Privacy Policy |
Please read our Terms
of Service | Signup and
rodelaet
Reged: 04/28/06
Loc: 50°56' N - 4°58' E (Belgium)
A front surface mirror like the Sky Window can collect a lot of dust over time.
I tried a few solutions to clean it gently without scratching it.
I came up with the following idea. There is this polymer solution called 'first contact'. It's a polymer that needs to be applied as a viscous liquid over the surface. After drying, the polymer can be peeled of like a film off the mirror surface. It removes dust that way. I find it a little too expensive to use it for my mirror.
I tried the same with : tape, like Scotch Magic Tape. Here is a picture of the mirror covered with the tape.
-------------------- Rony
My Astronomy Sketches
My Binocular Sketches
Edited by rodelaet (09/26/08 12:09 PM)
rodelaet
Reged: 04/28/06
Here is the mirror being cleaned from dust.
rodelaet
Reged: 04/28/06
This solution might work best on flat surfaces.
Don't know if it can be applied at lenses and curved mirrors.
refractory
Reged: 02/05/05
One problem with tape might be adhesive residue left behind. I used to work in the adhesives industry and some tapes leave more behind than others. Try collodion?
Jess Tauber
leo9
Reged: 06/17/08
Loc: Western Oregon, USA
Yikes! Take a tip from an ex-pro photographer... Just Say NO to tape, or special solutions that promise to lift the gunk off! I ruined a $1800 telephoto lens "cleaning" it with a solution used by pro lens and camera repair types (they know how, and more importantly -how much- to use) Talk to the gang on the reflector board... They have all sorts of solutions for cleaning reflector mirrors... Please avoid tape in the future, the glue residue will capture more dust than you can imagine... assuming it actually leaves the surface intact.
-------------------- Nikon 12x50 Action; Pentax 8x40 PCF WPII
Bogen 3220 w/3way+qw
Trico SkyWindow
Mr Q
Reged: 02/25/08
Loc: N Central New Mexico
I'm wondering if by using tape, when you remove it, does the action leave a static charge on the mirror surface? If so, what a quick dust magnet that would be! The only place I would ever put tape on a mirror is at its "blind spot" on a newt mirror for collimation purposes only. Mr Q
-------------------- What goes around, comes around, eventually.
Meade DS-10(10" newt)
10x50, 10x70 binos
Wes James
Reged: 04/12/06
The action of pulling plastic/magic tape off a surface WILL generate static electricity/create a charged surface.
-------------------- Wes
Atlantic Beach, FL
Some bino’s from Miyauchi 5x32 Binon's up through Garrett 20x110 Signature's,
Some telescopes from a Stellarvue 80mm NHNG up through a couple of 8” reflectors…
And a wonderful 4.25" Delmarva Shiefspiegler!
Some good friends, made here on C/N.
Oh- several cats and a wonderful wife!
Anyone want a cat???? :-O
"When your work speaks for itself- Don't Interrupt" -Gamble Rogers
rodelaet
Reged: 04/28/06
Thanks for the advice , guys!!
4 registered and 19 anonymous users are browsing this forum.
Moderator: EdZ
