Privacy Policy |
Please read our Terms
of Service | Signup and
GT2004
Reged: 10/26/04
Im new to the hobby im just trying to figure out what do I need to buy something that will do the job something that will produce nice images. I know about the meads deep sky images and the celestron nextimage If there is something that’s better then these and that’s a little more expensive that will produce better images. Sorry guys im just new to this thanks for all the help.
southmike
Reged: 11/22/04
Loc: Fayetteville, NC
well what do you have for a scope, do you have a laptop? you might be better off with a dslr like a rebel.. or even an canon a series (there is a good thread on those)
going that route you will need a t mount and an a t-ring or a maxview type eyepiece..
going the ccd route you will need a computer..or laptop, and then depending on what you want. a nextimage is good for planets , the dsi is a good entry level camera..the dsi pro is too new to tell then there are the sac 7,8, etc..
but above all else you need a good steady mount pretty much for any imaging.
-------------------- group scope pic
my refractors
LX200 10"-St120
LX200 8" f6.3-Orion 80ed
LX200 8" f10-Orion 90 Mak setup pic
Meade 102ED LXD650
Sky Watcher 100 ED Triplet prototype
Nexstar 5
etx125
etx70's
tjensen
Reged: 02/16/05
Loc: Chapel Hill, NC
Well it depends on what kind of pictures you want to take- planetary or deep sky... For planetary work- you can't beat the ToUcam! Easy to use and a resonable price. For deep sky- I went for the Canon 10D DSLR. Doubles as a great land camera and is a lot less expensive than the dedicated astroimagers. No cooling so you are limited in exposure times to <5min usually, but there will always be tradeoffs.
I think you need to look at what you want to do, what equipment you have, and how big the bank account is. This hobby has a bad habbit of draining mine quickly
Good luck with whatever you decide- and remember to have fun!!!
Cheers
-------------------- 10"LX200GPS
Orion 80ED
Canon XT (modified)
ToUcam Pro
mtc
Reged: 04/04/05
Loc: Chelmsford, MA
Either way will require a heavy dose of patience and lots of practice. Keep expectations low until you've figured out your optimum combination of settings across your scope & camera for the type of image your going after (lunar & planetary or Deep Space object).  FYI, mtc
-------------------- StarMax 127
Starshoot DSC
sienarot
Reged: 10/18/03
Loc: Calgary, Alberta, Canada
The number one, most important thing you'll need to take pictures is a good sturdy mount. Everything else falls into place after that. How well your mount is plays a big influence on how well your images can come out and what you will be capable of. You can pretty much take pictures with anything using any scope! However if your mount is inadequate, it won't matter what sort of imaging device or telescope you use.
-------------------- Derrick
Sky-Watcher 80ED f/7.5 Refractor
Celestron C8 SCT f/10 SCT
Canon EOS 20D
Logitech Quickcam Pro 4000
mtc
Reged: 04/04/05
Loc: Chelmsford, MA
Excellent point!
Starshoot DSC
GT2004
Reged: 10/26/04
thanks guys i have the Celestron C10-NGT with the CG-5GT computerized EQ mount. i want to take pics of Deep space and planets
-------------------- Celestron C10-NGT
TeamGS
Reged: 01/20/04
Loc: Elk Grove, CA
I am not sure what you consider a little more expensive, but a used SBIG ST7 or Starlight Xpress MX7-C can be had for around $1000 and are are a significant step up. They are more sensitive, have a larger chip, and are self guiding. The MX7-C is one shot color, and the ST7 needs a color filter wheel if you want to image in color. These are great cameras to start with, if you are looking for a little more than the DSI.
Gary
-------------------- Celestron 80ED
Losmandy G11
NexStar 80
Starlight Xpress SXV-H9
SXV guidehead, ToUcam 840
http://www.teamgs.org/astrophotography.htm
Charlie Hein
Reged: 11/02/03
Loc: 26.06.08N, +80.23.08W
Hi. I have a couple of comments... I'm sure you've already got the news that this may likely be an expensive undertaking for you. It will really help to take the time to fully understand the decision making process.
