Privacy Policy |
Please read our Terms
of Service | Signup and
knuklhdastnmr
Pepperbelly
Reged: 02/24/05
Loc: Beerpuddle, Colorado
Post your image of Sinus Iridium here. Post any comments on these images in Rules and Comments. Submissions shall close at Midnight EDT on October 31st. Please submit only one entry.
If you have submitted and entry and want to change it, first try the edit function. It is available for three days after the original post. After that please PM one of your moderators.
[Tip: There were significant changes to the rules beginning with the July 2008 contests and again in August 2008. It would be a very good idea to check the Rules and Comments thread, the link is above.]
-------------------- Knucklhead Astronomer
phil piburn
Reged: 07/15/06
Loc: Kansas City Mo
OK, I will go first. Fuji F-30 camera shooting thru eyepiece 80mm refractor 9mm BO/TMB eyepiece ISO 200 250/1000 sec.
droid
rocketman
Reged: 08/29/04
Loc: ohio
through a 102mm refractor , with a 17mm plossl, and a HP point and shoot 2.1mp digital point and shoot camera, afocally. I did gray scale and sharpen in paint shop pro.
-------------------- andy
Stingray
Reged: 09/18/08
Camera: Imaging Source DFK41AU Scope:SN-8 Meade Image: 200 Frames stacked in Registax Post: Microsoft Picture-it
Adrena1in
Reged: 09/02/07
Loc: Hampshire, UK
My attempt. Shot through my Phenix 1200mm f/9.5 achromatic refractor, then using a 25mm eyepiece projection arrangement for the magnified inlay. Canon EOS DSLR, focussed with Live View and using a Fringe Killer. 42 images stacked. Final result converted to B&W and adjusted the contrast and midtones.
(Not sure how necessary the stacking process was, and I'm thinking I should have left off the text, but hey, it's there now, and it's my first attempt at an image like this. Hope you like it.)
-------------------- Phenix 102mm f/5.9, Phenix 127mm f/9.5 and Orion ST80 f/5 refractors on EQ5 with GOTOStar
Phillips SPC900NC, Meade DSI-C, Canon EOS 450D with 18-55mm IS, 28-105mm and 75-300mm plus 2x TC
swcrawford
Reged: 06/15/08
Loc: Western Tennessee, USA
My first contest entry [be gentle ].
Taken on October 10th with an un-modded Phillips SPC900 through a Meade 10 inch LX200 EMC classic at f/10 on an Atlas EQ-G, manually guided (perfect alignments are still a little beyond me yet). QCFocus used for capture, WcCtrl used to adjust exposure, framerate etc. 771 of 2000 frames stacked in Registax 4 with multiple alignment points. Good transparency, poor seeing. Histogram stretched and sharpened in Photoshop CS3.
-------------------- 10" LX200 EMC
ST-80
Atlas EQ-G mount
ETX125PE
Canon EOS Digital Rebel 300D [unmodified]
Phillips SPC900NC [unmodified]
Meade DSI 2 color
Homebuilt Portable Power Supply
Fusion
Reged: 01/27/08
Loc: Amory, MS, USA
Post deleted by Fusion
-------------------- Lee
Celestron Nexstar 8SE
Orion 80mm Shorttube
Piggybacked on the CG-5 ASGT Mount
Meade DSIc
Phillips SPC900NC/00
QHY8 on the way.
twosox
journeyman
Reged: 09/03/08
Loc: blackpool
Taken this September when testing my Atik camera, 30 frames stacked in registax and tweaked in photoshop. Moon was a bit low and suffered a lot of heat haze coming from the roofs opposite me, the scope also fogged up slightly.
14" meade lx200gps.
Atik 1HSII ccd.
spc900nc ccd
3" F3.5 finder with 0.5 focal reducer.
Fusion
Reged: 01/27/08
Loc: Amory, MS, USA
I guess I'll give it a go. SPC900NC 8SE at f/10 Best 1000/3500 frames process in Registax Seeing - 3/5 slight haze
I deleted my first entry after a reprocess.
Meade DSIc
QHY8 on the way.
knuklhdastnmr
Pepperbelly
Reged: 02/24/05
Submissions are now closed.
6 registered and 8 anonymous users are browsing this forum.
Moderator: Charlie Hein, knuklhdastnmr
