nytecam
Reged: 08/20/05
Loc: London UK
Don't recall seeing any wide-angle shots on this forum of large DSOs like the North America Nebula [NGC 7000] currently overhead after dusk - is it possible My recent shots here via a regular camera lens are hardly instant but I'd be interested in what is possible via long integration video I used a simple red glass filter to suppress my LP skyglow and highlight H-alpha emission without a costly Ha filter
-------------------- Nytecam 51N 0.1W
Meade 30cm LX200+ETX-70+DS-2090+C8+Ha+CaK PSTs SBIG SGS+homebuilt spectrographs
Starlight SXVF_M9/Lodestar/Canon 300D DSLR/Fuji E550
My observatory build-ETX-70 imaging-spectro page
rolandlinda3
Reged: 01/24/06
Loc: Crozet VA 22932
I want to try my little lens around Cygnus next time. I think Rony might also. Perhaps I will get a chance to do it. If so, I will post a sketch...I don't grab frames. Roland
dvb
Reged: 06/18/05
My understanding is that the Mallincam provides a FOV similar to an 8mm Plossl -- so, with a 50* AFOV and fairly high mag, you won't see wide-angle views.
-------------------- Skywatcher 10" f/4.7 Newt on Matilda
Skywatcher 10" f/4.7 Collapsible Dob
Meade 8" SN f/4
Celestron C8 SCT
Celestron C6 SCT
Skywatcher ED100
Skywatcher ED80
EQ6 Pro "Matilda"
AT Voyager
Skymaster 15x70
Mallincam HyperColor Plus
Jack Huerkamp
Vendor - Waning Moon
Reged: 10/13/05
Loc: Louisiana
Unless you hook the MallinCam directly to a normal camera lens - like a 50mm. Then you will get a wide field of view.
Jack
-------------------- Orion ED80
Coulter CT-100
Celestron 6" f/8 Refractor
8" Newtonian/Cassegrain on Byers 812 Mount
Classic C-8
Celestron 11" CPC 100 with HyperStar
Tricked-out 17.5" AstroSystems TeleKit
Life Member and ALCOR - PAS New Orleans
Waning Moon II Observatory
HendyPhoto
Sith Lord
Reged: 08/09/06
Loc: Bountiful, Utah
I get nice wide views with the mallincam, mfr-3 and a 66mm refractor. I will try to dig up some screen captures! I especially liked the veil and North American with a UHC-S nebula filter.
-------------------- ~jon
SparkCast
CGE1400XLT w/HyperStar
90FD 66SD C6-R SN-8
CPC1100XLT Hutech 20D
Manny-Mod Vixen Porta
Mallincam MCHP
SPC900NC
CG-5 GT
"Two things are infinite: the universe and human stupidity;
and I'm not sure about the universe." --Albert Einstein
nytecam
Reged: 08/20/05
Loc: London UK
Thanks - could someone explain "Mallicam [imaging CCD] fov = 8mm Plossl" - I thought eyepieces and imaging chips were different media TIA
StarStuff1
Reged: 04/01/07
Loc: East Tennessee
Last night I got some really nice wide angle views of NGC 7000 as well as the Gamma Cygni nebula complex with a 50mm f/3.6 refractor and an 80mm f/5 refractor and my IIE and 14nm Ha filter.
Haven't done any photos yet but maybe it's time to try.
-------------------- Two dozen eyepieces, a dozen binoculars, a half dozen refractors, two reflectors and a homemade Image Intensifier Eyepiece (IIE). All products subject to change by the owner at any time.
Jack Huerkamp
Reged: 10/13/05
Loc: Louisiana
Place your MallinCam into your scope with no focal reducer and then callup a program like SkyTools on object being viewed on the monitor. Select or define your telescope and for the eyepiece being used create one called "MallinCam" with a 8mm focal length and a 50 degree fov. Then call up the eyepiece view. A circle will appear surrounding the DSO and the diagonal view on the monitor will match the diameter of the circle shown on SkyTools.
This is how I deermeined that the MallinCam acts like an 8mm eyepiece with a 50 degree fov. I experimented with a bunch of focal length/ fov combinations until I got a fairly good match.
Jack Huerkamp
Coulter CT-100
Classic C-8
Chris Schroeder
Reged: 12/11/04
Loc: N.E. WI Sky Glow
Great idea Jack!
-------------------- Chris
Mallincam Color Hyper Plus
10" DSH with SC DSC, CPC 800 XLT
M102ED S.V., ZS 80FD 10th Anniv, ZS 66SD, PST
POD XL3 http://POD.SchroederCity.com
gavbray
Reged: 12/31/06
Loc: Gold Coast, Australia
If you have TheSky6 you can setup field of view indicators for the Mallincam which are displayed as rectangles.
Under field of view indicators, create a detector with a size of 7.4 x 5.95 and 752 x 582 pixels. I have a PAL chip so you need to use the appropriate values if you have the NTSC chip.
You can then create field of view indicators using the Mallincam detector and your telescope/focal reducer combinations.
Without a FR the Mallincam rectangle is roughly the same size as an 8mm/50 degree eyepiece circle.
Gavin
-------------------- 14" LX200R + SV90T + AP1200GTO
31mm, 22mm, 17mm Naglers, 13mm Ethos, 10mm Pentax XW, 2X Powermate, AP MaxBright
Mallincam Hyper Plus Color, DFG/1394 video converter, Optec 0.33 & 0.7 FRs
IDAS LPS, DGM NPB & OIII, Lumicon Deep Sky
