Privacy Policy |
Please read our Terms
of Service | Signup and
markleewebb
Reged: 11/04/06
There are always and frequently posts by folks wanting to know about buying a scope and aperture/size. Most often it's 8" vs" 10" vs 12.5"
Over last few months and years I have had opportunity to compare views of various DSO's in several scopes. The scopes were all truss dobs:
8" with excellent Meade mirror f/6 10" with Meade research grade mirror f/4.5 12.5" with Zambuto mirror f/5
All scopes were well collimated when tested. Same ep's were used, too. All used Baader Hyperions 8, 13, 21, and 31.
Aperture won on many targets, but not all. In all, the images are larger with the larger scopes and you get more magnification with larger scopes, but on many targets the 8" is quite satisfactory.
Aperture was the dominant factor on all globulars. If globulars are your thing, buy the biggeest scope you can buy. You'll be disappointed on globulars in an 8". The larger globulars look like a dirty snowball (and small) in the 8". In the 10" you get some resolution and patterns of stars on M22, M28, M92, and M13. In the 12.5 you get lots and lots of resolved stars. The differences on globulars between scopes of different sizes is a large difference. Aperture absolutely rules on globulars. But - the 10" does quite well. The difference between the 10 & the 12.5 was not as large as difference between 10 & 8
Open clusters were the best in the 10" f/4.5. Some of best objects I viewed were in the 10 looking at M11 Wild Duck Cluster with a 13mm Baader Hyperion ep. Same for M23 M24 & M25, and the Double Cluster in Perseus. An f/4.5 mirror and an ep with a large fov blew away the other two scopes. If open clusters are your thing, a fast 10" scope with good optics and wide field ep's will keep you coming back for more night after night.
How about nebulae? On M8 Lagoon & M17 Swan the little 8" does quite well. It yielded a very bright albeit small image. You can see the Swan as a swan (which btw you can't on 4" - 6" scopes. In an expensive 4" APO refractor M17 looks like a diffuse rectangular shape). The 8", though, does have trouble yielding the dark "lagoon" area in M8. On M20 the 12.5 won easily - in both the 10 & the 8 it was a very dull object with no wow factor.
On M16 Eagle Nebulae the 8" could not find it. The 10" and 12.5 easily found it, and there was not much difference between the two scopes.
How about M57 Ring Nebulae? You can see it in the 8; it's a tiny specs with a slightly darker center. But you can't "observe" and study it. On Ring aperture difference between the 8 and the others was very evident. Even on the 10 the difference between it and the 12.5 was very clear. The 12.5 yielded very very large and detailed image of The Ring and the low magnitute star just outside the ring was brighter in the 12.5 on a night of marginal seeing. Still, on a better night of seeing the difference was a lot smaller. I'd still have no hope of seeing the 15th mag star in middle in the 10, nor the other two faint stars in the smokey ring, but with the 12.5 you can spend an evening looking for them.
On M27 Dumbbell I saw a big difference between the 8 and the others. Dumbbell, IMHO, always takes magnification well. But with the 8" the image is still small. I got a huge image in both the 10 & the 12.5 and they were very similar. I could not pick a winner between the 10 & the 12.5 on M27 Dumbbell.
NGC 6960/6992/6995 Veil is best viewed in the 12.5. It will take your breath away on a dark nite with good seeing. The 10 does well, but not as well as the bigger scope. The 8 did about as well as the 10.
M31 Andromeda - I prefer the 10" f/4.5. On a good night the core was bright and you could see dust lanes - image was very comparable to the 12.5. The 10 gave a great image even with a higher mag 21mm Hyperion ep: I could frame M31 M32 & M110 all in same fov in that ep, get a lot of magnification on M31, and still get a wide fov. It was one of best objects I observed, and it was best in the 10.
Conclusions: the 12.5 may be be the best overall "small" size scope in terms of portability vs aperture and resolution. If size is a concern, the the 10 is a remarkable scope and will yield a lifetime of pleasing evenings under dark skies. You WILL NOT be disappointed with a 10" fast reflector, but you may be disappointed with an 8" and get aperture fever quickly. From my comparisons, there is not much difference in size, easy of transport, and cost between an 8 & a 10 but there is a huge difference in performance. The 8 I used was nice with excellent optics, but it comes up lacking in terms of performance on DSO's.
I will qualify my conclusions by stating that one variable - focal ratio - was not the same in the 3 scopes. The 8" was f/6 and 10 was f/4.5, while 12.5 was f/5. This is a factor on some objects, yielding a larger fov on such objects as open clusters and M31.
