Pages: 1 | 2 | 3 | (show all)
Mike Conley
Reged: 09/23/07
Loc: NW Ohio
Another Collimation Question
      #2618798 - 09/02/08 11:08 AM
I have a telescoping truss ( 3 poles ) dob. I've collimated it using a glatter single laser/blug and combination tool. First I centered the secondary under the focuser using the sight tube. I noticed yesterday it was a little to one side and I mean a tiny bit. Now the only way I can get it perfectly centered is to 1. adjust the spider, moving the seconday off center. 2. adjust the focuser levelers. 3. tilt the seconday quite a bit to one side. I chose to try leveling the focuser ( moonlight ). I then collimated with the single beam, followed by the blug for the primary. Everything lines up great. Took the scope out last night, great views, but. Star test shows one side of unfocused star, secondary shadow offset and very noticeable. It seems that my focuser and secondary ( when its centered )are not lined up. Should I go back and just tilt the seconday to make up for it or move the seconday over, using the adjustments for the spider? Since this is custom built ( not by me ), there's no way to know if the top ring and primary cell are perfectly in line. Thought i had it , until I saw that secondary shadow.
Thanks Mike
Jason D
Reged: 10/21/06
Loc: California
Re: Another Collimation Question new [Re: Mike Conley]
      #2618854 - 09/02/08 11:29 AM
If you defocus little too much and you have a fast scope then the secondary shadow in the star test image will be skewed -- that is normal. To star test your collimation, defocus a little at high mag.
Jason
XT10 classic with premium optics
Tri-knob CR2 with compression rings
Round Table Platform
4.5" StarBlast
6" StarBlast6
TV EPs
Mike Conley
Reged: 09/23/07
Loc: NW Ohio
Re: Another Collimation Question new [Re: Jason D]
      #2618908 - 09/02/08 11:56 AM
Hi Jason,
Should it match on both sides of focus? It's centered on one side and skewed on the other side. As a test, I just backed out the focuser adjusters ,putting it flat. I centered the secondary again, which took a severe tilt to one side. I used the laser to center spot the primary and had to tilt it back to do so, so it's not tilted anymore. I collimated using the laser/blug combination. I then decided to check the secondary position with the sight tube and it's off to one side. It's nice and round and looks like it's sitting straight, just to one side. Is it time to offset the whole secondary to one side using the spider adjustments?
Thanks Mike
Starman1
Vendor - Scope City
Reged: 06/24/03
Loc: Los Angeles
      #2619330 - 09/02/08 03:44 PM
A little explanation of concepts, here:
If the secondary is off-center in the tube (let's say severely), then collimating would tilt the primary toward one side of the tube, and the focuser would be aimed at the secondary (wherever it is), and the intersect angle for the optical axis at the secondary could be 90 degrees or another angle.
All of this won't matter for collimation. Collimation is making the focuser axis coincident with the optical axis, adjusting the secondary to have the optical axis hit the center of the primary, and adjusting the primary to make its optical axis coincide with the secondary so light rays go straight up the focuser.
All the rest is an attempt to have the light evenly illuminate the edge of the field all the way around.
We center the secondary under the focuser so its edge evenly illuminates the focal plane of the eyepiece. We try to get the primary optical axis close to that of the mechanical centerline of the tube so that the tube opening evenly illuminates the primary mirror all the way around.
But collimating doesn't require even illumination of the field (unless you consider that part of collimation, which I do--I call it mechanical collimation rather than optical collimation, and both are important, but for different reasons).
So if the shadow of the secondary moves as you move the focuser, it is probably (not always) because the focuser axis is not aligned with the optical axis.
Your original post showed that there are several ways to interpret what you see in the focuser. You chose to change the alignment of the focuser to point it at the secondary. Fine, that should have had no effect on collimation. I'll assume the secondary is centered and the laser hits dead center in the primary and the primary's reflected shadow of the centermark was centered on the Blug's bottom. OK, so far.
The optical axis may not coincide with the mechanical axis of the scope at this point, but it is collimated optically. An out-of-focus star image will show a tiny amount of offsetting to the secondary. It might not even be noticeable because the amount is only a tiny fraction of the secondary's diameter.
But you see it offset a lot? That shouldn't be unless something is grossly wrong. I did a thought experiment in which I moved the secondary halfway to the side of the tube, and the out of focus shadow of the secondary was oval instead of round, but it still appeared roughly centered.