The 10 inch Newtonian on a CG5 mount is a very nice visual setup but you're loading a lot of weight on the mount already, and you haven't added cameras or accessories like a guide scope yet, which will definitely push up the load on your mount. The rule of thumb for imaging is to load the mount at around half its capacity for stability reasons. This is a big consideration when you're choosing what to buy.
If I were you, I'd take a look at the work produced by the folks here on CN, and find out what their setups are like. Chances are that they tell you, either in the messages they post or in their signature lines, but if all else fails, just ask - I'd be willing to bet that anyone who is making images of a quality that you'd like to emulate will enjoy talking about their gear!
You might decide that you need to make some changes in your rig as well as adding cameras to it, or even that the smart move is to buy a whole new rig just for imaging, and keep the 10 inch so that you have something to look through while you cameras are catching photons! How far you go down this road is a question nobody can answer but you.
You should be aware that you're really talking about two very different disiplines when you talk about planetary and deep-sky imaging. To do each type really well requires different equipment.
As you may have heard, our very talented friend Suk Lee is getting out of astro imaging altogether, and he's selling his entire rig.
(Here's a shameless plug for Suk: If you really want to jump in with both feet, you can save a ton of money and experimentation by buying Suk's rig. I know that this may sound weird, but it is a real steal at $25,000.00 for the scopes, mount, cameras - the works! I'm not kidding!)
Now I don't expect that you'd be interested in that large an investment. I mention it for a couple of reasons, though.
The primary message is that your options are truly only limited by the depth of your pockets. As first-rate as Suk's rig is, I'm positive that he could easily find ways to upgrade it if that was his aim.
The second is this: remember when I said that DSO and planetary work are two very different disciplines? For planets, Suk uses an inexpensive webcam, because that's all you really need. I personally don't know of anything that does a better job on the planets than the right webcam. Also, planetary work does not require high precision gear either, so the gear you have right now can be put right to work as is. If you can center a planet's image in a high-power eyepeice (say a 6-9mm Plossl, or a 15mm Plossl in a 2X barlow) and have it stay in the field of view for 3 or 4 minutes, chances are you have all the rig you need for planetary work.
This is because planets are really bright. The camera can catch a frame in a fraction of a second, capture thousands of frames over a few minutes time, and software can work with those frames to give you a nice image.
OTOH, deep-sky objects are dim, so dim that many times you can barely even see them visually, and you can almost never make out much color or detail. The cameras for this kind of work need to be able to take exposures from several seconds up to several hours in length to get a single frame. Some guys take exposures over several nights (weeks, even) to get enough frames to make a nice shot. Your gear absolutely has to be able to keep the light falling on the same pixel on your cameras' chip over the whole exposure time in order for you to get a clear picture out of it. Understandably, this requires a much more complicated and sensitive camera, and also puts great demands on your mount. Here also is the place where the money starts to add up!
That's why some guys have suggested a Digital SLR as a camera for this kind of work. Since that's the road I'm travelling myself, I can't argue with that logic, but I have a couple of strong suggestions as well.
I would treat this as two different "projects" - learn planetary astrophotography and deep sky astrophotography separately.
For planetary work: Get a webcam and an adapter to plug it into your focuser, or possibly consider a camera that is webcam-based but is already set up for astronomical use. One good choice for a camera might be one of the SAC 7 series of cameras from SAC Imaging. This camera works really well for planetary imaging, much better than the DSI or LPI for this job IMO.
The main reason I mention going this route though is because the camera will be able to serve you long term for multiple uses. These cameras are also equipped to do long exposures, so they could be used as an entry level deep sky camera with capabilities very similar to the DSI, or as an excellent imager to use with an autoguider program once you're ready to try your hand at that.
But the bottom line is this - get some kind of webcam based imager and use it to learn how to shoot planets and the Moon. You should progress fairly rapidly, and you can get decent images out of your current gear.