Hope this helps all y'all out there contemplating a scope purchase and you're looking at these sizes.
bsim
Reged: 01/04/08
Loc: New York City
Thanks for the detailed report. Besides the aperture difference, it shows how good the Zambuto mirror is. Was the 12.5" a Starmaster?
Teeter's 10" F/6 Truss Dob / Sky Commander DSC / Round Table Platform
Celestron C80ED / MoonLite CF Tri-Knob
William Optics ZS66, Orion XT8i, Orion XT4.5
Canon 10x30 IS, Constellation View 2.3x40 Bino
Astro-Tech Voyager, Bogen 3011 & 3036, UA MicroStar Deluxe
Howie Glatter Laser & tuBlug
13 & 8 Ethos, 35 & 24 Panoptic, Nagler 3-6 Zoom, TV 8-24 Zoom
walt r
Reged: 02/13/07
Loc: Doylestown, PA
A nice report that was very objective.
-------------------- Walt
Obsession 18" f/4.45 #1370 AN/SC
MK67 Deluxe 6" f/12 Mak-Cass, Super Polaris GEM, JMI MicroMax DSC
DIY 60mm f/6 Achromat
Cookbook 245 CCD
Dom
Reged: 12/28/07
thnx, a lot of help 4 a beginner like me.Anyone else have input,3 scopes dark,medium,lightskies? Dom
Edited by Dom (09/01/08 08:21 PM)
jdownie
Reged: 02/24/06
Since the Zambuto mirror was also the largest, it is not possible to differentially infer much about any potential quality advantage versus aperture-driven advantages. One would need to compare mirrors of the same aperture to draw any conclusions about relative mirror quality.
John
-------------------- ATM project - a terrible waste of good Pyrex.
bsim
Reged: 01/04/08
Loc: New York City
I would assert that the Zambuto mirror of the 12.5" had the highest Strehl ratio. I've viewed through scopes of equal aperture with Zambuto and other premium mirrors. The Zambuto mirrors were the best hands down in everything from DSOs to planets. Zambuto has a reputation for being the best of the best and rightly so.
Lard Greystoke
Reged: 07/27/08
Loc: Ohio
Very useful report. Since you were so good at it, here's another assignment (should you choose to accept it): the same thing with 16, 18 and 20". That should keep you busy for a while. Chop chop!
-------------------- Lard Greystoke
10" Odyssey Compact
"With Tantor, the elephant, he made friends. How? Ask me not."
InkDark
Reged: 10/29/07
Loc: Montreal, Canada
Thanks for this very good report!
-------------------- Jimmy
"Rarely Have So Many Understood So Little About So Much" - Palle Yourgrau
"...since that time, I have not complained about the weather one single time. I’m glad there is weather." – Alan Bean, Apollo 12
Mark Harry
Reged: 09/05/05
Loc: Northeast
I was out with my 8", finally on a very nice DSO night. Jupiter was a washout, too much soup down low. Inky black outside, no moon, and no clouds for once this summer. I saw the swan, and was in awe of the shape. Very plain to me, but it lacked the brightness that a 14" would have given it. But detail and shape were all there. ***** Another interesting stop, I was panning through the galaxy lane, and was absolutely awestruck. I stopped at a "dark nebula" very plain, and obviously not just a hole through the stars. This had some background brightness compared to outside the lane, where last night you could easily tell really black "nothing" from obscuring dust clouds. To me, last night here, would have been excellent for -any- type of aperture you happened to have. But your report is very accurate, ime. A wonderful, memorable night! Regards, Mark
-------------------- Scopes in the works-
Too many for putting down here! Favorites- 8" F/6, 8" F/4.72, 4.5" F/5.4, 14" F/4.455, all completed.
markleewebb
Reged: 11/04/06
Yes. This was not a technical report comparing mirrors or quality of optics. It was an observing report comparing aperture. The differences noted are due to aperture not mirror quality.
I'll leave comparisons of mirror quality to the technical gurus.
