Privacy Policy |
Please read our Terms
of Service | Signup and
Erix
Toad Lily
Reged: 12/25/04
Loc: Ohio, USA
November 2007
Jeremy Perez Subject: Comet 17P / Holmes Date/Time: November 7, 2007, 9:00 - 11:30 PM MST (November 8, 2007, 04:00 - 06:00 UT) Observing Loc: Flagstaff, AZ - Home Instrument: Orion XT8 (203 mm dia./1200 mm F/L) Eyepieces: 32 mm Sirius Plössl (38X / 66 arc minute TFOV) Conditions: Calm, intermittent high cirrus Seeing: 4/10 Pickering Transparency: Mag 6.0 NELM
-------------------- Erika
Automatic doors make me feel like a Jedi.
Zhumell 16", 10" LX200 Classic,Orion ED80, ETX70-AT, DS Maxscope 60mm
My CN Gallery * 2007 July - tracking NOAA10963
Erix
Toad Lily
Reged: 12/25/04
Loc: Ohio, USA
December 07
John K (John Karlsson)
Vernon BC Canada
Erix
Toad Lily
Reged: 12/25/04
Loc: Ohio, USA
January 2008
Erika Rix PCW Memorial Observatory, Lat: 40.01 Long: -81.56 Sun in H-alpha featuring NOAA 10980 and 10981 2008 01 04, 1720UT - 1820UT
Equipment: DS Maxscope 60mm, 40mm Pro Optic Plossl, 21-7mm Zhumell Zoom, LXD 75
Sketch Media: Black Strathmore Artagain paper White Conte’ Crayon and pencil White Prang pencil Charcoal White vinyl eraser Black pen
Post processing: Scanned in Photoshop, added contrast and subtracted brightness, resized and arranged collage. Digital sun insert from Tilting Sun program.
Erix
Toad Lily
Reged: 12/25/04
Loc: Ohio, USA
February 2008 kraterkid (Rich Handy)
Subject: Naked eye view of the lunar eclipse on February 21, 2008
Time: 8:59 PST to 9:07 PST Seeing: Antoniadi IV Weather: Cloudy with intermittent light showers Phase: 359.2 deg Colongitude: 86 deg Lunation: 14.05 Days Notes: A perfect bite, a bit hazy about the edge Medium: White Conte' Crayon on black Strathmore Artagain paper Sketch size: 9" X 12"
Erix
Toad Lily
Reged: 12/25/04
Loc: Ohio, USA
March 08 Jeff Young
M81 Sketch HB pencil on 160gm cartridge paper. Scanned and inverted in Photoshop. Scanner dropped the outer shading, so it had to be added back in using Photoshop.
Erix
Toad Lily
Reged: 12/25/04
Loc: Ohio, USA
April 08
Acheron Messier 101 GSO 300D - 12" f/5 Dobson Newtonian Reflector Baader Hyperion 13 mm - 115x 27 April 2008 - 20:30 to 21:30 UT Sketched from Petrova gora at 500m above mean sea level, Croatia A4 150gr paper, graphite pencil Scanned with Canon Lide25 and processed in Photoshop CS2
Erix
Toad Lily
Reged: 12/25/04
Loc: Ohio, USA
May 08
Sol Robbins April 9, 2008 Scanned Pencil Sketch of Jupiter. 6" Skywatcher Refractor, Chromacor II, Burgess Optical Nebula Filter, 5mm BO/TMB Planetary Eyepiece @ 224x.
Charlie Hein
Reged: 11/02/03
Loc: 26.06.08N, +80.23.08W
June 2008 - Jeff Young:
A somewhat dim but highly detailed solar prominence, as observed from County Louth Ireland, at 8:45 AM on June 20, 2008. The sketch was done with a white Derwent Graphitint pencil on black Artagain paper. Drawing time: 10 to 15 minutes. The tilting Sun graphic was added in Photoshop.
Equipment included a 0.7-angstrom 70mm Solarscope h-alpha filter, Tele Vue Pronto, Solarscope 20mm blocking filter, Astro-Physics BARCON, Baader MkV binoviewer and a pair of 15mm TV Plossls.
-------------------- "He's dead, Jim - I'll get his wallet, you get his tricorder." - Leonard "Bones" McCoy
Weston CSC:
Charlie Hein
Reged: 11/02/03
July 2008 - markseibold:
Moon, 2 days past full July 20th 2008 Midnight ~ 2 AM, observed through Nexstar 5i with 32mm Plossl and 12mm Plossl for close-up inset image in detail.
*Sky clear, calm; seeing estimated as 9/10. *Temperature 63 deg F dropping to 58 with dew point rising fast.
Observed through a Nexstar 5i at low and medium magnification, my original intention was to render this sketch as the whole moon.
Materials used:
Canson Mi Tientes medium tooth Blue Indigo paper of 20” X 24”.