For deep sky: if you have a camera that can be mounted on a tripod, has a long exposure ("bulb") mode, and has a wide angle or zoom lens, you can get started right away learning what you need to know. Most 35mm SLR type cameras have this capability. If you don't have such a camera, consider a DSLR like the Digital Rebel or the Nikon equivalent.
You can start by taking 15 or 20 second tripod mounted constellation shots, go from there to making cool star trail shots (which essentialy is just exposing for longer periods of time, processing and combining several frames to create a long trail), move up to piggy-backing your camera on your scope, and eventually graduate to using the scope as the camera's lens - learning every step of the way.
Reading up on the subject can't hurt, either. This is a web page for an excellent book on the subject for someone who is thinking about starting down this road... they even let you read Chapter 1 to let you have an idea of what you can learn.
After all this reading and practice time has passed (it seems like it'll take forever), you'll definitely have a good idea of what you need to do (or have) with respect to your gear!
Bottom line for this - get some kind of suitable camera and start down a long learning curve! Don't be tempted to skip any steps - everything builds on some prerequiste, so patience and persistence pays off in knowlege! This aspect of the hobby is going to be the expensive one!
Well, I've definitely rambled on way longer than I had planned on - I hope that at least I didn't completely bore you to tears!
Good luck!
Charlie
Weston CSC:
GT2004
Reged: 10/26/04
Hi Charlie how are you WOW thanks for alll the info i know now what to do so thanks so much for the input. Just a quick question is meads deep sky images and the celestron nextimage same as the SAC 7 series of cameras from SAC Imaging. which one you think is better to go with ?
Charlie Hein
Reged: 11/02/03
Thanks, it seems like I have a simple thought in my head to convey and it always ends up being a sort of "brain dump", much longer than I intended to go - I'm glad it was helpful.
Good question - Before I go too far, let me say that the DSI is a good product, possibly even a ground breaking product in its class. However, what I've been seeing and hearing is that it's software can be a bit hard to master. I'd say its best use is as an entry level deep sky camera. I would not consider the DSI the best candidate for planetary imaging, although there are a few guys out there that are getting decent planetary images from it. IMO, from what I've seen it's not really made for that kind of work, but you can get it to do it.
The NexImage is a pretty darn good planetary camera from what I've seen. It's very similar performance wise to the ToUCam, which is probably the most widely popular webcam for this kind of work, and it can be operated using easily available software as opposed to the DSI, which requires the use of proprietary software.
However, unless you modify it for long exposures, the NexImage is strictly for Planetary work, just like the ToUCam. Modification can be a tricky deal unless you have experience with that kind of work, and there's always the possibility that you'll mess up your camera trying to mod it. A sucessfully modded ToUCam can get deep sky images pretty similar to what the DSI can do - still entry level stuff for deep sky.
The advantage to cameras like the SAC 7 series is that the modifications are already done and tested for you, so this eliminates the possibility of wrecking the camera trying to mod it for long exposures. The SAC 7 also comes in a peltier cooled version that helps to reduce noise in your images by keeping the heat on the CCD chip down. They can also be run on quite a variety of software.
What's best? I'm biased toward cameras like the SAC 7 because I own one, but to be honest, if you were looking for a camera only for planetary work, I'd say a ToUCam or a NexImage is probably the best buy. If you were wanting to also try long exposures and you only wanted to buy one camera, then a camera like the SAC 7 makes a lot of sense as long as it's understood that we're really talking about entry level deep sky stuff here. Personally (and I'm probably gong to take some heat over this for saying so), I think that the DSI should only be thought of as an entry level deep sky camera, and not considered as a planetary camera.
Hope that helps.
Charlie
Weston CSC:
Anonymous
Unregistered
The answer depends on what kind of images you want to get. I have a Canon A95 mounted to an ep w/ a 1.5 to 1.25 rubber plumbing adapter that I use on a DSH 8" (dob). About the opposite of what everyone suggested here and to me when I asked. Needless to say, I can achieve "decent" lunar and planetary images. They aren't perfect but to the people I show them too, they are impressed. Best of all, I spent a grand total of $3 to do it! Sure a $1000 mount would help, but it can be done cheaper too.
