Privacy Policy |
Please read our Terms
of Service | Signup and
Dragonwatcher
Reged: 01/21/08
Loc: Kirkland, WA
I have an Astro-Tech Voyager alt-az coming. If I want a longer control for the slo-mo, anyone done this successfully and inexpensively and can recommend a site to purchase? Thanks in advance.
GlenM
Reged: 05/20/07
Loc: 53° 36'N 2° 06'W
Jackie,
I think the Vixen ones will fit.
Hope this helps a little.
-------------------- Glen
Dragonwatcher
Reged: 01/21/08
Loc: Kirkland, WA
Glen,
Thanks. That would make it easy, as I know where they can be purchased.
-------------------- Jackie
Pentax 80ED for ship watching
SV80L for grabNgo
Tak FS102 for longer sessions
TV 85
Dragonwatcher
Reged: 01/21/08
Loc: Kirkland, WA
Ooh... I went to the Astronomics site and found an Antares slo-mo cable that works with the Vixen and it says it will not work with the Voyager!
"This flexible manual slow motion control cable is 13.5" long. It will work on the 6mm diameter declination or right ascension control shafts of most imported altazimuth and German equatorial mounts from Japan and China, including those from Vixen, Celestron, Sky Instruments, Orion, etc. It is not usable with the Astro-Tech Voyager altazimuth mount (#ATV), which has larger diameter (7.5mm) slow motion shafts than the above-mentioned mounts." - From Astronomics web site page on Antares slo-mo cable.
Evidently not all slo-mo cables are compatible????
SV80L for grabNgo
TV 85
GlenM
Reged: 05/20/07
Hi Jackie,
I tried one that came with my Vixen GP2 (bought in the UK) and it fit no problem
Hope you get sorted soon and apologies for the duff info.
Clear Skies.
Dragonwatcher
Reged: 01/21/08
Loc: Kirkland, WA
Glen, No problem. I would have responded the same as you given the circumstances. Perhaps you are still right... I just need to contact Astro-Tech perhaps.
SV80L for grabNgo
TV 85
Hermie
Reged: 04/20/05
Loc: On the way to SYD
I can confirm the Antares control won't fit - the AT voyager control shaft is about 1 mm too big. I haven't found an alternative yet, but I've heard that some do work.
Hermie
-------------------- APM 105/650
GlenM
Reged: 05/20/07
Thanks Jackie,
Enjoy the Winter wonders to come.
16 registered and 12 anonymous users are browsing this forum.
Moderator: Charlie Hein, FAB
