extremez
Reged: 03/10/07
Loc: South Glens Falls, NY
what determines the exposure length of imaging DSO's? can you judge by the histogram of the frame? i was out last week and shot somewhere up to 80 images of m31 at anywhere from 20-30 secs. i didn't have that great of a polar allignment so i didn't go for longer.
putting 20 frames together with registax and messing around doesn't bring anything out.
are exposure times too short? is it my processing? any idea or thoughts?
here's 1 frame from that night. it's 30 seconds so you will see some trailing due to the bad allignment.
M31
-------------------- I'm a newbie and loving it!!
C8-SGT XLT w/ CG-5 mount
William Optics ZenithStar 80
Orion ShortTube 80(guide scope)
Canon EOS Rebel XT unmodded
Philips SPC900NC webcam
nofxrx
Reged: 07/12/05
Loc: palm bay,florida
I would think that 80 frames would give you something,not APOD worthy,but something... Try DeepSkyStacker.Its free and is designed for DSO image processing/stacking. Registax is made for planetary processing.Could be your problem. Try stacking them all in DSS and see what you get...
-------------------- Brent Oliver
3 Wonderful dogs: Sadie, Kara and Ozzie
Celestron C10-N///C9.25///Orion 80ED///WO ZS66SD White
Celestron CI-700 & ASGT Eq. Mounts
Nikon D40Xa///SBIG ST-402ME/Class 1/CFW///DSI-PRO...
My Gallery
Ohh yeah,and a VERY undersanding wife!!
Kolenka
Reged: 06/01/08
Loc: Seattle Area, WA, USA
Also be aware that M31 is tricky because of the bright core, with the very dim outer regions. If you are starting out, it can be tough as it requires 2-3 different sets of exposures of different lengths to get a really good shot.
Usually the histogram will give you an idea, but with how bright the core is, you could get fooled. So really, you should go by what shows up in the subs, because if it doesn't show up in the sub in some way, it won't show up in the final image.
-------------------- Meade 10" LX200R
Orion 80ED
Nagler 7T6, 9T6, 13T6, 17T4, 26T5
Canon XSi (Modded), TIS DMK 31AF03
Northwest Astro Photoblog
cam1936
Reged: 08/01/08
Loc: Alberta, Canada
On a lot of DSO objects it's as long as you can go without trailing or without background noise washing out your picture. On M 31 it's as long as you can go without trailing and without burning out the core because it's so bright.
-------------------- C8-SGT
Nikon 10x50 Action Ex
Canon 350D
Manfrotto tripod
Various EPs and accesories
ChazK
Reged: 11/23/05
Loc: Melbourne, Florida
You need about 2-3 hours for M31. To beat the S/N ratio I shoot for 2 minute subs at the very least. Drift alignment will have to spot on unless you AG
-------------------- Tak TOA 130mm/NJP Temma2
Tak FS 60CB
Canon 40D (unmodded)
Astronomik CLS
Canon EF 28-135mm f/3.5-5.6
www.digitalunatic.com
ChazK
Reged: 11/23/05
Sorry as to your M31 image. You have more data there than you think. You need to increase the RGB using curves in photoshop or some processing software. What program are you using?
Tak FS 60CB
Astronomik CLS
extremez
Reged: 03/10/07
I'm using PS elements 5 with Noels tools. I can't seem to find a turorial on processing though. when you say increase RGB what do you mean?
I did download DSS and stacked 67 images of various exposure lengths. This is what i tweaked out of it.
M31 2nd attempt
scully1234
Reged: 09/04/07
Loc: Rush, NY
Hey Extremez your second attempt is excellent for such short exposures !
Use the POLAR ALIGN MOUNT utility in your handset and try again. The polar align utility will give you very good polar alignment. It doesn't take long at all to run through it. Once you have done it you should be able to get two or three minute exposures.
If you can manage about 25 one minute exposures for the core then 25 two minute exposures for the outer arms you will get some very nice results !
-------------------- Astrophotographer wannabee !
Woot ! check out new cam in the equip list !
Celestron C8 XLT on the CG-5 mount
Meade 70mm AZ guide scope
Canon EOS 450D (xsi)
DSI color
Canon A530 point-n-shoot
Edited by scully1234 (10/04/08 09:41 AM)
Nils_Lars
Reged: 01/04/08
Much better , just add some more longer subs and youll have a great shot there.
-------------------- Erik
Orion ED 80
Orion Atlas GOTO mount
Williams Optics reducer
Various eyepieces and other gear
Baytronix 80mm guidescope
Orion Starshoot Autoguider
PHD guide
Canon 400D (unmodded)
Stilleto Focuser
NexImage webcam
http://home.comcast.net/~eriknlarsen/site/?/photos/
Stardaug
Reged: 08/03/08
Loc: Ontario, Canada
@extremez - your first image looks exactly like mine. I had the same problem. From what I've learned from the helpful people on here, I just needed more exposure time and more shots to stack. Your second attempt is much better. I'm hoping to achieve some better results soon. I've got the astrophotography bug!
Cheers!
-------------------- Shawn / Ontario, Canada
Celestron CPC800 SCT w/XLT
Ball bearing mod on AZ
Skywatcher Equinox 80mm ED 500mm refractor
Canon Rebel XT 350D unmodded
ADM Counter weight system
and a Telrad!
