tjay
Reged: 02/03/07
I'm going to try to afocal shots tonight with my Canon Powershot G2, but I was wondering if I should be setting focus for infinity, or should I go in macro mode to focus as if I was shooting something close up (i.e. the image from the eyepiece). Any tips would be appreciated.
-------------------- Clear Skies
Nexstar 8 GPS
GSO 8" Dob
Meade ETX 80
Kendrick Dew Heater
11mm, 20mm Agena Astro UWA
40mm, 32mm, 26mm, 20mm and 15mm Meade Series 4000 Super Plossl
25mm and 10mm GSO Plossl, GSO 2x barlow
Surplus Shed 47mm Erfle
GSO 2" Dielectric diagonal
Antares f6.3 focal reducer
Philips SPC900NC
nofxrx
Reged: 07/12/05
Loc: palm bay,florida
IIRC you are supposed to set it to "infinity".... I remember shooting planets afocally and would usually set it to infinity but would on occasion mess with the focus until I got what looked best... Hope this helps!! By the way what adapter are you using to hold the cam to the EP?
-------------------- Brent Oliver
3 Wonderful dogs: Sadie, Kara and Ozzie
Celestron C10-N///C9.25///Orion 80ED///WO ZS66SD White
Celestron CI-700 & ASGT Eq. Mounts
Nikon D40Xa///SBIG ST-402ME/Class 1/CFW///DSI-PRO...
My Gallery
Ohh yeah,and a VERY undersanding wife!!
Chris_H
Reged: 11/24/03
Loc: Norway
Some cameras actually work better in macro mode. My old Nikon 4500 was like that but my Canon A610 works best at infinity.
-------------------- Chris
"Big Papa Smurf" (254mm f/4.7 Sky-Watcher Newt)
Custom Orion Optics 150mm f/8 reflektor "Planet Killer" (On its way!!!)
SPC900
Canon Powershot A610 (CHDK modded)
Canon 10D (modded)
Canon EF 50mm f/1.8 II
Canon EF 70-200mm f/4 USM L
My Website
tjay
Reged: 02/03/07
Thanks for the reply.
I'm going to use a Agena 20mm UWA, which has 49mm threads under the eyecup, and I've got a 49mm to 52mm ring screwed into a 52mm to 49mm ring which screws right into the Lensmate I've got on my PowerShot G2. The combination of rings is just enough to keep the camera lens from hitting the eyepeice, and I was able to get them a local camera store.
Nexstar 8 GPS
GSO 8" Dob
Meade ETX 80
Kendrick Dew Heater
Philips SPC900NC
tjay
Reged: 02/03/07
I guess I'll give both a try then...
Nexstar 8 GPS
GSO 8" Dob
Meade ETX 80
Kendrick Dew Heater
Philips SPC900NC
tjay
Reged: 02/03/07
Well, I had some mixed, but encouraging results tonight. I gave Jupiter a shot, even though I had my focal reducer in, and the individual frames are probably my best planetary shots yet. I've got more frames, but I haven't had time to stack anything yet.
I also gave M13, M57, M31 and M27 a try, just for the heck of it.
I'm extremely encouraged by the results for M57, but I'm not clear why I got a halo around everything other than Jupiter. Anybody have any thoughts?
I shot Jupiter using 1/50 sec shutter at ISO 50, and everything else at 15 sec shutter at ISO 400, all through my Nexstar 8 GPS, using an Antares f/6.3 focal reducer, using my Agena Astro UWA 20mm with and without the extra barlow.
Here are the shots:
Jupiter:
M13 (not sure what happened here, I took multiple shots and they are all like this )
M57 (I'm quite encouraged by this, especially seeing the color )
M31 (Not sure what the halo is from)
M27 (again, not sure what the halo is from)
Notice of Edit: Fixed this post with legal sized images set up as clickable links to the original large versions! CH
Edited by Charlie Hein (10/02/08 07:31 AM)
mosheriffic
Reged: 03/31/08
Loc: Marysville, Wa.USA
Really nice attempts! Its encouraging me to get the lensmate set up for my Canon S3is from CNC supply! Those halos look suspiciously like something fogged up.
-------------------- Ron
"seeing is believing"
Celestron Nexstar 8SE
Orion 120st
astroview mount
Orion starshoot solar system color imager II
Member Everett Astronomical Society
tjay
Reged: 02/03/07
Thanks.
I hadn't thought of dew since my dew heater was doing such a great job of keeping my corrector clear. There was awful lot of dew on my patio table and chairs. I suspect you are right.
Maybe it's time to pick up any eyepiece strip for my dew heater...