Old antique pastel chalk sticks in square sticks and round include Sargeant, Grumbacher, Eagle Prismapastel, and various carbon greys as Swan Stbilo CarbOthello brand; I have purchased a few new ones as small square sticks. These are NuPastel. I have never used a blending stick. Only cotton swabs, Q-Tips and occasionally my bare fingers although I abstain from that as I know that it destroys the paper surface. I have never used a fixative on any of my works so they are vulnerable to smearing, thus kept stored until determination of whot to do with them in many requested prints now. Occasionally but not too often I accidentally smear some chalk in the void blank areas. I will lightly clean off or erase those areas with a dampened cotton swab before photographing the work with a 5.1 megapixel Sony Cybershot under north daylight or photoflash at night. If exposure is insufficient, I will drop brightness in Photoshop by a fer points and raise the contrast an equal amount. Color balancing is done with the camera settings per the ambient light- True north UV daylight or photoflash.
This was the first time I also used new chalk pencils by Faber Castell in snow white and a Swan Stabilo in cream white.
Much of the color on the whole moon was left as unblended with the exception of some small portions as you can see. That image is to be somewhat impressionistic yet I have rendered the actual craters and maria as accurate in position and placement as I could in under 2 hours (25 ~ 30 minutes of that time was spent on the close-up inset detail which actually became the final work for this forum.) Finally my left hand was omitted from the lower potion of the work with Photoshop erasure so as to not clutter the subject matter, hence the vignetting in the lower edges of the blank blue indigo paper.
Weston CSC:
Charlie Hein
Reged: 11/02/03
August 2008 - WadeVC:
...here is my submission of the King of the Planets, Jupiter
Weston CSC:
Charlie Hein
Reged: 11/02/03
September 2008 - markseibold:
I would hope to see others lunar sketches in the monthly contest so perhaps this may inspire. It is the largest work that I have attempted as free-hand of the moon yet. Thanks to seeing Rich Handy's tutorials. This is on a fine textured Strathmore paper in Stygian Black in 19" X 25" that I found to be flawed with vertically parallel embossed lines through it after I began the work.
The moons disc was created with a home-made extended string fashioned compass and chalk pencil from another small compass hinge pin. The lunar disc is drawn at 14" diameter. The size did not allow to finish details on the first night in early September 2008 (moon date at 8.5 days), so I continued the central maria regions on the second night at 9.5 days, but left the terminator untouched. While finishing the details on the second night, I added the quick close-up sketch of Mare Imbrium on 9" X 12" Artagain paper if only to represent the feature of the fading light at the terminator edge at bottom. Some surface details in the mare area were left out or omitted due to time allowance. Pastels included new Rembrandt, antique Sargeants, and Prismacolor in various white and off-white, Swan Stabillo antique chalks in various greys. Faber Castell white chalk pencil. Minimal blending was done with cotton swabs.
*The two pastel sketched images were photographed with a digital camera under natural daylight, then sized and joined as a single theme and effort with use of Photoshop for online display here.
Observed through a 10.1" f/4.5 Coulter Dobsonian with a 32mm eyepiece. Seeing was considerably good at approximately 8 ~ 9/10. Temp 60 deg F, dropping to 57 F with still air on both nights.
Weston CSC:
Charlie Hein
Reged: 11/02/03
October 2008 - markseibold:
3.3 Day old moon from a hill-top in Portland Oregon. A 19" X 25" pastel with the lunar disc sketched at a 12" diameter.
Weston CSC:
Charlie Hein
Reged: 11/02/03
November 2008 - Michael11:
Horsehead nebula region sketch, made on a white paper using graphite pencil. Location: Negev Desert in Isael, Time: November 1st 2008, 02:00 Telescope: 8" Orion SkyView Pro Newtonian. Eyepiece: Sirius plossl 25mm, Ultrablock filter
Weston CSC:
Charlie Hein
Reged: 11/02/03
December 2008 - markseibold:
The November 30th 2008 Great Conjunction. The scene so talked about at the beginning of December 2008 which became the most photographed lunar planetary conjunction in in photographic history. As I drove through evening fog heading west in east Portland Oregon, I witnessed a scene of the new crescent moon setting in the western sky with Jupiter and Venus above. I raced home to grab my portable Nexstar 5i and to a hilltop where I could observe the moon above the fog to render the surface details at the terminator. The street scene was added later at home from the memory of driving.
Sketched on Strathmore 19" X 25" Artagain Paper with various pastel chalks.
Weston CSC:
Charlie Hein
Reged: 11/02/03
January 2009 - markseibold:
Moonrise with Saturn - Pastel Sketch on 19" X 25" format-
Tuesday night January 13th in very still air at 33 degrees F, yet poor seeing conditions, I decided to observe the moons spectacular terminator line with my 10.1" f/4.5 Newtonian and render this impressionistic and somewhat accurate pastel of the moons terminator line and as it was low and ‘warmed in color’ by the atmosphere. A 32mm Plossl was used for the general whole moon and a 12mm and 9.7mm for medium close-up details although the bad seeing (5/10 ?)did not allow much magnification.
