Doug Barrett
newbie
Reged: 01/14/07
Loc: Colo. Spgs., CO
32mm tv's new
      #2610095 - 08/28/08 04:50 PM
I have a standard Denkmeier BV on a Micro Intes 606 Mak/Cass scope and use 32mm TV eyepieces. My problem is the interpupillary distance and eye placement needs to be exact or I get blackout. I am thinking of 24mm Hyperions, but would like imput. Do the Hyperions pinch your nose due to the diameter of the eyepiece? I realize this will vary from person to person, but would like some feed back. I also would like feed back on vignetting, as the Denk. has 26mm clear aperture and the Hyperion has 29mm.
Teal'c
Indeed
Reged: 08/02/05
Loc: TN
Re: 32mm tv's new [Re: Doug Barrett]
      #2610555 - 08/28/08 08:13 PM
I'm using the 24mm Hyperions with the Denk II/PS and have had no problems with spacing. Also, for some reason, the smaller lens of the 24 makes it easier to view (eye placement) than my 17mm Hyperions. I really haven't seen any noticeable vignetting.
Welcome to CN
Etch-O-Sketch and an eraser. Although....the eraser dosn't work
Edited by Teal'c (08/28/08 08:15 PM)
ckwastro
Reged: 11/23/05
Loc: AZ
Re: 32mm tv's new [Re: Teal'c]
      #2621354 - 09/03/08 12:35 PM
I use the 24 Hyps with the Denk Std / PS and have had no issues either. My IP distance is about 64mm.
Kerry
  • 92mm AP Stowaway (f/7 version, uh...actually f/6.57 )
  • Giro 3 Twin View
  • 10" f/5.4 dob w/Spooner primary
  • Tom O. Platform
  • 10x42 Audubon Equinox
  • Bogen 3221 tripod / 3047 3-Way Head
  • Denk Std BV
Joe Ogiba
Reged: 02/14/02
Loc: NJ USA
      #2621534 - 09/03/08 02:07 PM
Eyepieces with larger than a 26mm fieldstop will vignette in a Denk II when using it in Starsweeper/focal reducer mode (.66x) but I have not seen any vignetting in normal 1x mode even with my 20mm Widescan III with 84° AFOV in my Denk II.
Pentax PF-80ED
Meade 102ED APO
Orion EON 72
120ST
Apex 127
C6 XLT
CR150
C9.25
XT10
Zeiss 7x42 FL
Canon 10x42L IS WP
15x50 IS
12x36 IS II
Garrett Optical 28x110 HD-WP Signature Series
Oberwerk BT-80 45
Apogee RA-88-SA
Denk II Power x Switch binoviewer w/13mm Ethos, 20mm Pentax XW's, 20mm Widescan III's.
Jeff B
Reged: 12/30/06
Re: 32mm tv's [Re: Joe Ogiba]
      #2625078 - 09/05/08 08:31 AM
I had the same problem. Broke my nose in highschool so I've a ridge that gets in the way PLUS a narrow IPD and the 32MM's were tight. Removing the rubber eye cups does help. Also, there will be a bit of light loss at the edge of the field. However, they do give you just about the max TFOV possible with the 1.25" format eyepiece and they are sharp.
The 24mm Hyperions should be ok.
If I may suggest, the good old RKE 28MM or the Edmund 28MM Plossl version are excellent low power choices.
Jeff
2 registered and 1 anonymous users are browsing this forum.
Moderator:  EdZ, jrcrilly
Home
