Privacy Policy |
Please read our Terms
of Service | Signup and
WadeVC
Reged: 12/02/05
Loc: Lodi, California,
A nice double star found in Aquila, V1466 Aql isn't overly spectacular in regards to contrasting colors or possessing any other sort of "WOW" factor, but its secondary star is quite faint compared to the primary. I would consider this a good "semi-challenge" double for splitting for those just starting out observing doubles.
NOTE: I am not 100 percent positive that I have identified the correct name of this double. After checking Cartes du Ciel, this is the double star I sketched, but checking the name/info against SIMBAD describes V1466 Aql as a Variable Star.
Orion XTi10 f/4.7
Orion XTi8 f/5.9
Meade NGC 70mm f/10
Orion UltraView 10x50 Wide-Angle Binoculars
My Sketch Gallery
My Astronomy Blog
A wise man can see more from the bottom of a well than a fool can from a mountain top.
Reged: 06/13/06
Loc: Illinois
Wade,
Excellent sketch. Very nice target choice. Close pairs of stars of unequal brightness always stop me as I am sweeping to a target.
Frank
-------------------- my gallery
CarlosEH
Reged: 01/19/05
Loc: Pembroke Pines, Broward County...
Wade,
An excellent observation of an interesting double star in Aquila. The primary star measures 6.5 magnitude and the fainter component at 10.5 ( a magnitude difference of 4). The two stars are separated by 13.5 arc-seconds. A variable star database ( http://www.alcyone.de/SIT/bsc/HR7572.html ) lists it as a variable star as well with a variation of 0.6 magnitude (6.50 to 6.56). V1466 was discovered by the famous German-Russian astronomer Friedrich Georg Wilhelm von Struve (aka Wilhelm Struve, 1793-1864) using the Dorpat Refractor (9.5 inches (24 cm)). Thank you for sharing this with us all. The image below courtesy of Starry Night Pro.
Link; http://www.alcyone.de/SIT/bsc/HR7572.html
Carlos
rodelaet
Reged: 04/28/06
Loc: 50°56' N - 4°58' E (Belgium)
Wade,
A beautiful sketch of a careful study!
The difference in brightness is striking in your sketch.
-------------------- Rony
My Astronomical Sketches
My Binocular Sketches
Callibrate your Monitor with this little strip.
WadeVC
Reged: 12/02/05
Thank you for all the kind words everyone.
Carlos, thank you for the info and links...much appreciated!
Orion XTi10 f/4.7
Orion XTi8 f/5.9
Meade NGC 70mm f/10
My Sketch Gallery
My Astronomy Blog
rolandlinda3
Reged: 01/24/06
Loc: Crozet VA 22932
Very good, Wade. I will look for this, too. I had not noticed it. Roland
-------------------- Roland
Sketches in members galleries: rolandlinda3
Inspirational stories/sketches at:
www.christworksministries.org
0 registered and 2 anonymous users are browsing this forum.
Moderator: Charlie Hein, cildarith
