Astrophotography and Sketching >> Beginning Imaging
Tim C
Reged: 11/11/07
Loc: Marietta, GA
Connecting my W.O. 66mm to a DSLR? new
      #2666671 - 09/27/08 06:10 PM
I just found a good deal online for a Williams Optics 66m Zenithstar refractor and my birthday isn't too far away so I pulled the trigger. Was hoping someone could help me figure out how to connect this scope to my 450D for the best astrophotography performance. I'm 99% sure I'm going to order the .8X W.O. Reducer/Field Flattener for it. What kind of T adapter should I use? I'm a beginner but I've been using an 8"SCT thus far with a celestron SCT t-adapter. This adapter is about 3 inches long and has a diameter of 1.5 inches. Will this work with the WO 66 or should I buy a different t adapter (perhaps something shorter and/or with a wider diameter to reduce vignetting)? Thanks for any advice you have.
Tim
Tim
My Astrophotos:
http://mediafire.com/tcardinastrophotos
Nexstar 8SE
Denkmeier Powerswitch Diagonal
LXD75 Mount
Williams Optics Zenithstar 66
Canon xsi/450D (unmodified)
Various eyepieces and other stuff
Edited by Tim C (09/27/08 06:11 PM)
Mobius1
Reged: 08/28/05
Loc: Madison, WI / Gurnee, IL
Re: Connecting my W.O. 66mm to a DSLR? new [Re: Tim C]
      #2666771 - 09/27/08 07:34 PM
I know that the 66mm is a bit different from the larger scopes in the kind of visual back it has. But i believe that you can get an adapter with SCT threads on the rear, so that you could mate your T to SCT adapter on your '66.
Martin
Orion 100ED
Orion 120-ST EQ
PST-Ha
Celestron CGE 1100
Canon Rebel XSI
DSI-IIC
Yerkes Observatory Volunteer
(24" Cass on weekends)
Peds
Reged: 03/07/07
Loc: Brasilia, Brazil
Re: Connecting my W.O. 66mm to a DSLR? new [Re: Mobius1]
      #2666835 - 09/27/08 08:14 PM
I use the WO 0.8x Reducer / Field Flattener together with a regular Canon T-ring. That's all you need to get nice round stars covering the entire sensor.
The reducer/ff comes with one side being a SCT thread that is made specifically for connecting directly to the 66mm scopes. The other side is for your T-ring which connects the camera to the reducer/ff.
P.
Orion 80mm ED Apo
White William-Optics Zenithstar 66SD Apo
Tim C
Reged: 11/11/07
Loc: Marietta, GA
Re: Connecting my W.O. 66mm to a DSLR? [Re: Peds]
      #2666884 - 09/27/08 08:59 PM
ah, got it now. Thanks very much.
Tim
My Astrophotos:
Nexstar 8SE
LXD75 Mount
11 registered and 9 anonymous users are browsing this forum.
Home