A spectacular phase it was! I spent about an hour from Jan 13th 11:45 PM PDT till 1 AM Jan 14th roughing in the terminator and other key details, then retreated to indoors with use of a several digital photos I took through the eyepiece with a 9.7mm Plossl for close-up and 32mm for wide field for reference to recheck positions of and fill in the mare and other general surface features.
As Saturn was a few degrees above left of the moon I decided to add it in here, albeit a little out of distance scale from the moon yet showing the poor seeing conditions, I could barely make out Titan to the planets left, it is to accurate scale in apparent size to the live observation of the moon with a 32mm plossl at low power.
The paper was not what I would have preferred, a 19" X 25" Strathmore in rich blue with embossed ridge, my last available sheet. An undesired ridge-line shows through the surface. The moon was sketched at 15 inches diameter with various pastel chalks and mostly kept in the warm golden range of colors due to the appearance of it rising low in the atmosphere. I photographed the pastel image today in daylight for accurate pastel color representation.
Mark
Weston CSC:
Charlie Hein
Reged: 11/02/03
February 2009 - Erix:
This was done entirely at the eyepiece. The collage was put together in Photoshop after photographing my sketch (rather than scanning).
2009 Feb 13, 1600UT – 1700UT Solar prominences in h-alpha, western limb
PCW Memorial Observatory, Zanesville, Ohio USA Erika Rix
DS 60mm Maxscope, LXD75, 21-7mm Zhumell Sketch created scopeside with black Strathmore Artagain paper, white Conte’ crayon and pencil, white Prang watercolor pencil.
Temp: 3° C, Humidity 60% Seeing: Wilson 3, Transparency: poor Scattered, winds 7mph from NNW Alt: 34.4, Az: 159.2
Approximately 30° inward from the eastern limb, a crescent-shaped plage was seen with a dark dot during my h-alpha observation. No AR was noted in white light. There were a few proms scattered about to the north and south, but the prominences on the western limb really stood out. At first glance it looked like two detached proms, but adjusting the outer etalon and increasing magnification, that section of limb came alive with prominence structure.
Weston CSC:
Charlie Hein
Reged: 11/02/03
March 2009 - - Aldebaran:
Object: Messier 51 Time: 19/20.3.2009 Observing site: Länsi-Turunmaa, Finland Instrument: Newton 10'' Conditions: Clear sky, calm, 17,6 F (-8 C degrees)
Weston CSC:
Charlie Hein
Reged: 11/02/03
April 2009 - markseibold:
I observed the moon with the public on ISAN April 4 and 5 2009 with use of a Nexstar 5i. I returned home for solitary observation through my 10.1" Newtonian; 32mm Plossl and 9.7mm Super Plossl eyepieces with medium ~ good seeing conditions; light breeze at 51 degrees F, from 6 UT ~ 8 UT April 5 to produce this large 22" X 30" multiple pastel impression on black Stonehenge paper with various off-white, blue and grey dry pastel chalks. Several areas of the terminator and surface areas were rendered in detail with medium high magnification at 180X; finally adding the artists conception from the surface of the moon at bottom. -Mark
Weston CSC:
Charlie Hein
Reged: 11/02/03
May 2009 - Roel:
For the last 2 nights I have made some deep sky sketches with my home build 60 mm F/6,9 achromatic refractor. It's made out of a 20-year-old Novalux 60/415 lens and some spare parts from various other scopes. The chromatic abberation is horrific om Moon and planets, but this tiny telescopes does give me surprisingly pleasant views of some of the brighter deep sky objects. It made me so enthousiastic I want to sketch evering I see through it! I also have a 12,5" Dobsonian but sometimes, when time is short and weather is unpredictable, bigger is not always better! All sketches are made under a suburban sky. M8 was only 15 degrees above the southern horizon when I made the drawing.
Weston CSC:
Charlie Hein
Reged: 11/02/03
June2009 - Michael11:
M52 and NGC7635 (the bubble nebula region) in Cassiopea. Sketched with graphite pencil on white paper. Location and conditions: Negev Desert in Israel, ~6.3m sky, mediocre seeing. Instrument: Orion Skyview Pro EQ Newtonian, Sirius Plossl 25mm Eyepiece, with Orion Ultrablock filter. 40x magnification, at 1.25 degrees FOV. Date and time: 23.05.2009, 04:00 Objects info: M52: Open cluster, 7.3m NGC7625: emission nebula ("The Bubble Nebula"), 10m Notes: Only the brightest part of the "bubble" was visble. However in one FOV with the M52 open cluster it forms quite a nice view.
Weston CSC:
1 registered and 0 anonymous users are browsing this forum.
Moderator: Charlie Hein, cildarith