I took this one using this setup (be easy on me, it was only my second attempt, and yes the red/ blue needs shifted). It is a stack of only about 8 images. Its not an earth shattering image but my wife doesn't have me sleeping on the couch either! ;^)
Edited by Nathan (04/16/05 11:31 PM)
clitherowclan
Reged: 02/23/05
Loc: Fife Scotland
An alternative to the SAC series of adapted webcams may be the ATIK range. They are based on the To-U-Cam webcams with various different chips available with improved sensitivity. Damien Peach, on of the UK's absolute best planetary photographers, uses one of these and gets stunning results. The price starts at around the same as the DSI and moves on up as you choose more sensitive chips. Like the SACs they can do acceptable deepsky work but, in my humble opinion, the DSI is probebly better for that kind of work. If you put ATIK into google for your country, you should find distributers and also a Yahoo-groups link to an ATIK users forum with pleanty of advice; there is also a DSI forum on Yahoo. Best of luck and whatever route you choose don't expect brilliant results straight away. Get plenty of practice in for this autumn when Mars will make one of its best presentations in years! Cheers, Alan C
-------------------- Scottish Astronomer, Firstlight Instruments 10 inch F6.3 Newtonian, Helios 8inch F5 Newtonian and ED80 Apo on driven EQ5. Various cheap cameras.
mischief
Reged: 04/26/08
Loc: Northern California
Lots of good information. Thanks. My question: about all I can view from my backyard are planets and the moon. I am also getting a Lunt solar scope (soon, I hope). I would like to image planets, moon and sun. I have been reading about the Meade planetary imager, Orion planetary imager, Celestron planetary imager and the TouCam. I use a Mac which might be a problem with imaging software altho I have an Intel Mac and could run Windows. Which of the listed (or others) would you recommend for this type of imaging. I am going to be particularly interested in the sun once I get the Lunt solar scope. Thanks in advance, Dorothy PS In my list of equipment, I know they are all small aperture. I have trouble lifting and carrying anything heavy so I have to deal with that. Applies to mounts also.
Orion ST80 Vixen VMC 110 Orion StarBlast Orion Mak 90 Orion VersaGo mount Olympus C765 UV
NyxAither
Reged: 09/11/07
Loc: Arlington VA
Here's an example of my pictures taken with my SPC900 and adapter (I paid $50 total), and my dobsonian mounted telescope. Good luck!
Thomas
✸Orion XT8i✸Orion 80-T✸CG5 GT Mount ✸Meade DSI II Color✸Meade DSI (THANKS TODD N!!!)✸Orion 4.5" Reflector OTA✸Trusty Mac Powerbook G4✸1960's Gilbert 3" telescope✸10x50 binoculars✸SPC900NC✸
..::*~*Clear Skies*~*::..
Edited by NyxAither (09/27/08 10:21 PM)
NyxAither
Reged: 09/11/07
Loc: Arlington VA
And here's some bigger ones. Keep in mind, the SPC900 is strictly for lunar and planetary photography.
Thomas
Pauls72
Reged: 10/28/07
Loc: LaPorte, IN
I would recomend you start by getting a book or two on CCD or DSLR astrophotography, which ever way you are leaning. As you have already been told your curent setup is not going to cut it for astrophotography. You will need a larger mount or smaller scope. Don't forget you are going to need some software to process the images.
If you are looking at CCD, I would get "The New CCD Astronomy".
http://www.newastro.com/
-------------------- Orion 8" Reflector on a Meade LXD55
Orion 102mm Mak
Meade DSI-C
SBIG ST-402ME
Canon Rebel XTi
Edited by Pauls72 (09/27/08 11:18 PM)
cam1936
Reged: 08/01/08
Loc: Alberta, Canada
Any DSLR has the ability to capture good photos of DSO targets and almost any webcam has the ability to attempt planetary targets.
-------------------- C8-SGT
Nikon 10x50 Action Ex
Canon 350D
Manfrotto tripod
Various EPs and accesories
5 registered and 8 anonymous users are browsing this forum.
Moderator: Charlie Hein, knuklhdastnmr
