Privacy Policy |
Please read our Terms
of Service | Signup and
stevek
Reged: 04/16/06
Loc: west michigan
Skies were pretty crummy/hazy here last night but I was suffering from the need to get out my scope so i did, here in my suburban driveway. I started with M31 and ran thru a bunch of open clusters in Cassiopeia. I decided to hit a few targets I hadnt seen in a long while and moved over to the Blue Snowball/ngc7662.
Ngc7662/ Blue Snowball: (in AND) Super bright. Easily visible with some structure at 300 & 400x, with & without the NPB filter. Showed as an annular but not really round with uneven patches of brightness along edge of ring. Center was slightly darker. No central star seen.
I'd forgotten what a nice target this was!...Then, Moved over to M52 - I havent looked there in at least a year...
M52: (in CAS) Pretty nice open cluster. Fair size with uneven spread of small stars. Resolved ~ 100*
I thought I was doing pretty well considering the conditions so I came in to peek at Stellarium and see if there were other targets nearby and saw ngc7635/bubble neb right next to it.
ngc7635/Bubble Neb: (in CAS) hmmm...Nothing there until adding NPB filter. very faint/low surf brightness. Had to stay at EP and pan around to finally see something??? It appears to be a large neb, as i noticed darker areas outside the region while panning in. More obvious at 56X than 92X. Definitely brighter section appears to include small bright star just off even brighter nearby star (sorry I lost my sense of direction up at zenith). Larger portion to 'right' was dimmer and small to left was brighter. Possible patches of brighter neb out away from the included star but not vis in direct, avert only. No bubble seen.
I guess my ? is.... (I didnt go look it up yet. I wanted to get other impressions before I searched more detail)... What does this look like in an 8"? I really got the impression it was larger than I could truly resolve. The shape was irregular, tending 'lengthwise' above the brightest star nearby, sometimes giving a hint it may extend down to it. But no bubble???? Others impressions please.
Steve
edited to include constellation IDs - noticed in another thread this is preferred
-------------------- DSO 8" f6 DOB w/ 8x50 RACI & 2"Crayford
1958 Sears Discoverer 76mm Refractor
GSO SV 30mm 2",21mm Hyp,13mm Strat,BO/TMB 6mm&4mm
1.25"Filters: DGM-NPB, 25%ND
1.25" plossls: 25mm,20mm,15mm,9mm
Orion 2X Shorty Barlow
Garrett Gemini LW 11x56mm binocs
cheap $10 green laser pointer(hongkong express)
"What is that burning in the sky? Tell me y'all..." Jeff Beck/Jan Hammer
Edited by stevek (09/24/08 12:01 PM)
David Knisely
Reged: 04/19/04
Loc: Beatrice, Nebraska
Hi there. The "Bubble" nebula (NGC 7635) has a very faint patchy outer band of nebulosity that I first saw in my 10 inch with the UHC filter. It is well beyond the part of the nebula that has the "bubble" and extends from northwest to southeast for about 16 arc minutes. In the middle is the brighter patch which is the brightest northern part of the "bubble". It goes through a magnitude 8.7 star roughly from east to west, and appears as just a small diffuse oval of nebulosity with a bit more "pointed" eastern end that may show just a little curvature. Just to the north-northeast of this patch is a fainter "V" shaped patch. That is about all you will probably see of the "bubble" unless you are using a fairly good-sized telescope. Clear skies to you.
stevek
Reged: 04/16/06
Loc: west michigan
Sounds like what I saw. Fun target that takes some close attention to 'catch'. Thanks David! and clear skies back at you  Steve
9 registered and 2 anonymous users are browsing this forum.
Moderator: Dave Mitsky, Olivier Biot