So I think you haven't achieved collimation. Let's review the steps:
1) Center the secondary in the tube using a cardboard template and adjusting the spider vanes. Make certain all the collimation screws have equal amounts of threads showing.
2) Make sure the primary's centermark IS centered. Make sure the primary is centered in its cell.
3) Look down the focuser and adjust the rotation of the secondary until it appears round to the eye.
4) If close to centered in the focuser (using a sight tube),
you can center using the collimation screws. If not fairly close to already centered, you can adjust the tilt of the focuser to achieve the same. This may pose a conceptual difficulty, but as far as the optical path is concerned, both achieve the same thing.
5) align the secondary tilt using the laser. If the mirror moves off center in the focuser to do this, try adjusting the tilt of the focuser again. Repeat. Each time you repeat, the tilt adjustment of the secondary and the resultant realignment of the focuser will be less until you get to where both are good at the same time. You may have to choose between a centered secondary and a good laser beam adjustment of secondary tilt. CHOOSE THE TILT. Having the secondary perfectly centered is a recommendation but is not critical.
6) align the primary using the BLUG (or TUBLUG, or simple barlow).
7) Re-align the secondary. You may have to move it a bit.
8) Realign the primary.
9) Go back and forth as often as you need until both show collimation simultaneously. When both show perfect collimation at the same time, in my experience, even an autocollimator shows only very tiny errors.
10) Move the focuser in and out. The laser beam should hit the primary exactly through all the travel of the focuser.
If it does not, then the laser is being tilted in your focuser when it is being used to align the focuser axis to the secondary tilt.
A. You are tigtening it down with a setscrew? The tops of some focusers are not superlatively square.
B. You are using a 2" laser in a 2" focuser? If you're using a 1.25" laser in a 2" focuser, with an adapter, loosen the adapter while the laser is tight in the adapter and rotate the entire thing in the focuser. Laser beam move? Your adapter is not "square" and you cannot achieve collimation with it. Replace it.
So how will the shadow of the secondary appear in the out-of-focus star image? It will appear nearly centered, or centered exactly. The offset you've achieved is tiny (let's say 1/8" unless the scope is 20" and up), so the inexact nature of gauging the centering of the shadow will make it appear pretty much centered. And, more importantly, racking the focuser in and out through focus will not change the centering of that shadow. Though technically it will appear offset in opposite directions on either side of focus, the amount of offset really won't be easily seen. I don't notice it in an f/4 scope, so you probably won't either.
After going through the steps above, repost your results here. I'll be curious to see what happens.
Don
Don Pensack
12.5" Truss Dob, 5" Maksutov
Sustaining Lifetime IDA member, TeleVue junkie
Mike Conley
Reged: 09/23/07
Loc: NW Ohio
Re: Another Collimation Question new [Re: Starman1]
      #2619365 - 09/02/08 04:09 PM
I'm pretty certain I'll have to give up the secondary being perfectly aligned under the focuser to center the secondary in the upper cage/tube. I can still center the secondary by tilting it,but once I go through collimating and get perfect alignment with site tube and laser/blug. The secondary is back to being slightly offset under the focuser. What I'm trying to say,aligning with the site tube and laser/blug is returning me to where I started with the secondary just a tad bit to the right. I'll gothrough it again.
Thanks mike
Mike Conley
Reged: 09/23/07
Loc: NW Ohio
      #2619471 - 09/02/08 04:57 PM
When I said offset the seconday, I'm only talking 1/8". It's a 3 vain spider. The front vane to the focuser and one other vane are the same, the third vane is 1/8" shorter to allow me to center the secondary. When I sawthe shadow offset on the star last night I had the secondary centered. I just offset it today. When I saw one side of focus centered and the other side skewed quite a bit, i thought something is wrong. But who knows how well the top section is cut out. I mean its a wood ring, it could be off that much?
Thanks mike
Starman1
Vendor - Scope City
Reged: 06/24/03
Loc: Los Angeles
      #2619652 - 09/02/08 06:29 PM
I don't think it's your upper entrance to the scope that's off. I just think you don't yet have the focuser in line with the optical axis.
I had the same issue with my scope after I rebuilt the UTA--I had to choose between concentricity of the secondary-to-focuser drawtube or accurate alignment.
Or so I thought.
