Privacy Policy |
Please read our Terms
of Service | Signup and
NeoDinian
Experienced Postmaster
Reged: 10/05/05
Loc: Rockford Illinois
Ok, have about 3.5 hours grinding done (total time). Still working 80 grit. (I wish I had 60 grit to get this quicker!)
My "Target" depth is .0833, and I'm currently at .0675. The mirror is ground out to about 3/4" from the edge (8" mirror), but my tool is only showing wear on the outter 50%, and nothing starting in the center yet.
My grind has been working 40% offset cordial strokes.
What should I be doing now? Continue as I am? If so, will I pass my depth? Should I change strokes now? Less of an offset?
-------------------- Neo... (Jeff)
10" LX200-GPS/SMT UHTC "Draco"
Rockford, Il.
NeoDinian's Eye on the Sky!
Coming soon:
astrosam
Reged: 05/14/08
I think you should definitely move in to a smaller offset, if not move to a centered stroke. You're .0158" off your target sagitta, less than 20% of the depth to go but 75% of the mirror is ground. The rule of thumb I was taught was you want to match your % of mirror ground with % of sagitta. So I think you're running deep and should move your stroke in. I'm concerned that you've dug a hole with the 40% overhang, at this 75% ground stage something like 20% overhang or center over center would be more appropriate I think.
I'd grind center over center alternating mirror/tool on top until it's ground to the edge. Keep an eye on the sagitta and if you're getting really close then focus more ToT to keep it from going too deep.
That's my 2 cents anyhow
Spoonsize
Vendor/Clothing
Reged: 08/27/04
His 2 cents is the same as my 2 cents...makes 4... anybody else??
-------------------- Steve Durham
www.margesmonograms.com
(Marge made me do it)
Biff
Reged: 09/04/05
Loc: Courtice, Ontario
I'll make it 6.
-------------------- Ryan
Antares 200mm f/6 Dob & 130mm f/5 Travel Dob.
Projects on the go...
- a couple 80mm SS refractors on the back burner.
- a few small mirrors awaiting polishing
- 260mm f/7.15 mirror... still polishing
Member of DRAA
My house.
DRAACO
10 registered and 8 anonymous users are browsing this forum.
Moderator: Don W, Joe Cipriano
