Privacy Policy |
Please read our Terms
of Service | Signup and
paul11
Reged: 01/30/06
Loc: Essex UK.
Hi all just a couple of questions about setting up the EQ6.Do you use the bubble on the tripod or do you use a real level on top of the tripod to level it and how level does it need to be, exact or just close. Are we on daylight savings in the UK or not.And how accurate do you have to be with your latitude and longitude,my latitude is 51.52 and my longitude is 0.602 is the latitude North and the longitude East,thanks,,,,Paul.
-------------------- LX90-10" Canon 350D Toucam 840K Barn-door tracker
RAKing
Reged: 12/28/07
Loc: Virginia
I must confess that I have never even looked at that little bubble level because it really doesn't matter.
My pier is close to level and I sure don't waste time trying for anything better than that. The only reason to level the mount is to make it easier for polar alignment. If the mount is level, there is no interaction between the azimuth and latitude adjusting screws.
After the mount is polar aligned, it does not care if the tripod is level. At that point, the RA axis is "level" with the NCP and that's what counts.
It's always easier to align the mount if your lat/long are correct. The SynScan hand paddle goes to tenths of a minute and degrees. You can interpolate seconds and still be good.
Forgive me, it's been many years since I lived over there, but I do believe you are on BDT right now and Essex is east of Greenwich.
Ron
-------------------- Time spent looking at the stars is added to your life.
"Hi Def" TV-102
C925-CF SCT "Time Machine II"
Orion XT10i / Moonlite CR2
GM-8 GEM / A-P Portable Pier
Bradley B
Reged: 05/14/07
Loc: Sacramento, California
Hi Paul,
Although I've seen some of the bubble levels that were "close", the bubble level on my EQ6 (Orion Atlas, rather) was wildly off. I use a bubble level (now).
Although you will undoubtedly hear different opinions, it has been my experience that the "Alignment Successful" message comes most easily with carefully leveled mount, accurate polar alignment, and fairly precise lat/long.
I do not know if you are on Daylight Savings in the UK or not.
Hope this helps.
BB
-------------------- Vixen NA140SSf
Pentax 105SD
Meade 12" LightBridge
Takahashi 7X50IL "Astronomer" Binoculars
It is error only, and not truth, that shrinks from inquiry. -Thomas Paine
Reged: 07/06/07
If you want to level it, the built-in bubble is fine. It really doesn't make a whole lot of difference.
-------------------- Uncle Rod
Watch for Rod's New Book:
Choosing and Using the New CATs--coming soon!
Reged: 07/06/07
Ron
We can take that a step further, actually, and say that it doesn't make any difference whether the mount is level _before_ it is polar aligned. Level has zero effect on polar alignment.
paul11
Reged: 01/30/06
Loc: Essex UK.
Thanks for that i may get the chance to test it on Friday if the clouds clear,,,Paul.
Skylook123
Reged: 04/30/05
Loc: Tucson, AZ
I'll try with some general information; if it is old news, please just read on by.
First, the hand controller GOTO technology is called SynScan. You may see SynTrek; this is the non-GOTO version.
The easiest setup for any location is to set the time to current UTC, offset = 0, and DST = NO. Of course, that means you need to know what UTC it is!
The level is hopeless on most EQ6s, as is the latitude setting for the elevation. The most accurate way to set the mechanical latitude prior to polar alignment is to use an inclinometer (the sort of thing used to check the angle of walls or shelves) and set it on the top plate without the OTA. But, as Uncle Rod observes above, level isn't critical if you use other methods for polar alignment. I try to use a level and inclinometer because my setup is quite mobile; at times, over 300 miles between setups. So, if I level and have a good inclinometer reference for elevation, I can get Polaris more easily into the polar scope. However, a 1-star alignment followed by a Polaris GOTO and then adjust the pointing with the mount mechanicals can also easily get Polaris into the polar scope.
You will need to enter your coordinates in the hand controller in hh mm for RA and dd mm for DEC. That's all the precision you can enter.
I assume you will be receiving the SynScan V3.xx firmware hand controller. When you receive it, power it up (it can be powered in a stand alone mode, without the mount) and verify you have one of the latest versions, V3.20 or newer. The source of the firmware upload software for your computer to update the hand controller, and for the latest firmware to upload, is: Skywatcher SynScan Firmware Downloads
If you do not receive the latest user manual(s) with the kit, try: Syscan Manuals
Download both the SynScan 3.0 and 3.11 files. In addition, you might want to download all of the firmware files, since some have version description files included. You might need all of the odds and ends to have the complete documentation.
I see you have a 10" LX-90; is this the OTA you will use? I converted my 10" LX-5 to the Atlas version of this mount. It's been fantastic for the last 2 1/2 years.
A final comment; there is a good source of EQ6 help and information on Yahoo. Check it out for a gold mine of information, and friendly, effective advice:
EQ6 Yahoo User Group
Well, there's a start. We could also raise the possibility of EQMOD. That's a fantastic resource for running the mount that opens a wide universe of possibilities, including satellite tracking.
Yahoo EQMOD Users Group
-------------------- Jim
A Bad Night With A Telescope
Beats A Good Night Doing Anything Else
Tectron 18" Truss Dob/Sky Commander DSCs, "Derrick"
Meade 10" LX-5 SCT/Atlas-G "Ol' Blue Eye"
Orion 90mm refractor,
Meade 10" Starfinder Newt/JMI NGCMax DSCs,
Celestron 10x50 Ultima Pro
nik hodges
Reged: 04/20/07
Loc: UK
all good advice the only advantage of leveling the tripod is that if you are level then when you make azimuth adjustments it has no effect on altitude and vice versa.
If you are not level this is not the case as the axes are "mixed" up and azimuth adjustments will effect the altitude and vice versa which if you drift align means you cant independently adjust the axes
-------------------- Flurostar 110 [TMB] with TAK TOA/FS 0.75 reducer
Megrez 80mm triplet apo & mkIII FF
"LX200R" (8") with AP CCDT67 reducer & moonlight focuser
StarlightXpress SXVF-H16 camera/trutek filter wheel
DSI Pro II
Maxim DL/Maxpoint + adobe PS3extended
On AP900 notification list
paul11
Reged: 01/30/06
Loc: Essex UK.
Thanks again guys I’ve fitted the Losmandy dovetail plate to the OTA today and the EQ6 Losmandy head will be here in the morning,as soon as I fit that I will be up and running.Still shows clear skies tomorrow night so I hope to find out how it all works, if all goes well I will try the DMK as well,,,,,Paul.
11 registered and 18 anonymous users are browsing this forum.
Moderator: Charlie Hein, FAB
