Mare Nectaris
Reged: 03/09/08
Loc: Toijala, Finland
Hi all,
this is a story of building an observation shelter KuuMaja (finnish for MoonHut), which is located in Toijala, Finland approximately at 61 degrees 09 minutes Norther latitude and 23 degrees 50 minutes Eastern longitude, at an elevation of 104 meters above the sealevel.
The aim was to construct a simple shelter to get rid of the light pollution due to the direct and close glow of several streetlights shinging from the North onto the yard.
I also wanted to have decent protection from wind, have the rig ready for quick sessions and be able to observe the most of the skies (i.e not to have a dome) and deliver fast tempering for the scope.
The hut also had to be on the backyard and the roof had to be quickly opened and closed. The northern side of the hut should allow to see the Stella Polaris for appropriate Polar alingment, yet protect from the streetlights as was mentioned earlier.
I have clear vision about from Southeast to Northwest, over trees and houses upward from about 30 degrees from the horizon.
The KuuMaja (MoonHut) is 2,5 x 2,5 meters and the maximum height on the Northern wall is 2 meters. The South-tilted roof is made of transparent plastic material, and it slides up and down (on rails down into the South), hanging on a sliding rails system.
The structure is made of lumber preprocessed (impregnated) to be water resistant. The walls and the floor are made of filmlayered plywood board, which is also water resistant.
At this point my EQ6 Pro –tripod is simply mounted on concrete slabs resting on a sand bed, thus having no contact with the structure to prevent any vibrations from transferring into the scope when observing.
The stucture is made in a fashion it breathes under the roof, so I might experience minor amount of snow pouring in occasionally, but this should not be a problem (knock-knock).
Also the ventilation is important, as the transparent roof gathers considerable amount of warmth into the hut especially during the summer months.
In the following messages I'll share with you 17 pictures to present the ida of the KuuMaja (MoonHut). It took some 70-80 hours to build, and of course required permission from the neighbours and authorities to be built. There are also a few closeups on the building of the sliding system just in case somebody would benefit from the ideas.
Be well all!
First, the foundations...
-------------------- Share - and you shall have it all
Timo Keski-Petäjä
CtheMoon
Observation shelter KuuMaja (MoonHut)
TAL 250K*Celestron C8-N*SkyWatcher Skymax 150 Pro*TAL1(Mizar)*EQ6 Pro SynScan*Celestron Advanced GT (CG-5 GOTO)*Baader Hyperion Clickstop Zoom 8-24*17 mm UWA-70*TeleVue BIG 2x Barlow*Celestron 2x Barlow Ultima SV Series
Edited by Mare Nectaris (08/23/08 06:36 AM)
Mare Nectaris
Reged: 03/09/08
... the floor structure
Timo Keski-Petäjä
CtheMoon
Mare Nectaris
Reged: 03/09/08
... sandbed and concrete slabs for the tripod...
Timo Keski-Petäjä
CtheMoon
Mare Nectaris
Reged: 03/09/08
... ready floor (later to be cut for the tripod to be mounted properly)...
Timo Keski-Petäjä
CtheMoon
Mare Nectaris
Reged: 03/09/08
... skeleton ...
Timo Keski-Petäjä
CtheMoon
Mare Nectaris
Reged: 03/09/08
... the walls ...
Timo Keski-Petäjä
CtheMoon
Mare Nectaris
Reged: 03/09/08
... Southbound rails for the roof ...
Timo Keski-Petäjä
CtheMoon
Mare Nectaris
Reged: 03/09/08
... sliding roof ...
Timo Keski-Petäjä
CtheMoon
Mare Nectaris
Reged: 03/09/08
... detail of sinking the slider's bolt into the roof sled ...
Timo Keski-Petäjä
CtheMoon
Mare Nectaris
Reged: 03/09/08
... sliders bolt in place on the sled ...
Timo Keski-Petäjä
CtheMoon
Mare Nectaris
Reged: 03/09/08
... locking the sinked bolt with plywood ...
Timo Keski-Petäjä
CtheMoon
Mare Nectaris
Reged: 03/09/08
... Nut is on ... and I'm quite nuts already
Timo Keski-Petäjä
CtheMoon
Mare Nectaris
Reged: 03/09/08
... left roof sled (seen from the Southside) with slider attached to the assembled bolt (this will be hanging on the rails supporting the roof letting it slide). The support on the sled is only temporary in this pic - it was later built from 5 inch plank to be on the safe side ...
Timo Keski-Petäjä
CtheMoon
Edited by Mare Nectaris (08/23/08 06:50 AM)
Mare Nectaris
Reged: 03/09/08
... sliding roof ready and closed ...
Timo Keski-Petäjä
CtheMoon
Edited by Mare Nectaris (08/23/08 06:52 AM)
Mare Nectaris
Reged: 03/09/08
... closed roof seen from inside the Hut ...
Timo Keski-Petäjä
CtheMoon
Mare Nectaris
Reged: 03/09/08
... KuuMaja (MoonHut) is born
Timo Keski-Petäjä
CtheMoon
Mare Nectaris
Reged: 03/09/08
... and the roomer has arrived - or maybe even the resident!
Thanks folks for witnessing the happy occasion!
Be well all!
Timo Keski-Petäjä
CtheMoon
David Pavlich
Reged: 05/18/05
Loc: Mandeville, LA USA 30.22 X 90....
Very innovative! I like the way you worked with the tripod to keep it isolated from the floor.
David
-------------------- Proud Member; PAS NOLA,
"If we knew what we were doing, it wouldn't be called research..."
A. Einstein
csa/montana
Den Mother
Reged: 05/14/05
Loc: montana
Very, very nice! A simple, but very effective design that will work very well for you!
Thanks so much for sharing the great photos taking us on the journey with you.
Now, enjoy!
-------------------- Carol
AstroTech 16" Dob (Thanks ASTRONOMICS!)
Vixen 80MF/AstroTech Voyager
Masuyama's 7.5, 15, 25W, 35mm,
Pentaxes; 5XW, 7XL, 10XW.
14mm Meade 4000 UWA
TV Panoptics; 22, 35
DreamCatcher Dobservatory, #2
Galaxyhunter
Reged: 01/02/06
Nice job on your OBS
Blowing snow WILL find its way through the smallest of openings. You might want to get some brush stips to seal the movable roof to the stationary building. Its just a thought.
-------------------- Carl
My lousy skies at Hawkeye Observatory
