Privacy Policy |
Please read our Terms
of Service | Signup and
microbes
Reged: 12/12/04
Loc: Romulus, Sector 12
it's supposed to be f/9 or so, where the image deterioration from spherical aberration becomes smaller than the scope's resolution limit
This is true of a 4.5 inch, but as the mirrors get bigger the focal ratio at which a spherical mirror is defraction limited goes up. If I recall, in a 6 inch you have to be at about f/10.5 and in a 8 inch you have to be at about f/13.
That's why you don't normally see spherical mirror used in newts much bigger than 4.5, the focal length required to get close to defraction limited gets really long with bigger mirrors and makes for a scope that you need a ladder to get to the eye piece.
For instance, an 8 inch newt with a spherical mirror would have to have a tube about 100 inchs long (8 1/2 feet) to be defraction limited.
Dirt Cheap Astronomy
Voyager 114X900 Newt EQ2 * Sky Chief 60X700 EQ1 * Cometron 62X300 EQ1
Sears Ultra Wide 7X50 Binos * Vintage 16X50 Binos EQ1
Books, Barlows, Eyepieces, Camera Adaptors & Other Esoteric Junk.
Protheus
Vaguely offended
Reged: 09/01/07
Loc: Illinois, US
Now that you mention it, that makes perfect sense, given the rather large increase in resolution for the larger mirror.
Chris
-------------------- "To tread the sharp edge of a sword;
to run on smooth-frozen ice,
one needs no footsteps to follow..."
"Well, people sometimes ask me 'how did you get involved in astronomy?' I said 'I got born, what's your problem?'" -- John Dobson
"In discussing the large-scale structure of the cosmos, astronomers sometimes say that space is curved, or that the universe is finite but unbounded. Whatever are they talking about?" -- Carl Sagan
dmgriff
Reged: 09/20/06
Loc: 30 degrees latitude, USA
force a fast scope to become a slow scope by stopping it down.
Chris,
When you say stopped down, do you refer to a mask at the front of the ota or at the mirror?
I have a end cap plug on my 114mm/912mmfl f8, that has an additional plug in the center of about 60mm diam. I always assumed that this was for viewing the moon, to cut down on glare, etc. The instructions didn't even mention it.
So, do I have a roughly stopped down f15 (912/60)?
(The original spherical mirror has been replaced with a e-scopes/coulter 1/8wave.)
Good viewing,
Dave
Protheus
Vaguely offended
Reged: 09/01/07
Loc: Illinois, US
Sounds more or less right. The thing is that by covering the edges of the mirror, you effectively "convert" it to a smaller mirror at the same focal length. You can basically get whatever slower focal ratio you want this way, along with any benefits, like reduced spherical or chromatic aberration, for example, or a scope that will work well on simple eyepieces. The draw-back, of course, is that you lose aperture, and so your theoretical resolving power is less. Unless the mask is offset, you also have the same central obstruction that you usually have, which -- relatively speaking -- becomes much larger after a point.
Chris
dmgriff
Reged: 09/20/06
Chris, sounds like those who have a Tasco Luminova ota have a "secret weapon" for the spherical mirror. I guess for lunar/planetary, doubles, whatever.....
Good viewing,
Dave
InkDark
Reged: 10/29/07
Loc: Montreal, Canada
Thanks everyone for the replies. You never how much you will learn when you start a new thread on CN. I'm learning a lot with this one.
Chris, if I understand what you're saying is that a 8 inch newt with a 1200mm FL could also serve as a 6 inch with a 1200mm FL if a mask is made at the front of the tube? Would this make it as easy to collimate the 8 inch with a mask as a 6 inch. I don't know if I understand what you meant, but this doesn't seem right.
-------------------- Jimmy
"Rarely Have So Many Understood So Little About So Much" - Palle Yourgrau
"...since that time, I have not complained about the weather one single time. I’m glad there is weather." – Alan Bean, Apollo 12
What do you mean by “Saving the Earth”? The Earth is not in danger! Don’t worry about the planet it will be here long after we are extinct...
