han_solo82
Reged: 05/30/08
cleaning eyepiece new
      #2597012 - 08/22/08 04:33 PM
After a camping weekend with friends and my WO scope, my eyepieces are now filled with eyelash oil and other spots. I have search the web and these forums for tips on cleaning eyepiece and found that the televue instruction are probably best and easiest :
http://www.televue.com/engine/page.asp?ID=143
Now, I have a question. When I want to the pharmacy, I found 2 types of alcohol : one was 70% rubbing alcohol, and the other one was 99% isopropyl alcohol.
I went with the 99% isopropyl alcohol, since it is more pure than the rubbing one. Is it ok to use this type of alcohol (isopropyl) to clean eyepiece (and eventually, camera lenses)
I just want to be 100% sure before putting anything on my precious eyepieces!!
thanks!
Luigi
Reged: 07/03/07
Loc: Massachusetts
Re: cleaning eyepiece new [Re: han_solo82]
      #2597032 - 08/22/08 04:43 PM
99% is fine to use. Rubbing alcohol is simply dilute isopropyl alcohol. Alcohol absorbs water from the air so 99% IPA will become more dilute if the bottle is not tightly closed. Methanol, what I use, is even better as it leaves much less residue on optics. It's somewhat toxic so isn't usually available at pharmacies. Chemical supply houses have it.
17.5" f/5 Discovery Truss
IM715 7" f/15 MCT, Eon-120ED refractor
CG5A coffee grinder, Orion Skyview Alt-AZ
35,19,15 Pans.9 Nag. Meade 24.5 4kSWA, 4.7 5kUWA.
BO-TMB 7mm planetary.
Zeiss Diascope 85
Zeiss, Leica, Canon IS, Fujinon, Nikon binos
han_solo82
Reged: 05/30/08
Re: cleaning eyepiece [Re: Luigi]
      #2597042 - 08/22/08 04:46 PM
great! I guess I whould be fine with what I bought then!
thanks Luigi!
13 registered and 13 anonymous users are browsing this forum.
Moderator:  Greg K., Jason B, csa/montana
Home