After iteration (several, if I recall), it was closer. So I repeated the same alignment again and again, and each time I had to make less of an adjustment in centering after adjusting the tilt.
Eventually, both were true at the same time--concentricity and alignment.
The autocollimator showed perfect collimation each time, so it's obvious that centering isn't necessary for perfect collimation.
Why iteration of the mechanical and optical alignment procedures brought both into agreement I'm not sure, but it did.
What I actually did was: sight tube, cheshire, autocollimator, sight tube, cheshire, autocollimator, etc.
Don Pensack
sixela
Reged: 12/23/04
Loc: Boechout, Belgium
      #2620598 - 09/03/08 04:36 AM
The secondary doesn't have to be perfectly centred in the tube. If it isn't the only possible effect is early vignetting by the front of the scope, but that's both rare and usually irrelevant (as front vignetting is very, very gradual and usually dwarved by vignetting by the secondary) unless things are *way* off. And on most scopes, the optimal position isn't centred in the tube anyway, but slightly offset away from the focuser.
No, you can't (I mean: you use confusing terminology). Moving the secondary can centre it under the focuser. Tilting it make the reflected focuser axis move, not the secondary.
Yes, you can move the secondary by using the three tilt screws, by adjusting them all in the same way, but that's not tilting the secondary.
*Always* end by making the reflected focuser axis point to the centre of the primary, not by trying to centre the outline of the secondary.
That's because having an uncentred secondary merely shifts the fully illuminated field slightly, while having the focuser axis point somewhere else than where it should tilts the focal plane (introduces defocus at the edge of wide fields, makes star tests unreliable out of focus, and makes it more critical for you to have used a Cheshire *exactly* at the focal plane to avoid other errors).
You guessed it: that part of the procedure *is* iterative. If you do things right, though, each time you go through this adjustments should become smaller.
There *is* a way to iterate and come back at the same point if you're not careful about the order in which you fix position, rotation and tilt of the secondary (and what you use to fix things).
Most of the time, when I see people iterate a lot, there's a gross rotational error that they aren't fixing by rotating the secondary properly.
It's also very easy to confuse the outline of the secondary and the edge of the primary's reflection. If you move the secondary to centre the primary's reflection you'll be toast.
It's *the* most frustrating part of collimation. It's also the least important. Fortunately, it's also the part you only have to do once (until someone knocks your spider out of place ). It also means it's perfectly OK to give up on perfect centring of the secondary if you're fed up with it (see above).
What works for me:
1) position the secondary until it appears centred (large adjustments: spider vanes and secondary holder bolts unless they grossly misplace the secondary, small adjustments: focuser collimation bolts)
2) rotate it so it appears as circular as possible
3) tilt it so the reflected focuser axis points towards the primary's centre.
Rinse, repeat, cycle, and *NEVER* change the order of the steps.
By the way: centring of the secondary should ideally be done from a vantage point in which the primary's reflection appears almost as large as the outline of the secondary. On fast scopes, if you rack the focuser in or out the apparent offset between the secondary's outline and the primary's reflection will change slightly.
400mm f/4.46 David Lukehurst truss Dobsonian on Tom Osypowski equatorial platform
Orion Starblast (114mm f/4 reflector, Alt/Az)
Mike Conley
Reged: 09/23/07
Loc: NW Ohio
Re: Another Collimation Question new [Re: sixela]
      #2623328 - 09/04/08 11:29 AM
Thanks for all the help. The way I centered the secondary was by placing paper below it and orange paper behind. This allowed me to see only the secondary under the focuser tube. Collimation was never a problem, just I always ended up with the seconday ever so slightly offset to the right, but perfectly round in appearance and everything aligned. I've worked on it a little more, by adjusting/leveling the focuser and racking in and out with the laser until I get the least amount of movement within the donut. Where I'm at now,
I have the seconday centered in the optical tube ( top ring on truss )
I have the secondary ever so slightly offset to the right under the focuser tube, meaning when I rack the focuser in to almost hide the area around the diagonal. I have a thin line on the left side.
I have the single beam centered in the donut with just a slight movement racking the focus in and out, much less than when I started.
I have a return barlowed beam on the blug face centered.