Protheus
Vaguely offended
Reged: 09/01/07
Loc: Illinois, US
Yes, actually it's not just good for spherical mirrors. Even a parabolic mirror can use an aperture mask to combat glare (as you mentioned), or possibly poor seeing...
Chris
Protheus
Vaguely offended
Reged: 09/01/07
Loc: Illinois, US
Well, yes and no; think of it like this:
By masking off the 8" to 6", converting your 8" f/6 to 6" f/8, you probably do increase the tolerance for misalignment compared to what the 8" would show at full aperture, yes. You can probably reduce a 12" dob to 6" and not see coma even without a paracorr.
It will only work, though, as long as it's behaving as a 6" mirror. In the case of your 8" example, you can't put the mask on, collimate it, and take it back off expecting not to see coma because you collimated it with an aperture mask on. The thing that makes the 6" less picky is the focal ratio. An f/6 mirror (the full 8") is somewhat more picky about being perfectly in line than an f/8 mirror (the stopped down version); you can take advantage of this and get the view of a perfectly enough collimated 6" from your not-quite-there 8", but you can't use it to get the collimation any closer to perfect so that it will work right when you un-stop the mirror.
Chris
Edit: What I'm saying here is that in absolute terms, your perfectly collimated 6" optical system and your not-perfect-enough 8" optical system are the same distance from ideal. It's only that at the slower focal ratio, you have more room for error before you start seeing it in the image.
Edited by Protheus (08/19/08 06:40 PM)
InkDark
Reged: 10/29/07
Chris
Chris, I got ya. I didn't expect a mask on the 8 inch to help collimation that's of course logical. But now that you've brought this up (the mask thing) I understand that in a 8 inch with 1200mm FL, you kinf of have a 6 inch with the same FL if you put a mask on since its the outer edge of the bigger mirror (the 7 and 8th inches) that induce the abberations.
Protheus
Vaguely offended
Reged: 09/01/07
Loc: Illinois, US
I'm afraid I don't fully understand it myself, but that's the way I think it works, yep. At least in terms of spherical aberrations, I can say with some certainty that this is the case. I really haven't looked at coma well enough yet, and can only assume (so far) that it will be similar...
Chris
microbes
Reged: 12/12/04
One thing to think about if you you consider masking down a newt is the size of the secondary. When you mask a newt down the central obstruction becomes a larger and larger percentage of the total aperture meaning you lose contrast and if you carry it too far you will start seeing the secondary shadow in the eye piece, particularly when looking at something bright like the moon.
You can get around that if you make an off axis mask but I think that creates problems of it's own.
But who wants to lose aperture anyway? There are very few good reasons for wanting to lose aperture.
InkDark
Reged: 10/29/07
Yeah, well not me!
Protheus
Vaguely offended
Reged: 09/01/07
Loc: Illinois, US
Yeah, well not me!
Me neither; I think I mentioned the problem of the larger relative secondary obstruction a while back... Still, once in a while, it's good to know that this kind of thing can be done.
Chris
InkDark
Reged: 10/29/07
So my father had the chance to try is scope on Jupiter last night with the 25mm plossl. He said that although the planet was small (only 36X), it looked pretty clean. He would like to try higher power. Just as a guide line, can we expect this scope to work at 100X or so on planets? Any of you have tried this before?
Protheus
Vaguely offended
Reged: 09/01/07
Loc: Illinois, US
I'd say the it should almost certainly do this. You have a 4.5" scope there. Even if you can't reach 50x/inch due to spherical aberration, it should sustain well over 100x in good conditions.
I seem to recall that Pete gave an approximation of somewhere around 40x per inch for his 130mm spherical mirror. Can't find the post right now, but if that's right, you'd get 160x pretty easily.
Chris
InkDark
Reged: 10/29/07
Thanks Chris for your inputs. I think that my father should be pretty happy if he could use his scope on planets at 100X. OTOH, 160X is rough on must nights with my 6 inch (local sky conditions). So I guess a 9mm EP should do fine for my dad as a high power EP and use the 25mm as a finder. This scope is just something that he can take along when going in the country. When we go observe together, we obviously take my scope and his binos (they're better then mine, hands down).
Thanks again for your help confirming what I was thinking.
