Announcements and News >> Beginners Forum
PlayUgly
Reged: 12/22/07
Loc: Midwest
Stargazer Steve Scope: Night #2
      #2616224 - 09/01/08 02:39 AM
I took my telescope out again tonight along with my new small, folding table, pocket sky atlas, Night Watch and a whole list of globulars to hunt.
I decide to focus in on a red lamp shining from a nearby tower to better align the Rigel. I was pleasantly surprised to make out details of the lamp. Telescopes are cool.
Before hunting DSO's, though, I couldn't resist taking a quick look at Jupiter. The seeing must have been better tonight, because my 8mm Hyperion gave a nice, sharp view not at all like last night. I popped it in, and noticed... wait a minute. The upper, dark cloud band didn't look like that last night. Is that the...
HOLY...
I THINK THAT'S THE GREAT RED SPOT!!
After a sharing the eyepiece with my wife a couple of times, I was convinced I was looking at the GRS. What an incredible surprise. I wasn't sure what a 6" scope would show me. I didn't know if I'd ever see the GRS. It wasn't even that difficult to see. The dark cloud band had a noticeable chunk missing. A closer study showed a kind of bubble within the dark band with a very thin dark line extending into the lighter cloud band. THE ACTUAL GREAT RED SPOT!!
My wife went inside and I set out to find M13. This didn't work out so well. I can't make out Hercules. I searched for a little while, but no joy. My search was further complicated, since Hercules was directly overhead (I think). A dob really doesn't maneuver well when pointed straight up. Neither does my head. I'm going to spend some time time studying constellations and learning how to orient myself to the night skies
So... BACK TO THE GREAT RED SPOT!!! No loss really.
By now the GRS has moved to near the edge of the Jupiter, and I couldn't see it as well. I decided to try the fine tuning rings for the first time and see what kind of magnification I could get tonight. I tried the 28mm ring first. That turns my eyepiece to 5mm and I'm looking at 240X. I still get a good enough image, but it's not quite as sharp. I can make out more dark cloud bands nearer each pole. I add the 14mm ring to make a 4.3mm eyepiece and 279X. Again the image is softer but I can make out about the same detail. Jupiter is sprinting through the FOV at this point. I take out the 28mm ring and get 200X - a very nice view.
I take another token look for Hercules, and then notice a sparkling star low in the west. I grab the 21mm and get a lovely image of a busily twinkling star. I think I saw gold and green and maybe a little orange or red. I still don't know which star it was.
Some impressions after two nights out:
The Rigel is great. I can find objects more quickly through my telescope at 279X than I can through my binoculars at 20X. Finder scopes can't be any easier. At $40 - $50, I don't see why every telescope doesn't deliver with a Rigel or Telrad instead of finder scope.
The motion on my scope is very nice. It's relatively easy to make even the smallest adjustments necessary at 279X. I just need to grow accustomed to the upside down/backward motion.
The Hyperions seem to be a nice fit with my F/8 scope. I was looking at Jupiter at the FOV edge and still could see a sharp image. I like the large lens aperture. The eye relief is comfortable for my wife and I.
It looks like clouds are in my forecast the next few nights. I've got to go back to work Tuesday anyway, so I may not get out for a few nights. I'll soon post a report on buying and building a Stargazer Steve telescope.
Thanks, everyone, for reading and commenting.
Victor
Stargazer Steve 6" F/8 Dob
8mm, 13mm, 21mm Hyperions
Nikon 10x50 Bincular
Zhumell 20X80 Binocular
Jason 50X50 Refractor
(purchased by my grandmother's boyfriend for "2 bits" at a garage sale 30 years ago)
John Lacey
Reged: 03/12/08
Loc: Central Coast, CA
Re: Stargazer Steve Scope: Night #2 new [Re: PlayUgly]
      #2616255 - 09/01/08 03:36 AM
Nice observing. Patience goes a long way, and your testing various EPs attests to some. A lot of times I'll spend 15-30 minutes looking for something, which is sometimes easy to find later and sometimes not. It's easy to get frustrated, but often worth it to take a breath and try yet again.
The easiest way to get motions down is not to try to reverse things in your mind, but just pretend that you're moving the target, not the scope. On the other hand, if you're starhopping based on correct image maps, you might need to think about it a little. I mostly just avoid thinking altogether, and when I'm working from a map, or in my case from a memory of a map, I just ignore the visual and pull the scope in the right map direction.
It's funny, because I've never used a Rigel or Telrad, but I don't understand how they help. I can see mag 7 objects in the finder, so I'm often looking at my target when I move to the EP.
Oh, and yes, if you were looking earlier tonight and saw the GRS, then Hercules was at the zenith. When something is above 60° it's pretty tough for me, and involves kneeling and bending over to look through the finder. I find it helpful to balance my knee or right hand on the tube while I'm pushing it with my left to get finer control over the motions near the zenith. When it's over 75 or 80°, I don't even try. The patience helps here, too, because if you wait an hour or so, everything will move back down lower.
John L
Orion XT8i "Jetson", Q70 32mm, Hyperion 17mm, 8mm
Orion 10x50 UltraView
Jim Haley
Reged: 07/04/07
      #2616290 - 09/01/08 04:34 AM
Since you mentioned a difficulty in finding Hercules I will make one more suggestion. Try the book Nightwatch by Dickinson. It has constellation maps that (when held at arm length) contain asterisms the same size as you will see in the sky. This might help you more easily find the Keystone.
Jim Haley
12.5" f6 Starsplitter Dob
Orion 8" XTi (with computerized object locator)
Orion 114EQ reflector
80mm f6 refractor
dgs©Moderator
Reged: 03/29/04
Loc: West Monroe, Louisiana
Re: Stargazer Steve Scope: Night #2 new [Re: Jim Haley]
      #2617228 - 09/01/08 03:33 PM
When you find yourself in "Dobson's Hole", a trick many use to make steering a little easier is to put a brick or something under one foot of the base. Throwing the vertical (Azimuth) axis off of vertical a bit makes it easier to steer around your zenith.
- david
8"Ø Newtonian on SVP, Moonlite CR2, Telrad
PST Oberwerk Ultra 15x70 Orion Ultraview 10×50
Hand-me-down Sears Refractor (Discoverer) 60mm×900mm
"What we have done for ourselves alone dies with us; what we have done for others and the world, remains and is immortal." --Albert Pike
Silicon Owl
Reged: 11/25/05
Loc: Waimea, Hawaii
Re: Stargazer Steve Scope: Night #2 new [Re: dgs©]
      #2617334 - 09/01/08 04:21 PM
Sounds great! Jupiter really is nicely placed at sunset right now. I was able to show the GRS to some first timers Saturday night. Sounds like the long f/8 really is doing what it should, providing decent higher magnification views. The mirror has to be reasonably good to show the detail you describe.
You are right about the Telrad/Rigel, they make far more useful finders than the little optical finders attached to budget scopes. I notice that some suppliers like Orion put red dot finders on many of their basic scopes now.
Andrew
Andrew Cooper
Personal Website and CN Gallery
Handmade 18" Dob / NS11GPS / 6" RFT / 90mm APO / TV-76 ...and a twin 10m
"I have loved the stars too fondly to be fearful of the night." --Sarah Williams
18 registered and 13 anonymous users are browsing this forum.
Moderator:  miniventures, desertstars, werewolf6977, dgs©, ClownFish
Home