Thanks Mike
4stargazers
Reged: 07/13/08
Loc: colorado
      #2624737 - 09/05/08 12:02 AM
hey mike,
If I understand your problem correctly, after you collimate
everything seems to line up but when look back through your collimation cap your secondary is slightly misaligned. If this is the case I had the same thing happen to me, as it turned out my focuser was out of square. although my optical axis was aligned properly my mechanical axis was off. Others may have different thoughts on this but this is my take there's a lot of info on squaring your focuser on the web I just used good'ol trial and error took awhile but I got it fixed lol.
meade 4.5'' reflector
etx 60
orion XT8'' dobs
Sirius 40 mm plossl
Sirius 26 mm plossl
Sirius 10 mm plossl
Orion Ultrascopic 2x FMC
3-Element Barlow Lens
Telrad with dewshield plus
and the pulsing light
Mike Conley
Reged: 09/23/07
Loc: NW Ohio
Re: Another Collimation Question new [Re: 4stargazers]
      #2624995 - 09/05/08 06:50 AM
You may be right, I've been using the adjustments on the moonlight to square it. What I've found, it's easy to square up using the four set screws. You have to be careful though. The first time I did it was perfect until I rack the focuser in and out. That moved the laser from the center ( racked in ) to the outside edge ( racked out ). I kept working with it, now there is slight movement. I'm going to keep working with it until I notice no change .
Spaced
Reged: 03/01/05
Loc: Tacoma, Washington, USA
      #2627420 - 09/06/08 01:32 PM
This is a bit off topic, but perhaps germane to the quote.
I have a Catseye sight tube. It's length is adjustable such that, using a supplied ruler, I can make the f/ ratio of the sight tube the same as the f/ ratio of the mirror/scope. I've never understood the point of adjusting the f/ ratio of the sight tube, since I simply use it to assure the circular appearance and centering of the secondary, and I can move the sight tube in and out of the focuser so its apparent aperture through the peephole is barely larger than the apparent size of the focuser.
Why adjust the focal ratio of the sight tube?
P.S., Don, Alexis, Vic, Jason D: I'm constantly impressed and grateful for the time you spend helping people with collimation issues. Thanks!
Look! Up in the sky!
_____________________________
XT 10i - the i stands for Telrad
Megrez II 80 ED Triplet APO "Punk"
Siebert Black Night BVs
8 X 42 Celestron Regals
sixela
Reged: 12/23/04
Re: Another Collimation Question new [Re: Spaced]
      #2627514 - 09/06/08 02:27 PM
So that the sight tube's inner edge is almost as large as the secondary's outline *just* when the primary reflection is also almost as large as the outline of the secondary.
BTW, the ideal aspect ratio is often somewhat shorter or longer than the f/ratio -- depending on how the secondary is sized.
CatseyeMan
Vendor (Cats Eye Collimation)
Reged: 12/16/04
Loc: Huntsville, AL USA
      #2628580 - 09/07/08 08:16 AM
BTW, the ideal aspect ratio is often somewhat shorter than the f/ratio -- depending on how the secondary is sized.
It's not intuitive but if you go through the analysis you will actually find that to optimize the OTA axial position of an "oversize" Secondary, the "ideal" sight tube should in fact be "longer" and moved farther away from the focuser. This is purely an academic issue and quickly becomes impractical with much increase in Secondary size over the "single-point" 100% illumination number. The only time it might seriously be considered is in wide-format astrophotography scenarios where precise symmetrical contrast at the extreme edges of the image is the objective.
For visual users who can't effectively pull their sight tubes up far enough in the focuser to "see" the Secondary without compromising axial alignment of the tool itself, the better compromise is to shorten the tube to accomodate Secondary centering realizing the Secondary positioning is not "perfect" but is "close enough" that the error is below the threshold of visual detection in scope performance.
Jim Fly - Manufacturer
sixela
Reged: 12/23/04
Re: Another Collimation Question new [Re: CatseyeMan]
      #2628825 - 09/07/08 11:24 AM
Exactly -- with the pupil at the intersection of the extreme rays of the collection of light bundles through the illuminated field you want to optimise (picking nits).
I never think about it, given that you can pretty much *observe* what the good ratio is -- the one that allows you to make the inner edge, secondary outline, and primary reflection similar in size.
It does make quite a difference on a large f/4 Dob, in my experience. Even in my f/4.5, there is some difference in the offset towards the primary if I select a different vantage point from which to centre the outline of the secondary under the focuser.
But I'm being a nit, I know.
