coopman
Reged: 04/23/06
Loc: South Louisiana
I need some ideas on how to make this EP easier to pick up w/o fear of fumbling it. It is very smooth, and after it gets a little moisture on it or I'm wearing gloves in the winter it is very hard to handle. I tried to see if I could sent TV an e-mail, but I could not find an e-mail address on their website. I need to get some sort of rough knurled rubber sleeve (or equivalent) that I can add to the upper barrel. Any ideas? Thanks.
-------------------- Regards,
Clay
"The heavens declare the glory of God; the skies proclaim the work of his hands." Psalms 19:1
kaaikop
Reged: 07/13/08
Loc: Ste-Therese, Canada
It might get messy after a while, but you could stick the "hook" part of velcro tape... this way the EP would really "stick" to those fleece gloves
-------------------- Benoit, RASC Montreal
-C 9.25XLT on EQ6 Pro / ED80SF on Portamount
-Plossls, Radians, Naglers, LVW's & Orthos.
-a pair of 7x50's
coopman
Reged: 04/23/06
Ha, then I'd need some advice on how to remove an eyepiece from my glove!
Clay
csa/montana
Astro Ambassador
Reged: 05/14/05
Loc: montana
Clay; I purchased some black shelf liner at K-Mart, that is a rubberized item. You could cut a strip of this, & using double-stick tape, or a dab of glue adhere it to your eyepiece.
If you want to try it, PM me your address, & I'll send you enough for your eyepiece.
-------------------- Carol
AstroTech 16" Dob (Thanks ASTRONOMICS!)
AstroTech 66ED / Vixen 80MF/AstroTech Voyager
Masuyama's 7.5, 15, 25W, 35mm,
Tak LE 5mm B/TMB 3.2
7mm Pentax XL, 10mm Pentax XW
14mm Meade 4000 UWA
22mm Pan, 35mm Pan
DreamCatcher Dobservatory, #2
AstroPhethean
Reged: 03/04/08
Loc: Aberdeen, UK
I was too thinking of a grip for my 32mm TV Wide Field.
I had the idea to use lots of rubber bands around the body...
Andrew
-------------------- Observing kit:
16" Lightbridge
7mm TS Planetary, 8.5-12mm Antares Speers-WALER, 18mm Meade S5K UWA, 32mm TV Wide Field.
Set of 4, 6, 10 and 16mm Zeiss Abbe-II orthoscopics and 2x Abbe barlow in a beautiful walnut case.
Imaging kit:
Skywatcher 8" newtonian and Orion ED80 side-by-side on EQ6.
Sony alpha-300, Atik 1-HS and 2-HS CCD; Minolta Film SLR.
John Fitzgerald
In Focus
Reged: 01/04/04
Loc: AR
You could get a couple of thick neoprene O-rings from a parts store and slip them over the body to give something to grip.
Observing since 1966
Messier Cert #898
csa/montana
Astro Ambassador
Reged: 05/14/05
Loc: montana
Good suggestion, John.
14mm Meade 4000 UWA
22mm Pan, 35mm Pan
John Huntley
Reged: 07/16/06
Loc: South West England
You could cut a couple of rings of rubber from a cycle innertube and stretch those onto the eyepiece body. The inner tube should be a fair bit smaller in diameter than the eyepiece of course so that the rings grip tightly.
I used this method to replace the rubber grips on my ED80 focusser wheels when they perished.
John
-------------------- Vixen ED102SS F/6.5 Refractor
Skywatcher 203mm F/5.9 Dobsonian
Vixen Portamount
Naglers: 31mm T5, 22mm T4, 13mm, 9mm, 7mm and 5mm T6's
Powermate 2.5x
Revelation 2.0" Dielectric Diagonal
Jaimo!
Reged: 10/11/07
Loc: New Jersey
This may also be an option...
http://www.televue.com/engine/page.asp?ID=223
It seems Tele vue offers a retrofit rubber eyeguard for that EP, that could give you something to grab onto & a little better seeing at the same time.
Jaimo!
-------------------- Meade ETX-90/AT
WO ZenithStar 66 SD APO
Zeiss 50/540 ATM Refractor
spaceghost
Reged: 01/04/07
Loc: Olathe, KS
Maybe just take a rubber band and double it over and over the barrel till it's tight. Should give a good enough grip, and it won't budge. And you can take it off easily someday if you need to.
-------------------- Justin
WRose
Reged: 07/08/05
Loc: Colorado, USA
Lots of good ideas to try Clay. One thing to consider is the pliability of the material in cold weather. I've used rubber bands down to a little below 0° F but prefer neoprene O-rings which are good to -40° F. Whatever you decide, here's a suggestion that I use in cold weather. Get yourself some well fitting (snug) latex or nitrile gloves to wear under your regular gloves. They provide better grip in cold & moist weather and protect your hands from wind chill. While the rubber bands, O-rings, inner tube material, etc. are half the equation, your fingers are the other half.
-------------------- Clear Skies, Bill
coopman
Reged: 04/23/06
Thanks for the info, Bill.
Clay
PJ Anway
Reged: 06/04/03
Loc: Michigan's U.P.
Neatly cut a slice of a bicycle inner tube and you will have a black rubber band. Stretch this around the eyepiece and that should provide a nice grip.
-------------------- PJ
_________________
Lookum Observatory
Spooner 203mm
Showa 100mm
Zeiss 80mm
Tak 78mm
Rick Woods
Reged: 01/27/05
Loc: Inner Solar System
Use a couple of the thick rubber bands that hold broccoli clumps together. Two of those will give you a good firm grip. I've had two on my old TV 32mm plossl for many years.
-------------------- - Rick
14" LX200GPS
8" Meade 826C
