Observing >> Planetary and Solar System Observing
Deepskydave
Reged: 06/27/08
Loc: Waltham, MA, USA
Re: Neptune new [Re: Deepskydave]
      #2565404 - 08/07/08 01:18 AM
You should try www.Stellarium.org instead.
Dave
"Miranda" Nextstar 8i SE XLT
Proxima 8-24mm Zoom
OPT OIII
Vector 19ah Power Tank
Stellarvue 1.25" 99% Refelctive Diagonal
Wing Thing
Deepskydave
Reged: 06/27/08
      #2565405 - 08/07/08 01:19 AM
You should also check out www.stellarium.org for the software.
Dave
Proxima 8-24mm Zoom
OPT OIII
Wing Thing
Rick Woods
Reged: 01/27/05
Loc: Inner Solar System
Re: Neptune new [Re: JakeT93]
      #2565561 - 08/07/08 05:55 AM
My next challenge is to find Mercury, my horizons aint the best, maybe around 3-6 degrees off the SW I can see, and 2-4 off the S.
Try for Mercury during one of its westerly (morning) elongations. Find it in the twilight, and follow it up into the daytime sky. Use high power, and a red filter if you have one. You might be surprised at how much you can see!
- Rick
14" LX200GPS
8" Meade 826C
AZStarGuy
Reged: 05/05/08
Loc: Scottsdale AZ
Re: Neptune new [Re: Rick Woods]
      #2568374 - 08/08/08 12:13 PM
Thanks for the Stellarium tip guys! I'm going to give that a try - now if the cloudy monsoons would blow out of here I might have a shot at Neptune!
Ron
8" f6 Eq Newt
24PAN, 13T6,7T1,6RAD,5RAD,4 & 3.2 Planetaries
planetman83
Reged: 09/17/07
Loc: Greece-Crete
Re: Neptune new [Re: AZStarGuy]
      #2580323 - 08/14/08 06:27 AM
If I want to find Uranus or Neptune or some comet I just write down the coordinates of the object. If you have a good map (if you are a real deep sky observer you definitely have one), you can find them fast. Uranus and Neptune are dots in the finder that don't exist in the maps. Pluto is an exception as it is very difficult and you need a very detailed piece of map.
Thunderhead
Reged: 08/27/05
Loc: Melbourne, Australia
      #2584873 - 08/16/08 11:27 AM
Both Uranus and Neptune transit at the zenith here, and once this horrible winter clears I'll pump up the mag! I've seen both planets in my 10", Uranus is a tiny disk and greenish at 300x while Neptune is a tiny blue orb at the same mag.
I've yet to try for the moons.
SAB - Melbourne, Australia
GSO 10" F5 Dob with flocking & dewshield
12" (304mm) F4.6 truss dob with premium optics
Zhengyi
Reged: 12/28/04
Loc: Ontario, Canada
Re: Neptune new [Re: Thunderhead]
      #2595731 - 08/21/08 05:15 PM
I was taking test images on Tuesday night around 23:02EDT, Neptune was my test subject. And I noticed something zoomed across the field. Anyone else saw it?
Animation
TMB 115/805 LW
William Optics 80mm SD / Alt-Az 3
Exit-pupil
Reged: 11/13/07
Loc: Eastern Long Island, NY
Re: Neptune new [Re: Zhengyi]
      #2600292 - 08/24/08 11:41 AM
I don't know what that was, but last night I was just cruising the sky wide-field and spotted some space junk - brightening (maybe 8th magnitude?) and fading about every three to four seconds - just tumbling. There's a lot of junk up there.
As for Neptune, I'm wondering if I spotted Triton last night. I saw two dots; one about three diameters away at the 3 o'clock position and another at the 11 o'clock position about twice the distance. This was through a 6" refractor using a diagonal, so the real placement would be at the 9 o'clock and 1 o'clock positions, respectively. I could detect them only using averted vision.
Jono
Booji
Reged: 10/12/07
Loc: North Carolina, USA
Re: Neptune new [Re: David Knisely]
      #2620518 - 09/03/08 02:18 AM
[I can just make out the disk and a hint of limb darkening in my 8 inch]
This is what I saw tonight at 417X with my 8" reflector, I found that by using averted vision I could make out the edge of the disk much more easily. I did not think the sky would take that much mag tonight, but there was a few minutes of good seeing now and then.
Be seeing you,
Booji
Losmandy G11 non GOTO
Vixen GPD2
Vixen FL102S APO
Edmund Scientific 8" reflector (red tube)
Vixen VMC110L
Fujinon 7x50 FMTR-SX Binos
astro_anthro
Reged: 03/05/08
Loc: Reno, NV
Re: Neptune [Re: AZStarGuy]
      #2622787 - 09/04/08 02:20 AM
I had been struggling to find Neptune and Uranus myself when I found this thread and the Stellarium suggestion. Using it on my laptop in conjunction with my binocs and, of course, my telescope I was able to find both within minutes of looking for them. Great program. Wow, I sound like an ad! Clear skies! Tom
Tom N.
2 registered and 2 anonymous users are browsing this forum.
Moderator:  kfred, Tom L
Home
