rodelaet
Reged: 04/28/06
Loc: 50°56' N - 4°58' E (Belgium)
NGC 7293, The Helix Nebula.
Planetary nebulae are not that popular among binocular observers. Most of then remain invisible or appear like meaningless small dots in binocular instruments. Such is not the case with NGC 7293, known as the Helix or Helical Nebula. At a distance of 450 l-y, the Helix is the brightest and the largest ‘specimen’ of the planetary nebulae. Its diameter measures ¼° across. Nevertheless, the Helix is a very dim target. Its integrated brightness of magnitude 7.3 is spread over an area as large as ¼ that of the moon’s full disk. Add to that the fact that this planetary remains low to the southern horizon for mid-northern observers, and you’ll understand that the Helix can be a challenging object. I had seen it only once with a 100mm refractor, equipped with a UHC filter. So I was curious to see if I could find NGC 7293 with a pair of binoculars. The Helix can be found near the centre of the triangle formed by Delta Capricorni, Delta Aquarii and Formalhaut. I tried my luck during a clear moonless night in the French Alps. I first started my search with a pair of 8x56. I soon noticed a faint puff of smoke in the field of view. Object found! The nebula was clearly visible with averted vision as a round smudge. I suspected two faint stars bordering the west side of the nebula. The 8x56 did not reveal any particular detail in the nebula. When I finished my sketch, I mounted my 15x70 TS Marine binoculars. These binoculars provided a darker background and a better contrast. I could clearly discern more faint stars around the Helix. The nebula appeared to be brighter around its edge than near its centre. The northern rim appeared to be the brightest feature of the planetary disk, and its brightness added to the impression that the disk showed a darker centre. I was pleasantly surprised to see such details without the aid of any filter.
The sketches are presented at the end of the post. The first sketch is my impression with the 8x56 Bresser. The sketch made with the 15x70 TS Marine can be seen in the second post.
The observation with a 100mm refractor can be seen here.
Site : Le Castellard Melan, France ( 44° N )
Date : September 28, 2008
Time : around 21.00UT
First Binoculars : Bresser 8x56
FOV: 5.9°
Second Binoculars : TS Marine 15x70
FOV: 4.4°
Filter : none
Mount : Trico Machine Sky Window
Seeing : 2/5
Transp. : 4/5
Sky brightness : 21.33 magnitudes per square arc second near zenith (SQM reading).
Nelm : 6.5
Sketch Orientation : N up, W right.
Digital sketch made with Corel Paint Shop Pro X2, based on a raw pencil sketch.
(Note: if the sketch does look too dark on your monitor, try to darken the room.)
First sketch : Bresser 8x56.
Edited by rodelaet (10/05/08 12:42 PM)
rodelaet
Reged: 04/28/06
Here is the second sketch with the 15x70 TS Marine.
-------------------- Rony
My Astronomical Sketches
My Binocular Sketches
Callibrate your Monitor with this little strip.
Edited by rodelaet (10/05/08 12:11 PM)
WadeVC
Reged: 12/02/05
Loc: Lodi, California,
Not only are those excellent sketches Rony, but they also convey perfectly what one can expect to see in the night sky through a low-power EP or binos.
Impressive and excellent!
Orion XTi10 f/4.7
Orion XTi8 f/5.9
Meade NGC 70mm f/10
Orion UltraView 10x50 Wide-Angle Binoculars
My Sketch Gallery
My Astronomy Blog
A wise man can see more from the bottom of a well than a fool can from a mountain top.
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
Very evocative sketches! They do convey an accurate impression of their appearance in binos.
On one astoundingly clear night back in the mid-nineties, while spending the night floating in an inflatable rubber boat anchored in the middle of a small lake (Lat. 45N), I could just see the Helix in my 2.3x40mm Owl Eyes. In a 7x35 it was dead easy.
-------------------- Home-made 11X50 right angle bino, 8.1 deg. FOV
Modified 26X100 bino, 3.5 deg. FOV
Home-made Mk II RA bino, using interchangeable objectives and eyepieces
My Gallery
Mediocre minds discuss people. Good minds discuss events. Great minds discuss ideas.
Reged: 06/13/06
Loc: Illinois
Rony,
Beautiful sketches of this nearby planetary nebula. The first really good look I had at this target was through a pair of 80mm binoculars at a very dark site long ago. Your sketches bring back that memory in a vivid fashion. Wonderful work guy.
Frank
-------------------- my gallery
rodelaet
Reged: 04/28/06
Wade, Glenn and Frank,
Thank you for the posts!
@ Glenn : none of my business, but did you take the boat out just to observe from the middle of the lake?
CarlosEH
Reged: 01/19/05
Loc: Pembroke Pines, Broward County...
Rony,
Wonderful and accurate observations of the Helix Nebula (NGC 7293) in Aquarius. This extended celestial interloper appears within the Water Bearer as a "ghostly figure" as in your fine renderings. Many observers believe it to be more prominent based upon excellent observatory-class images posted such as the one below. Thank you for sharing it with us all.
Links; http://www.hawastsoc.org/deepsky/aqr/aqrp.html http://www.hawastsoc.org/deepsky/maps/aqr/aqr2p.gif http://en.wikipedia.org/wiki/NGC_7293 http://apod.nasa.gov/apod/ap030510.html
Carlos
rodelaet
Reged: 04/28/06
Carlos,
Thank you!
Your words and links to the beautiful pictures are much appreciated.
cildarith
Reged: 08/26/04
Loc: San Diego, CA
Rony, these are an excellent pair of comparison sketches! I hope you'll have the opportunity to do more of them.
-------------------- Eric
6" f/6 Parks Newtonian
10x50 Bushnell Binocs
CN Sketch Gallery||MinDat Mineral Gallery
rodelaet
Reged: 04/28/06
Thank you, Eric!
While thes comparison sketches are fun, they do take a lot of my energy, like all these sketches do. On a typical night, I feel exhausted and loose my concentration after four or five sketches. It is a hard choice then between comparison sketches or new objects.
GlennLeDrew
Reged: 06/18/08
Rony, I did indeed paddle out to the middle of the lake to observe from my floating platform all night. (Earlier in the day I'd been fishing.) And man, oh man, was that a GREAT night! Naked eye dark nebulae in Scorpius almost to the horizon! And when I held myself as still as possible while looking over the side, looking straight down toward the water I could very clearly see the reflection of the milky way when Cygnus was overhead (not to mention the rest of the milky way at the appropriately smaller angles toward the horizon.) I could almost feel myself floating in the depths of space.
My Gallery
rodelaet
Reged: 04/28/06
Glenn,
That must have been a magical situation : stars above and stars below.
rodelaet
Reged: 04/28/06
Just for the record : I've been running through my observation notes and verified dates and times. The time of observation should be : 20.00 UT for the 8x56 observation, and 20.30 UT for the 15x70 observation.
