Privacy Policy |
Please read our Terms
of Service | Signup and
Scott K
Reged: 09/13/07
Loc: Dallas, TX & Eufaula, OK
I opened up my dome a couple of times yesterday without any problems. Russ had used the rest of the EPDM pitch pocket filler to seal around the inside base of the dome last week, and so we needed to put the tiles back down again. (Not finished with water sealing yet - but this looks to be a good improvement.) While doing this, I opened and closed the dome a couple of times without any problems.
So imagine my surprise as I open the dome last night to do some observing, to find that the front shutter of the dome pops out of it's track, rearing up backwards instead of smoothly opening.
This is pretty easy to remedy - you just climb up a tall ladder and pop it back in track. It's super annoying to have to fetch the ladder (If I wanted a ladder in my observatory, I 'd have a roll off and a big dob!), and it's a little stressful to see it malfunction, but no big deal. I fix it and go on to have a successful night of observing.
So today I try to reproduce the failure, and of course I can't. But in the course of watching the shutter open and close a half-dozen times, I am struck by how much force is pulling DOWN on the shutter, pulling it against the rear cover of the dome.
I examine things, and I notice that the tension on the shutter cables on the western side of the shutter is quite a bit higher than on the east side, and much, much higher when the front / top shutters near the zenith of the dome, which is where it seems to hang up, than when the shutter is closed. At the zenith, the cables on the west side are almost guitar string taut. When closed, they have a small amount of give.
So Bob, my brother-in-law, and I, try loosening the west cable a tiny bit. This helps - the cable is no longer completely taut when the shutter is raised. So we sand the rear slot and the front tab on the shutter (it was catching a bit on the slot), and we found the shutter to work much, much more smoothly than it ever has before.
I opened and closed it at least 8 times, and it just worked flawlessly. The motor strain sound when the dome closes is gone. The shutter parts seem to smoothly glide over one another while the dome opens, just as they should.
I may need to periodically sand the slots and tabs a bit, and I may not have the tension quite right (although it seems pretty even between the east and west cables now), but so far, so good.
If this turns out to fix the problem permanently, it would be a lot of grief caused by maybe 1/8" of adjustment to a cable.
JAT Observatory
Space Freak
Reged: 02/20/05
Loc: Eastern PA
Scott, Glad you found the problem. I personally find shutter issues un-nerving.
-------------------- -Marcus
The problem with free speech is even the stupid have a voice.
http://jatobservatory.org
12" LX200R on a Paramount ME
Pedestal
Reged: 03/11/06
Loc: Smoggy Bottom, Baytown,Texas
And I was thinking, "oh no, not again!!!" Hubert
-------------------- www.smoggybottom.org
GrassyPond
Reged: 02/06/07
Loc: South Georgia
Hi Scott Do you have a spring on the "close"cable?
-------------------- Turtle Creek Observatory
Joe
12" LX200R
MallinCam Hyper Plus Color
10' HomeDome Automated with LesveDome
Scott K
Reged: 09/13/07
Thanks Marcus, I do too! 150 lbs of shutter, 12 feet in the air and out of control is really scary!
Scott K
Reged: 09/13/07
No I don't Joe, although I think that would help. Do you have a picture of how you arranged the spring, and any thoughts on how heavy of a spring to use? Keeping the tension uniform would defintely help.
GrassyPond
Reged: 02/06/07
Loc: South Georgia
Hi Scott Sorry I don't have pictures. I think Jerry has the components needed for this including the spring. You will also need to replace the "close cable" lock nut with a pulley, a grooved wheel bolted in place of the lock nut. Route the close cable around this wheel and attach it to the spring that is attached to one of the bolts holding your cable track system in place. You can find this on the Yahoo group for the dome.
Joe
12" LX200R
GrassyPond
Reged: 02/06/07
Loc: South Georgia
Hi Scott On the yahoo group is a picture under HD10-Mod folder that is exactly like my installation.
http://tech.ph.groups.yahoo.com/group/home_dome_users/photos/view/26c6?b=2
Joe
12" LX200R
Scott K
Reged: 09/13/07
Thanks Joe, I just emailed Jerry to see if he has such a kit, and if he does, I'll get one and install it. Keeping the tension uniform really seems as if it would help a lot.
What I'd really like to do at some point is add a brace across the rear cover, near the top. I think this would also help - the slot flexes 2-3 inches depending on the travel of the shutter.
Chris Schroeder
Reged: 12/11/04
Loc: N.E. WI Sky Glow
Glad you got everything working Scott, a least for now  With your luck, I wouldn't be buying to many lottery tickets
-------------------- Chris
Mallincam Color Hyper Plus
10" DSH with SC DSC, CPC 800 XLT
M102ED S.V., ZS 80FD 10th Anniv, ZS 66SD, PST
POD XL3 http://POD.SchroederCity.com
GrassyPond
Reged: 02/06/07
Loc: South Georgia
Hi Scott There is a picture of the "spreader bar" on the Yahoo group also.
Joe
12" LX200R
6 registered and 6 anonymous users are browsing this forum.
Moderator: Chris Schroeder, csa/montana