The intent was to give an honest appraisal of what you can and can't see in these 3 mirror sizes, since there is always a lot of discussion about what scope to buy based on what you can see and observe.
greenough1
Reged: 01/04/08
Loc: Livermore, CA
Very interesting and generally very useful post. I've been looking at nebula recently and last night found M17 using my XT6, 15mm and 20mm SWA EP's with a Baader UHC filter (filter required for this object). At 80x, I had a very nice framed image of the Swan body and neck with direct vision. Maybe I just got lucky, but a 6'', IMO, did pretty well on it. This isn't a criticism, but rather a YMMV issue ;-) Thanks again, jeff
-------------------- Orion XT6i (f/8) w/ COL
Philips SPC900
Edited by greenough1 (09/02/08 10:17 AM)
jdownie
Reged: 02/24/06
I am not saying that Zambuto mirrors are not excellent, nor that the one in the test wasn't the best. I was just pointing out, logically, that one could not infer a quality advantage of the Zambuto due to the fact that it was also the largest mirror.
John
bsim
Reged: 01/04/08
Loc: New York City
Well, logically there are many variables here. If all things were equal except the aperture then it would be logically valid. Besides aperture there are other variables such as mirror quality, collimation and cooling which are just as critical. Recently, my 8" Orion beat a 18" Obsession in viewing Jupiter. Why? Because of cooling and collimation issues. So, logically it's not as simple as you make it out to be. I think logically the only thing we can say about the original post is that a certain percentage of the difference between the views can be attributed to aperture. The rest can be attributed to other factors such as collimation, cooling, seeing, transparency, and mirror quality. In the real world, smaller aperture instruments can beat larger ones because of collimation. cooling issues and mirror quality. I see it all the time.
Edited by bsim (09/02/08 04:26 PM)
luu5
Reged: 08/07/08
Loc: Duluth, GA
I am little bit surprised about this, as I am quite sure I have seen M16 in 20x80 binoculars?!?!
-------------------- 10" DIY Dob, SW80ED, Lidl 70/700, TS 25x80
danm
Reged: 04/27/08
Loc: Northern California
Interesting report. One fault however might be that your 'scopes all have different focal lengths, and so with those EP's will give different images. Describing the images as large versus small gives a hint, if the focal lengths were the same they would all be the same size, just brighter or dimmer. You need to put the same eyepiece on two scopes, both which have the same focal length to fairly compare them. I suspect the differences your seeing are more focal length related. You do have a caveat that the focal ratio's are different, but they have to be to be able to use the same EP on them with the same resultant view - it's the focal length that has to be the same. Without doing the math the lineup might be something like 8" f/6, 10" f/5 and 12.5" f/4.
I have a 8" newt and a 12.5" dob (in process of building) with virtually the same focal length (f/6 to f/4), and both have premium optics. I'll report on how they fare, I'm expecting that the 12.5" will always win, since images will have better resolution and brightness. But who knows - maybe I'll be surprised.
-------------------- TV Ethos 13mm
Oberwerk Ultra 15x70
Celestron C6 f/10 & AT Voyager Alt/Az mount
8" f/6.3 Newtonian (Dad's ATM) & AT66 red tube
12.5" f/4.1 Telekit (Dad's ATM Mirror)
Lard Greystoke
Reged: 07/27/08
Loc: Ohio
M16 has a cluster, which is easy, and nebulosity, which is not.
10" Odyssey Compact
Mark Harry
Reged: 09/05/05
Loc: Northeast
"with virtually the same focal length (f/6 to f/4), and both have premium optics. " ******** I've done one better. I have a 14" being shipped back from the coater, and a 6" mirror, both the same focal length on purpose. I want to see just what such a wide disparity of aperture will actually do to what's detectable/pleasing, or any other characteristic I could think of. Take me a while to get both together for a look. M.
danm
Reged: 04/27/08
Yikes - 6" versus 14", why don't you just use the 6 incher as a spotter for the 14?
The focal lengths on mine are an accident - or maybe not. My Dad picked f/4 for the 12 (30 years ago!) because somebody told him he would get remarkable views through it. Not sure what he meant by that, as I said it should look the same as through the 8", just brighter and more resolved (but that's a big 'just').
luu5
Reged: 08/07/08
Loc: Duluth, GA
The hazy bunch of stars really imitated nebulosity well... I guess same goes with M17?
jsiska
Reged: 07/12/06
Unless the 10" mirror was refigured, it may not be a research grade mirror. As I understand it all Meade Research grade mirrors - the 8", 10", and the 12.5" all came with an advertized focal ratio of f/6.
Jim -------------- GPDX-C102F with Moonlite Motorized focuesr. Meade 880, 8” f/6 RG Reflector. Meade 10" f/4.5 Starfinder dob. 1962 60mm, f/11.7 Tasco 9TE with custom visual back remounted on a GEM.
13 registered and 7 anonymous users are browsing this forum.
Moderator: Don W, werewolf6977, Jason B
