Charlie HeinModerator
Reged: 11/02/03
Loc: 26.06.08N, +80.23.08W
Aug08 CN Imaging/Sketching Contest Poll!
      #2622922 - 09/04/08 07:02 AM
We are very pleased and proud to present the August 2008 Solar System Imaging Semi-Finalists in the Imaging/Sketching Contest.
Bart Declercq:
My submission is the area from Rupes Recta to Werner on the moon.
The image is a mosaic of images taken using a Celestron C9.25 at F/16 (FL 3800mm), using an Imaging Source DMK31 camera, operating at 30fps through an Astronomik Red filter.
The image consists of about 6 separate AVI's, each originally 2000 frames long, multi-aligned in Registax selecting the best 256 frames per alignment point, with about 20-25 alignment points per AVI.
The image was taken from Haaltert, Belgium (N 50.885°, E 4.015°) on 2008-07-24 at approximately 3h50UT. The moon was about 45° high in the sky and the seeing was decent, though not very good (hence the use of a Red filter and the relatively short FL)
Mick Hyde:
Moons Southern Highlands - 23rd Aug 2008 - 3:30am
Bad to average seeing.
Equipment: C9.25, 2.5x TV Powerview, DMK21AF04AS, Celestron Skylight and red.
25 x 1000 frame avi, best 300 processed in Registax and photomerged in CS3.
Lunatiki:
From 08-26-2008
Jupiter and Europa
Equipment 8 inch SCT
2x barlow
DBK21AF04.AS
K3ccd/Registax4/PSP8
1000 frames stacked.
Mike Phillips:
Jupiter's moons, Ganymede and Callisto transiting on 2008-08-05: from 0218 to 0403 UT.
Quickly processed animation of 18 frames from about 6 minutes apart and 60s per RGB-channel each.
I used:
Ubuntu Linux and coriander
8" Celestron C8i SCT
DMK 21AF04
2.5x PowerMate
Astronomik LRGB filters
True Tek Color Filter Wheel with visu diag
HANTO:
Jupiter accompanied by 3 of his moons (Ganymede, Callisto, Europa listed from left to right).
8-in Newton @ f/19.6 mounted on Losmandy G11.
LRGB with L = 0.5R + 0.5G, Astronomik RGB, DMK21AF04.AS.
Good to very good seeing.
Please note that voting will conclude on September 8th at Midnight EST.
Many thanks to all who took part in the contest!
Which Image goes to the finals?
Users may choose only one (18 total votes)
Bart Declercq:
8 44%
Mick Hyde:
6 33%
Lunatiki:
3 16%
Mike Phillips:
1 05%
HANTO:
0 0%
Weston CSC:
2 registered and 8 anonymous users are browsing this forum.
Home
