Astrophotography and Sketching >> Beginning Imaging
Patrick
Reged: 05/16/03
Loc: Franklin, Ohio
WCS Drift Alignment Software Problem
      #2661244 - 09/24/08 06:50 PM
I installed DSI-WCS drift alignment software on my Vista laptop and am getting a Microsoft.NET Framework error message that says the application is attempting to perform an operation not allowed by the security policy. The operation required the SecurityException. The options are to continue or quit. If I hit continue it brings up the WSC menu but doesn't recognize my DSI that's hooked up to the computer.
The Meade DSI is working with PHD Guiding so I know that part is okay.
I don't have a clue what that means or how to correct it. I do have the Microsoft.NET Framework 1.1 running on the computer.
Will WCS run on a Vista machine?
Patrick
Discovery 10" f/6 Split Tube Dob
Celestron C6 SCT
Denk Binoviewers
AT66ED Refractor
Oberwerk Ultra 15x70 Binocular
475B Geared Tripod & 501HDV Head
Oberwerk 9x60 Binocular
Celestron Regal 8x42 Binocular
Canon 30D DSLR
Mini EQ1
My Astronomy Pages
Edited by Patrick (09/24/08 06:53 PM)
snowdragonusa
Reged: 09/04/07
Loc: Denver, CO
Re: WCS Drift Alignment Software Problem new [Re: Patrick]
      #2661751 - 09/25/08 12:10 AM
Hi Patrick,
Yup it works on Vista 32 bit. I run my DSI with WCS and Vista quite often. What you might what to do is go into the Control Panel and then to Security Center. In the Security Center is the ability to turn off User Account Control. This is new with Vista and basically gives you a warning every time you try and either access, install, or have another program access something that doesn't have the official Microsoft seal of approval.
Turn this function off and see if that helps solve your problem.
Cheers!
Adam
12" LX200R
AT80mm piggyback
DSI Pro, DSI-C, LPI
Denver Astronomical Society
Brighton Astronomical Group
Patrick
Reged: 05/16/03
Loc: Franklin, Ohio
Re: WCS Drift Alignment Software Problem new [Re: snowdragonusa]
      #2661781 - 09/25/08 12:36 AM
Hi Adam,
Thanks! That eliminated the security issue, but WCS is still not recognizing my DSI for some reason. I don't see where I can connect to the camera. The user interface page just shows 'DSI-Cam: None'.
Do I want to run the program in XP compatibility mode?
Patrick
Celestron C6 SCT
Denk Binoviewers
AT66ED Refractor
Canon 30D DSLR
Mini EQ1
My Astronomy Pages
snowdragonusa
Reged: 09/04/07
Loc: Denver, CO
      #2662147 - 09/25/08 08:50 AM
When you try and start WCS without a DSI connected you will get a message saying there is no DSI detected and the program will close. So, if you are getting the program to stay open then you might already be good to go.
Once you have the program open, simply press start. This will start the 'live view' mode. From there you center your star and then click on it to start the drift tracking.
If that doesn't work then try running in XP mode and see if that does the trick.
Adam
12" LX200R
AT80mm piggyback
DSI Pro, DSI-C, LPI
Poochpa
Reged: 02/12/05
Loc: Buffalo Burbs, NY
      #2662457 - 09/25/08 12:19 PM
If you are using the original DSI, make sure you use the DLLs from the old library folder. See the posts about this on the WCS group, which is linked on WCSs main page.
Televue NP101
Vixen GPDX/Skysensor 2000PC
Meade 8" LX200GPS
Stellarvue Nighthawk II
WO Zenithstar 66SD
Canon Rebel XSi
Patrick
Reged: 05/16/03
Loc: Franklin, Ohio
Re: WCS Drift Alignment Software Problem new [Re: Poochpa]
      #2663228 - 09/25/08 07:34 PM
Thanks guys! I think I got it working. I copied the .dll files from the Autostar suite and was able to get a DSI image.
Patrick
Celestron C6 SCT
Denk Binoviewers
AT66ED Refractor
Canon 30D DSLR
Mini EQ1
My Astronomy Pages
RandallK
Reged: 11/10/06
Loc: Nanaimo, B. C. Canada
      #2664600 - 09/26/08 01:25 PM
Don't you just love it when people here help out!
Scopes: Meade SC-8AT w UHTC
SkyWatcher 5" F/5 Reflector
SkyWatcher 127mm MAK
Mount: HEQ5 Pro
Cameras: Orion Starshoot DS Colour Imager V.1
Imaging Source Webcam DMK21AU04.AS
Palm TX PDA w Astromist and Bluetooth wireles control.
snowdragonusa
Reged: 09/04/07
Loc: Denver, CO
      #2665501 - 09/26/08 10:31 PM
Patrick
SUCCESS!!!
Enjoy those awesome alignments now!
Adam
12" LX200R
AT80mm piggyback
DSI Pro, DSI-C, LPI
1 registered and 7 anonymous users are browsing this forum.
Home
