Privacy Policy |
Please read our Terms
of Service | Signup and
abutu
Reged: 03/09/07
Loc: Gijón (Asturias) - SPAIN
Hello:
I am considering this OTA. Could anybody tell me how this combo works for visual only (no astrophotography)?
I know that Celestron sell the C11 over a CG5GT but I would like to know also the opinions of the users of CN.
Thanks a lot,
Alex
letimotif
no complaints
Reged: 05/20/07
Loc: Far Flung Isles of Langerhans
Hey Alex,
You'll get some varied opinions on this one. The CG5-GT is a fine mount. It's noisy, so don't be surprised if you wake up the neighbors, but its go-tos are great.
Now, I've used a CG5 with a 9.25" SCT it found it a bit wobbly. Not terribly so, sometimes a few seconds to damp down on the vibrations. I think it would be possible to use a C11, but vibration will be an issue for you. The difference in weight is significant.
I know there are some folks who are quite content, you may find it suits you, too--or not.
-------------------- Celestron CPC 1100
Celestron C6R-GT
Orion 120ST
B&L Banner Astro 80mm
Astro Telescopes 'tis a mystery 80mm ED
Sundry Oddments
Ah, but a man's reach should exceed his grasp, or what's a Heaven for?
Ad astra per aspera
kaaikop
Reged: 07/13/08
Loc: Ste-Therese, Canada
Bad idea, IMHO I had C9.25 with GG5GT. Already was at the very limit of that mount. I think it could handle an 8" reasonably, but not for serious photography. I had to return mine (traded in for a Skywatcher EQ6 Pro) after a number of quirks & problems with the CG5, that was the best move I ever did.
-------------------- Benoit, RASC Montreal
-C 9.25XLT on EQ6 Pro / ED80SF on Portamount
-Plossls, Radians, Naglers, LVW's & Orthos.
-a pair of 7x50's
Arbacia
Reged: 04/18/07
Loc: Madrid, Spain
Abutu, I told you before. If the c9 is not a good idea on your CG5GT, the C11 will be worse. Have you even seen any of these tubes?
At this point, change the mount or keep the C8. Or much better: get directly a C14 system.
Alternativelly, you can keep your TSA on CG5GT, which is a light equipment, and get a 12"-16" dobsonian with tracking and argonavis-like systems.
LightBridge 12"
Celestron C8 (orange tube) on HEQ5
Set of Hyperion EPs; DMK 31AF03.AS
CN image gallery
http://www.asociacionhubble.org
magsterone
Reged: 03/14/06
Loc: Mobile, AL
I own the c-11 asgt set-up. It is great! I do visual only and the views are spectacular! The only modification I made to the set-up is using the Starizona Accessory Tray and the Celestron Vibration Pads. I can knock my ota and it settles in under 2 sec. When I use my Denk binos and rap the ota, it settles in less than 3 sec. Don't let the naysayers turn you off from this setup. I think it is the best deal for the money out there. Good luck.
-------------------- Best Regards,
Joe in Mobile
C-11 ASGT
Denk II Binos
Denkmeier #S2-d SCT Powerswitch
Pair of Televue 24 Panoptics
(Possibly 13t6's in the future)
Member of Mobile Astronomy Society
Al Canarelli
Reged: 12/06/07
If you use this set up for visual only use, you can get away with it. While it's not a match made in heaven, it will be okay if you make certain that everything is always carefully balanced. Be mindful that this OTA weighs 28 lbs, which is about 8 lbs. more weight than you should have on this mount. To be on the safe side, it may be a good idea to slow down the slew rate so that you don't tax the machine too much.
w orchid
Reged: 04/23/07
Loc: Tampa, Fl
There is a member in our club, that has this set-up and he takes incredible images with it. Hopefully he will chime in.
-------------------- Celestron C8 orange tube circa 1982
Stellarvue SV102ED
Rusty
Reged: 08/06/03
Loc: Brooker, FL
Our club also has an imager with one; his images are fine (planetary only with a webcam). It's marginal at best, however, visually or for imaging.
-------------------- N11GPS Fastar
TOA-130S
MK66 Std
Vintage C5
Megrez II 80mm ED Triplet APO
SolarMax 40
NJP Temma II
Sirius EQ-G
ST8XE/CFW-8(LRGBHa)/AO-7/DF-2/STV Dlx/ST237a/350D (Unmodded)/Mallincam Color Hyper Plus/DSI III Color/DSI II Pro
Two not-spoiled Golden Retrievers - Maggie and Casey
Sometimes I think we're alone in the universe, and sometimes I think we're not. In either case the idea is quite staggering. - Arthur C. Clarke
magsterone
Reged: 03/14/06
Loc: Mobile, AL
I just use mine as advertised. I use the hc as I woukd for any mount. I never considered the slew rate. You'll never regret this package.
Joe in Mobile
C-11 ASGT
Denk II Binos
garyc11
Reged: 11/20/04
Loc: Niagara Falls,NY
i agree, i had this set up before i bought my other scopes and it worked just fine for visual. careful balancing and anti vibe pads help a lot. i was even able to do some astrophotography with this set up. this package is a heck of a deal you wont regret it.
-------------------- CGE 1400
CPC 1100
MallinCam Hyper Plus Color
Celestron 100 ED
CG5-GT
Celestron C-8 Newtonion
7 registered and 10 anonymous users are browsing this forum.
Moderator: Jason B
