Privacy Policy |
Please read our Terms
of Service | Signup and
bigD
journeyman
Reged: 12/04/07
Loc: Vancouver Island, BC, Canada,
Hi all After looking at the stars for years i got myself a c8-ngt and it works great and being a beginner setup and finding objects is to easy,The only problem is the focuser, every time you focus the object moves back and forth. could a antares focuser http://www.islandeyepiece.com/shopexd.asp?id=1205 fit on the c8-ngt. thanks
mcoren
Reged: 01/11/06
Loc: Northern Virginia, USA
The problem you are seeing is called mirror shift, and it is the result of the way SCTs focus by moving the primary mirror.
The focusers you show are meant for newtonians and refractors.
The same focuser (made by GSO in Taiwan) is available for SCTs. Here is a link to one supplier in the US:
http://www.scopestuff.com/ss_fsm1.htm
You can check with Island Eyepiece & Telescope to see if they have something similar, or with ScopeStuff to see if they can ship to Canada.
-------------------- Mike
Orion SkyQuest XT10
Suburban Washington DC
bigD
journeyman
Reged: 12/04/07
the c8-ngt is a newtonians not a SCT
http://www.celestron.com/c2/product.php?CatID=11&ProdID=57
the focuser has play in it and the object im looking at moves around
Edited by bigD (08/24/08 05:35 PM)
mcoren
Reged: 01/11/06
DOH! Sorry, I knew that, but I saw "C8" and it registered SCT in my mind!
As Gilda Radner used to say on Saturday Night Live (for those of you over 40), "Never Mind"...
Orion SkyQuest XT10
bigD
journeyman
Reged: 12/04/07
thats ok
karlpenney
Reged: 01/04/07
Loc: Halifax, NS
Do you mean the object moves around in the view as you adjust the focuser? This seems odd, does the drawtube wobble or something? Anyway, the Antares focuser should fit fine. I replaced the original R&P focuser on my 8" dob with that same one. It is much smoother!
-------------------- Karl
Antares 8" DOB
SV NHNG 80mm
Celestron C8
Vixen GP-DX
Canon 350D
bigD
journeyman
Reged: 12/04/07
yup the object moves around in the ep as I adjust the focuser, the draw tube wobbles but not bad just hard to center objects. thanks for the info