Nexstar 8 GPS
GSO 8" Dob
Meade ETX 80
Kendrick Dew Heater
Philips SPC900NC
Edited by tjay (09/25/08 10:14 PM)
nofxrx
Reged: 07/12/05
Those are great!!!
The Halo effect is from vignetting.This can happen from several things: the .63 reducer,the distance from the eyepiece to the cam, or a combination of both...
The only reason you didnt get it on Jupiter is because it was at a short exposure,the longer exposures will show this more so.Also stretching the image in PS will bring this out more.
I had one of those adjustable adapters like THIS ,which would allow me to move the cam around to find that "sweet spot" where the vignetting would be less...you could also try zooming in until the vignetting is less,or more manageable.
Your M57 is really good,plus you got some color in there
Definitely keep trying,if your results are this good starting out I cant wait to see where you are in a year or so!!!
My Gallery
Edited by nofxrx (09/25/08 07:45 AM)
tjay
Reged: 02/03/07
Those are great!!! The Halo effect is from vignetting.This can happen from several things: the .63 reducer,the distance from the eyepiece to the cam, or a combination of both... The only reason you didnt get it on Jupiter is because it was at a short exposure,the longer exposures will show this more so.Also stretching the image in PS will bring this out more. I had one of those adjustable adapters like THIS ,which would allow me to move the cam around to find that "sweet spot" where the vignetting would be less...you could also try zooming in until the vignetting is less,or more manageable. Your M57 is really good,plus you got some color in there  Definitely keep trying,if your results are this good starting out I cant wait to see where you are in a year or so!!!
Brent,
Thanks for the encouragment.
Would a bracket like yours help with the vignetting if I'm already getting the camera lens really close to the eyepiece?
I suspect there are only a few millimetres separating them since I'm only using a couple of adapter rings to attach the camera to the eyepiece.
Nexstar 8 GPS
GSO 8" Dob
Meade ETX 80
Kendrick Dew Heater
Philips SPC900NC
tjay
Reged: 02/03/07
If anybody is curious, here is a picture of my Powershot G2 connected to my Agena 20mm UWA using the step up and step down rings.
Nexstar 8 GPS
GSO 8" Dob
Meade ETX 80
Kendrick Dew Heater
Philips SPC900NC
nofxrx
Reged: 07/12/05
Actually Tom,sometimes there needs to be more space between the lens and eyepiece lens than that.. It really depends on the EP...I have an Orion 3.8mm Epic and it "blacks out" near the EP lens,visually or with the cam. I doubt that is the problem.it is more than likely the spacing from the reducer to the EP/cam...are you using a diagonal? if so try it without it,maybe it will help. If not then maybe it needs a short extension tube...With my limited knowledge of optics I would suggest trial and error until you find what works for you the best...
My Gallery
mosheriffic
Reged: 03/31/08
I don't know if this is the same as you are using, but I thought I would pass it along!
http://www.cncsupplyinc.com/digikits.htm
Just scroll down to find your camera model.
Orion 120st
astroview mount
Edited by mosheriffic (09/26/08 02:52 AM)
tjay
Reged: 02/03/07
Thanks. I was just wondering if there was any possibly that the bracket would help. Sounds like there is. I'll give it a try with the focal reducer on the next clear night too.
Nexstar 8 GPS
GSO 8" Dob
Meade ETX 80
Kendrick Dew Heater
Philips SPC900NC
tjay
Reged: 02/03/07
I don't know if this is the same as you are using, but I thought I would pass it along!  http://www.cncsupplyinc.com/digikits.htm
Thanks.
I've seen these. I kind of "rolled my own" with the step up and step down rings I'm using.
Nexstar 8 GPS
GSO 8" Dob
Meade ETX 80
Kendrick Dew Heater
Philips SPC900NC
Charlie Hein
Reged: 11/02/03
Loc: 26.06.08N, +80.23.08W
Looks like vignetting to me - sometimes it's because the light path is blocked but in this case it looks like the light cone just falls off very rapidly.
Did you use any zoom in these shots at all? I started imaging using a DV camcorder tied to the eyepiece pretty much the same way you have done, and I would get this kind of vignetting when I used the optical zoom on the camcorder:
Here's another shot - same basic setup, but no zoom:
My guess is that you might actually have the same issue with the Jupiter shot but the background is so close to the same level that you cannot tell the difference.
Charlie
Weston CSC:
tjay
Reged: 02/03/07
image deleted
image deleted
Charlie
I definitely did use the maximum zoom on my camera. I'll try without next time. Thanks for the tip.
Nexstar 8 GPS
GSO 8" Dob
Meade ETX 80
Kendrick Dew Heater
Philips SPC900NC
