csa/montanaModerator
Astro Ambassador
Reged: 05/14/05
Loc: montana
Wiring: fan on Dobs
      #2612233 - 08/29/08 04:33 PM
I'd like to hear about how others have "cleanly" tucked or guided their wiring from the battery pack to the plug-in for the fan on Dobs.
Photos would be nice!
Carol
AstroTech 16" Dob (Thanks ASTRONOMICS!)
AstroTech 66ED / Vixen 80MF/AstroTech Voyager
Masuyama's 7.5, 15, 25W, 35mm,
Tak LE 5mm B/TMB 3.2
7mm Pentax XL, 10mm Pentax XW
14mm Meade 4000 UWA
22mm Pan, 35mm Pan
DreamCatcher Dobservatory, #2
jskuban
Reged: 03/19/05
Loc: Northern Illinois
Re: Wiring: fan on Dobs new [Re: csa/montana]
      #2612614 - 08/29/08 09:19 PM Attachment (16 downloads)
Hey Carol,
I needed some counter balance in the mirror cell anyway, so I just brought the battery closer to the fans. The idea was, if you're going to carry the extra weight, might as well make it useful. You can see it just under the fans in the picture. The bracket swings out so I can get to it. After trying to fabricate the bracket, I found a metal bookend, made a few bends and it was ready to go. I use zip ties and wire guides to fasten and run wires.
Jay
16" Nightsky
8" Orion
80mm Nighthawk
John rombi
Reged: 08/14/05
Loc: Gods Country
      #2612642 - 08/29/08 09:44 PM Attachment (15 downloads)
Hi Carol,
If it's for your 16" it will be similar in configuration to my 12"Lb.
Instead of the battery pack supplied with your scope (and mine) I routed it through a fused switch box.
The 12V 7amp/h battery sits underneath the box on the side of the scope.
Meade Lightbridge 12" Deluxe (Modified)SiebertOptics
Unitron 4" Alt-Az
Unitron 2.4" Alt-Az
www.macastro.org.au "A New Eye On the Sky"
John rombi
Reged: 08/14/05
Loc: Gods Country
Re: Wiring: fan on Dobs new [Re: John rombi]
      #2612644 - 08/29/08 09:45 PM Attachment (10 downloads)
One more........
Unitron 4" Alt-Az
Unitron 2.4" Alt-Az
Astro Ambassador
Reged: 05/14/05
Loc: montana
Re: Wiring: fan on Dobs new [Re: jskuban]
      #2612685 - 08/29/08 10:16 PM
Hi Jay, thanks! Don't know if this would work with mine or not; but what a great setup!
Carol
14mm Meade 4000 UWA
22mm Pan, 35mm Pan
Astro Ambassador
Reged: 05/14/05
Loc: montana
      #2612691 - 08/29/08 10:18 PM
John, Nice! I'm completely illiterate when it comes to wiring, etc. Would you explain what all I need? Purchase at Radio Shack?
Carol
14mm Meade 4000 UWA
22mm Pan, 35mm Pan
KWB
Reged: 09/30/06
Loc: Westminster,Co Elev.1646Meters
      #2612851 - 08/30/08 12:41 AM Attachment (8 downloads)
Hello Carol
This isn't an answer to your question but it is another alternative. Do you have an electrical outlet in your observatory?
I dont have a permanent place to view and have to take my telescope for the evening outdoors every time I use it. The distance is short and a 25 foot extension cord is all I need. I don't like buying batteries or recharging them and a 300 MA/120 volt ac adapter works for me. When I'm done I roll up the extension cord and the converter with it. Not real neat and tidy but battery free.
Kenny
"When dealing with a mystery,choose the most unlikely of the likely possibilities"-Sherlock Holmes
Edited by KWB (08/30/08 12:42 AM)
Astro Ambassador
Reged: 05/14/05
Loc: montana
Re: Wiring: fan on Dobs new [Re: KWB]
      #2612915 - 08/30/08 02:34 AM
I do have several outlets, however, no matter which I would use, the cord would an obstacle for me to trip on.
Good idea Kenny, & it looks tidy! Definitely would save on batteries also!
Carol
14mm Meade 4000 UWA
22mm Pan, 35mm Pan
John rombi
Reged: 08/14/05
Loc: Gods Country
      #2613027 - 08/30/08 07:24 AM Attachment (7 downloads)
I hope I can explain it clearly for you!!
All the components can be purchased from an Electronics Store.
1.A Box to put everything into, There are many types and sizes.
The choice is yours.
2. A 2AG glass fuse holder (500ma glass fuse) + a switch.
3. 20cm's of hobby wire, to hook up the fuse and switch.
Unitron 4" Alt-Az
Unitron 2.4" Alt-Az
Astro Ambassador
Reged: 05/14/05
Loc: montana
      #2613280 - 08/30/08 10:53 AM
John, thank you!
Carol
14mm Meade 4000 UWA
22mm Pan, 35mm Pan
John rombi
Reged: 08/14/05
Loc: Gods Country
      #2613941 - 08/30/08 05:34 PM
Carol,
I know it just looks like a mess of wires in there, but the part you need is on the left.
I'll make up a simple diagram to show you what goes where.
Unitron 4" Alt-Az
Unitron 2.4" Alt-Az
Astro Ambassador
Reged: 05/14/05
Loc: montana
      #2613996 - 08/30/08 06:09 PM
I'd appreciate it, John!
Carol
14mm Meade 4000 UWA
22mm Pan, 35mm Pan
8 registered and 18 anonymous users are browsing this forum.
Moderator:  spaceydee, csa/montana
Home
