Observing >> Deep Sky Observing
Anonymous
Unregistered
Lumicon UHC or Orion Ultrablock new
      #24611 - 12/01/03 04:09 PM
I have a 4.5in. reflector and I am considering a filter. Should I buy a Lumicon UHC or an Orion Ultrablock? From what I've read they are similiar, both are narrowband passing hydrogen-beta and ionized oxygen. I have had recommendations for both. Any advice is greatly appreciated. Thanks all.
Anonymous
Unregistered
Re: Lumicon UHC or Orion Ultrablock new [Re: ]
      #24613 - 12/01/03 04:16 PM
I believe the bandpass on the Orion is a bit wider, which will yield stars with slightly brighter images, and slightly lower contrast for the nebulae. The UHC also passes a lot of deep red (but not H-Alpha). This can cause a slight red halo around bright stars on Achromat refractors. Otherwise, I buy whichever is cheaper. Don't forget Thousand Oaks filters as well.
Warpd
jack45
Reged: 07/07/03
Loc: Lacey WA
      #24634 - 12/01/03 05:18 PM
I have the Orion Ultrablock and with the 24.5mm Meade, 17mm Nagler T/4 and the 11mm Nagler T/6, the view it great stars turn a bright blue but the nebular cloud come out real good having not used the Lumicon UHC I can only comment on the Orion Ultrablock you can't lose. I have the Orion XT10" F/4.7, and they say you can't see the Horsehead nebular without a 16"scope or less but I think I saw it using the Orion Ultrablock the two times I view it, they said you need the H-beta filter.When you do view it (M42) look next to the four stars in the center of the nebular, thats were I saw the Horsehead nebular (I think).
Clear Skies!
16"f/4.5 Discovery Split Tube/TV Paracorr
12.5"f/5 Discovery PDHQ/TV Barlow
Orion SkyQuest f/4.9 XT12"Intelliscope
Orion 120mm F/8.3 Refractor
Burgess BV 24mm aperture/Siebert 4 pc OCA
BV Pairs:26mm,20mm,17mm,14mm,12.5mm
Tele Vue Smooth Side Plossl,10.5mm,13mm,21mm,26mm,TV 11mm
UO Abbe Set,40mm 5000s Plossl,31mm Axiom LX,26mm T/5,LX,23mm Axiom LX,20mm T/2,16mm T/2,15mm Panoptic,14mm Meade UWA,10mm Axiom LX!
Anonymous
Unregistered
Re: Lumicon UHC or Orion Ultrablock new [Re: jack45]
      #24641 - 12/01/03 05:36 PM
The Horsehead nebula is actually near the western-most belt star in Orion. I've seen it in an 8" and a 10" scope under VERY dark skies at about 8,000 feet altitude. No filter was required. I haven't seen it since. If I were getting a 2" filter, I'd definitely get the Ultrablock...it's half the price of a UHC or OIII.
Warpd
John_Gillies
Vendor - Earthwin Optical
Reged: 04/23/03
Loc: Ontario, Canada
      #24683 - 12/01/03 07:39 PM
Hi Rick,
I have 3 Lumicons and really love the things. The one Orion filter I own is a 2" moon filter. Right from new the Orion does not thread properly on any of my 2" ep's or my 2" binoviewer nosepiece. I'm a little dissappointed with it for that reason alone. Maybe I got a bum filter, I don't know. Under the magnifying glass the threads appear perfect. My Lumicons fit perfectly. I haven't heard of anyone else with the same problem, but it has discouraged me from buying Orion filters in the future. So from my experience I'm saying go for the Lumicons, their price is higher but you get what you pay for. Others here will disagree, but then why buy a Tele Vue when you can get a Skywatcher right?
John Gillies
12” LX200 GPS / Double Stacked PST
EarthWin Optical PFS-D Binoviewer System(s)
Skywatcher ST 80, 102 & 120
Captain Drift
Reged: 11/27/03
Loc: Brazil
Re: Lumicon UHC or Orion Ultrablock new [Re: John_Gillies]
      #25729 - 12/05/03 01:09 PM
What is the minimum configuration (aperture/focal ratio) to use a narrow band filter?
Is it worth using an Ultrablock in my scope (180mm - f/6 dob) or a bit more apperture would be required?
Thanks in advance.
Neliton
180mm f/6 Dob
Anonymous
Unregistered
Re: Lumicon UHC or Orion Ultrablock new [Re: Captain Drift]
      #25736 - 12/05/03 01:20 PM
I use a UHC (very similar to an Ultrablock) in my 70mm f-6.8 Ranger with good results.
Warpd
imjeffp
Senior Space Cadet
Reged: 09/30/03
Loc: Cedar Park, Texas
      #25747 - 12/05/03 01:40 PM
I hope it'd be worth using an UltraBlock in your 180mm f/6, since I just started using it with my 150 mm f/6. First night out on the front porch looking over the neighbor's Christmas lights was better than I expected. I'll know more in a couple of weeks when it gets dark.
Blog
ST80 • AT80EDT/LXD650
ETX-90/DS-2000 • 10" LX200 Classic ("The Quarter-Meter Telescope at the Heritage Park Observatory")
SPC900NC • DMK21AF04 • Digital Rebel XT
Captain Drift
Reged: 11/27/03
Loc: Brazil
Re: Lumicon UHC or Orion Ultrablock [Re: imjeffp]
      #26681 - 12/08/03 10:11 AM
Thanks Warpd and imjeffp!
So it seems that my 2005's list of what to buy has its first cadidate.
Neliton
180mm f/6 Dob
Moderator:  matt, Olivier Biot
Home
