat for the location of the graph you were just viewing.Hope that helped,and Google earth is good to.This is just another way I found to find my cooridinates.
Clear Skies
Edge Of The Ozarks Arkansas
Meade 70AZ-A 70mm
Celestron NexStar 114SLT
Kodak Z710 Digital
Canon T50 35mm
+35.82/-091.57
WildBill
frero
Reged: 01/07/08
Loc: Arlington Hts, Illinois
      #2599504 - 08/23/08 11:07 PM
Here's how I work with Stellarium, since the map can be tricky.
1. Go to the NOAA's Geophysical Data page and type in your Zip Code. It will automatically generate your latitude and longitude.
2. In Stellarium, click on the wrench, then click on the location tab.
3. Use the up/down arrows to set your latitude and longitude, then click save location. That's it.
Brooklyn
Reged: 07/24/08
Loc: Central New Jersey
      #2599513 - 08/23/08 11:21 PM
Your location in stellarium doesn't have to be 100% accurate.
As long as it is within the 5-10 miles radius of where you live, its accurate enough to see whats going on.
Look at a map of your town, then look at the map in stellarium.
Stellarium only uses bigger cities as Dots on the map...so decide which towns are near your area and what directions they are in.
For example...i live in a town called marlboro NJ. East brunswick township is in the stellarium map, and it is NW of my town. Freehold township is also in stellarium but is southeast of my town.
So what do i do? i zoom in all the way between the dots of east brusnwick and freehold....and i put my location dot right between the two of them. It is more than enough accuracy.
Stellarium RULES!! out of all the star charts this is my favorite....since they use REAL 3d graphics instead of just a 2d circular star chart.
Meade 8.25"(209.55mm) LX-90 EMC (SCT)
Albert Einstein =>
“Intellectual growth should commence at birth and cease only at death.”
“If you can't explain it simply, you don't understand it well enough.”
Brooklyn
Reged: 07/24/08
      #2599514 - 08/23/08 11:22 PM
hey treehop, wanted to let you know. I am also using windows vista 32bit and stellarium works fine for me...all of its features work.
Try to reinstall?
Albert Einstein =>
Treehopper
Reged: 07/29/08
Loc: Upstate NY
Re: SETTING THE LOCATION ON STELLARIUM new [Re: Brooklyn]
      #2599766 - 08/24/08 02:55 AM
Try to reinstall?
Which version are you using? The standard Windows version (v.0.91.0) works fine for me as well. It's the "development" version with the proposed new features that has the borked map. I've tried this on both my computers to verify. There's something flaky still about the beta version (0.10.0). I'm sure it'll be fixed before long.
Tim
10 registered and 14 anonymous users are browsing this forum.
Moderator:  miniventures, desertstars, werewolf6977, dgs©, ClownFish
Home
