Observing >> Deep Sky Observing
Astrojensen
Reged: 10/05/08
Loc: Bornholm, Denmark
Observing report, October 8th/9th, 2008 new
      #2688523 - 10/09/08 06:07 AM
Hi friends
Yesterday afternoon was very clear, so I expected a great night. There was a little wind, which I hoped would keep the dew at bay. Unfortunately, that didn't translate into great transparency as I'd hoped, but more about that later.
I went out around 8PM, to look at the Moon, using my 60/850mm Zeiss E. The seeing as a little soft, so I just cruised around a little, and did not bother looking for extreme detail. Clavius was coming nicely out of the morning shadows, as was Copernicus.
After looking at the Moon for a while, I took the scope to the other side of the house, to look a bit at the stars. I looked a little at the double cluster and a few other things. I wanted to look at doubles, but the E 60 doesn't have a finderscope, so finding dimmer stars is a bit of a challenge, especially since the scope was set up to take 0.965" eyepieces. Biggest field I could get was about 1.3 degrees.
I did get a very nice look at Gamma Andromedae, using 170x. The colors were beautiful, and the diffraction rings sharp and almost steady. A really fine view.
I decided to go to bed at around 10 PM, and get up around midnight, when the Moon had set. I overslept a little, so I only got out around 1 AM.
Equipment used was my Zeiss Telemator, Zeiss amici turret and 32mm plössl, 25mm Kellner, 16mm and 10mm Zeiss orthos.
To my dismay, the sky was not very transparent, and had a steel grey look. The stars were shining quite brightly, but the contrast was really suffering tonight. I was not going to the "mountain site" tonight, but just observed from my backyard, inside the little village of Østermarie. The streetlights turn off at midnight, so they weren't an issue. Only light was from the windows of the neighboring bakery, which were mostly covered by my hedge.
I began by taking a peek at M31. Hmm. A bit bland. I had great dark adaption after the sleep (got dressed and everything, without turning on the lights), so the view was a bit depressing. I could see most of the field stars around G1, so again, I was operating near mag 13.
NGC 891 was not as good as Monday evening, though it was definitely there.
I decided to continue visiting old friends, instead of hunting for new targets. NGC 925 was next. This one was really faint. At 26x and 32x, I could barely see it. I had to use U2000.0 to find it. Normally, I've been able to sweep it up. Since I had the atlas out anyway, I decided to visit a few more galaxies in the area. NGC 890 was close by, so I took a look. It was very faint, small and concentrated. Round and featureless. 53x was best.
NGC 750/751 are a couple of galaxies in the process of merging. They looked like a small elongated fuzz at 53x. NGC 736 nearby was even fainter, and looked slightly elongated, evenly illuminated and with no other features.
NGC 777 was next, but I couldn't see it, which confused me, since I've seen it before, and it's brighter than 736. Then the stars began to fade out. Dew on the eyepiece? No, a lot of clouds moving in fast.
Oh well. I took a peek at the Orion Nebula, low in the SE. It was nice, but not very impressive. In a few minutes, clouds covered most of the sky, so I went to bed again.
Clear skies!
Thomas, Denmark
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
Re: Observing report, October 8th/9th, 2008 new [Re: Astrojensen]
      #2689935 - 10/09/08 08:09 PM
If the daytime sky was a deep blue, yet at night it was 'steel grey', I'd guess the natural airglow was on the bright side. It can vary in brightness fairly considerably, and on quite short time scales.
But in the end, you did get to capture some stellar photons!
Home-made 11X50 right angle bino, 8.1 deg. FOV
Modified 26X100 bino, 3.5 deg. FOV
Mediocre minds discuss people. Good minds discuss events. Great minds discuss ideas.
Astrojensen
Reged: 10/05/08
Re: Observing report, October 8th/9th, 2008 new [Re: GlennLeDrew]
      #2690470 - 10/10/08 03:23 AM
Hi Glenn
If it was airglow, which I doubt, it surely was extremely bright. From what I've read about airglow on the web, it is a quite subtle phenomena. The limiting mag naked eye on the last night was not much better than 5.
I am observing from an island, at less than 300 feet altitude, or just above that. The air is almost always filled with moisture. On the good side, light pollution is quite low, and near-pristine skies are easy to find. Heck, I can see M13 naked eye from my own backyard, when civil twilight is not quite over yet, IF the air is dry and clear. On such nigths, I have seen wonderful things.
But, as you said, I did catch some photons. Beats looking at them on the web.
Clear skies!
Thomas, Denmark
Edited by Astrojensen (10/10/08 03:25 AM)
timokarhula
Reged: 01/30/06
Loc: Sweden
      #2690486 - 10/10/08 04:10 AM
So you have seen M13 naked eye when the sun has been less than 6 degrees below horizon?! I guess you mean before the end of _nautical_ twilight (less than 12 degrees)? It is then when I can spot M13 on good nights.
/Timo Karhula
Astrojensen
Reged: 10/05/08
Re: Observing report, October 8th/9th, 2008 [Re: timokarhula]
      #2690660 - 10/10/08 08:56 AM
Hi Timo
Ooops! Sorry, my bad! I was of course thinking of Nautical twilight, as you said.
Clear skies!
Thomas, Denmark
3 registered and 1 anonymous users are browsing this forum.
Moderator:  matt, Olivier Biot
Home