Jason D
Reged: 10/21/06
Loc: California
      #2628866 - 09/07/08 11:38 AM Attachment (13 downloads)
The attachment illustrates Jim's point.
If the peep hole of the sight-tube is close enough for the whole primary edge reflection to be seen smaller than the secondary edge (Xa), then centering the primary reflection within the secondary will NOT yield the optimal field illumination (Xb). That is, when angles A is the same as B and A' is the same as B' then C does not equal D.
By pulling the sight-tube away from the focuser to the point where the reflection of the primary edge coincides with the secondary edge (Ya), then illumination field will be optimized as shown in figure Y. Interestingly, if you move the peep hole of the sight-tube closer to the focal plane, the primary edge reflection will be slightly off-center with respect to the secondary edge (Yd).
Jason
4.5" StarBlast
6" StarBlast6
TV EPs
CatseyeMan
Reged: 12/16/04
      #2628935 - 09/07/08 12:17 PM
For any given "fixed-length" sight tube, yes I agree that this is the best practical approach.
My (academic) point was that for a given optical f-ratio and a given "oversize" Secondary mirror size, there is one and only "one" sight-tube f-ratio (slower than the optical one), that can facilitate (in theory) "exact" centering of the Secondary to also perfectly center the image ellipse on that Secondary.
sixela
Reged: 12/23/04
      #2629078 - 09/07/08 01:41 PM
I've got a TeleTube, Jim . With a fixed length tube, you can make *two* of the circles have a similar size - and for the third you'll have to just see where the chips fall.
You need an adjustable tool (or a fixed length tool that happens to have the correct aspect ratio) to make all *three* circles similar in size.
My point as well. But for imperfect sight tubes, one should check the offset also from the focuser/tool position which makes the outline of the secondary and the primary reflection similar in size, whatever that does to the tool's inner edge - after complete collimation, obviously, i.e. when the primary's reflection is also centred.
Otherwise, it's easy to set a slightly suboptimal offset towards the primary.
Sometimes, if your sight tube is too narrow, you might want to check with a collimation cap...
Spaced
Reged: 03/01/05
      #2629553 - 09/07/08 07:03 PM
That makes sense to me!
I don't understand why this should be (:headscratchgraemlin:), but perhaps understanding is not necessary to correct application.
So how does one determine what the correct f/ratio setting on the sight tube should be for a given primary/secondary ratio? Is the difference between the optimal and the nominal so slight that it really doesn't matter?
Starman1
Vendor - Scope City
Reged: 06/24/03
Loc: Los Angeles
Re: Another Collimation Question [Re: Spaced]
      #2629613 - 09/07/08 07:45 PM
The optimum centering condition of the secondary is to provide uniform illumination of the edge of the field for imaging or for large field stop eyepieces that utlize a larger portion of the scope's focal plane.
Given that uniform illumination is not critical for visual observing with most eyepieces, the discussion contained herein, and following, is somewhat academic.
Having the outlines nearly the same size makes for easier alignment.
But, when the autocollimator is used you have verification of exact collimation, whatever the edge illumination.
You should understand that centering the secondary is a shorthand way of saying, "provide proper offset of the diagonal".
If the secondary is centered under the focuser by moving it toward the primary, but not also by moving it away from the focuser, then the optical centerline is tilted ever so slightly toward the focuser, and the *effective* position of the secondary is offset away from the focuser as well as toward the primary, just as if you had performed classical offsetting.[there is a slight difference in intercept angle at the secondary, but negligible for this discussion]
In other words, moving the secondary off center and away from the focuser(classical offsetting) to achieve offset is simply accomplished more easily.
The negatives to this technique are:
--the optical centerline and mechanical centerline are no longer coincident, meaning some DSCs may have trouble finding things exactly
--one side of the front opening of the telescope will cutoff more light than the other, resulting in uneven field edge illumination IF the upper opening of the scope is not properly chosen. A lot of contemporary telescopes have openings that are too small to avoid vignetting using this collimation technique. The lateral vignetting may be detectable in an image--it is unlikely to be visible visually. If the opening of your scope is smaller than the primary size plus the field stop of your largest field stop eyepiece, this "New Method" collimation procedure may introduce visible vignetting on one side of the field of view. [Note I said "may". It probably won't].
Don Pensack
14 registered and 5 anonymous users are browsing this forum.
Moderator:  Don W, werewolf6977, Jason B
Home
